Welcome to the North American Subaru Impreza Owners Club Sunday August 31, 2014
Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC > RMIC Vendor Classifieds
Old 11-17-2010, 03:02 PM   #1
RallySport Direct
NASIOC Storefront Vendor
Vendor Sales Rating: (95)
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Talking --->Brand new HKS header! In stock, get yours today!<---
Details:
409 Stainless Steel
Equal Length
Includes all the needed hardware and gaskets
2008+ Specific fitment!
Price: 553.35 Shipped in the continental US!
__________________
RallySport Direct is offline   Reply With Quote
Old 11-19-2010, 12:44 AM   #2
zizux
Member Sales Rating: (1)
Member#: 199836
2011 STi
Uses factory up pipe?
zizux is offline   Reply With Quote
Old 11-19-2010, 10:33 AM   #3
RallySport Direct
Member#: 33174
We are Open Late!
Factory or any other OEM direct replacement up pipe
__________________
Old 11-19-2010, 08:09 PM   #4
bhhamblin
n00b Moderator
Member Sales Rating: (35)
Member#: 99397
13 STI, 83 DR30
93 R32 GTS-T, 93 R32 GTR
Editttttt
bhhamblin is offline   Reply With Quote
Old 11-24-2010, 09:41 PM   #5
azn2nr
Member Sales Rating: (23)
Member#: 35276
2006 2.5i clone
438/420 whp
Best fitting header ever. No flex pipes no slip joints. Just fits. Full review coming
this header will fit any triangular pan'd wrx/sti from 05-11.
on wrx 06 and 07 WRX ONLY you will need to remove the oil cooler and cocking bracket pictured together here
the cocking bracket is pictured by itself here
and make it look like this here
to do this you will need to blockoff or bypass the coolant line that runs into the oil cooler as well as aquire an N/A oil filter bolt. blocking off requires you to tap the water pump or ghetto rig a plug. the bypass just requires cutting the hard line bracket off which ends up looking like this here (displayed with N/A oil filter bolt)
finished product
azn2nr is offline   Reply With Quote
Old 11-26-2010, 05:48 PM   #6
bhhamblin
n00b Moderator
Member#: 99397
13 STI, 83 DR30
Installed another one of these on my personal car today. Perfect fitment!
Old 11-26-2010, 10:15 PM   #7
08WhiteRex
Member#: 187453
2012 Mulletmobile
the person holding the light for that picture must be a total badass.....
08WhiteRex is offline   Reply With Quote
Old 11-26-2010, 11:04 PM   #8
Legba
Member Sales Rating: (15)
Member#: 88589
2012 STI
the best one
I'm just wondering where the factory subframe support is? It looks like it has to be removed to install this header
I'm not even certain you can fit aftermarket bracing on there. It just goes WAY over to the passenger side.
Legba is offline   Reply With Quote
Old 11-27-2010, 02:29 AM   #9
08WhiteRex
Member#: 187453
2012 Mulletmobile
it is 100% installable without removing any of the factory parts on the newer models. I'm also assuming that, disregarding the oil cooler with the cocking-bracket, that it installs fine as well.
Old 11-27-2010, 12:38 PM   #10
Legba
Member#: 88589
2012 STI
the best one
Gotcha. Too bad it's not 304 I supose that explains the price
Old 11-27-2010, 12:44 PM   #11
bhhamblin
n00b Moderator
Member#: 99397
13 STI, 83 DR30
No worries. You dont see it under the car. Also, the factory sub frame brace does not need to be removed or modified whatsoever. I was also able to retain the factory under panel without it melting.
Old 11-27-2010, 01:02 PM   #12
zizux
Member#: 199836
2011 STi
Gains / Losses?
Brody you put this on your 08? What effects did it have?
Old 11-27-2010, 01:33 PM   #13
wantsti
Member Sales Rating: (83)
Member#: 134764
04 sti
java black pearl
even 304 cracks that why full-race and killer-B use 321.
wantsti is offline   Reply With Quote
Old 11-27-2010, 02:28 PM   #14
Legba
Member#: 88589
2012 STI
the best one
Full-Race headers are made from schedule 10 conduit (~.12 thick), which is 304. Killer B is the only manufacturer that I know of that uses 321 (alloyed with titanium).
Yes 304 cracks, but 409 is less strong at higher temperatures. That's why NO ONE uses it for manifold. It's a cheap material, cheaper than steel in some cases. I'm really suprised HKS puts thier name on this. They don't usually make cheapo stuff, but the material just doesn't match the application. If it did, everyone would be making them from 409 because it's inexpensive.
Old 11-27-2010, 08:30 PM   #15
azn2nr
Member#: 35276
2006 2.5i clone
438/420 whp
So why are you even asking the questions then? If you think its cheap then get one thaw the material you like
Old 11-27-2010, 10:18 PM   #16
08WhiteRex
Member#: 187453
2012 Mulletmobile
No lie, brody's car sounds just like a porsche now. It's especially pissed off, though quieter.
Old 11-27-2010, 11:28 PM   #17
Legba
Member#: 88589
2012 STI
the best one
I'm cheap, just not quite Ebay cheap. Unless it will last twice as long as the 2 sets of Ebay headers I can get for $200 each
Old 11-27-2010, 11:38 PM   #18
08WhiteRex
Member#: 187453
2012 Mulletmobile
I've seen $1000 headers crack like nobody's business that were made of pure platinum and tyrannosaurus tooth enamel.... The point is any header on our cars is going to be prone to cracking.
Old 11-27-2010, 11:59 PM   #19
azn2nr
Member#: 35276
2006 2.5i clone
438/420 whp
ps. iirc the factory crosspipe and uppipe are made of the same material as these headers, and the top of the uppipe gets the hottest when running hard. not to mention the header has more area for gasflow than the stock manifold which would make it more efficient and cooler
Old 11-28-2010, 12:13 AM   #20
Legba
Member#: 88589
2012 STI
the best one
^ lol, uh huh and not true. Headers crack from using materials not capable of withstanding the temperatures seen in turbocharged applications, poor manufacturing and crappy design. Header built to the contrary will outlast the car.
IMO buying cheap headers is just asking for eventual failure. The tricky part to me, or anyone else considering cheap headers, is does that happen in 5 months or 5 years. What kind of warranty do these headers come with and RallySport stands behind, might have some buying power too.
Old 11-28-2010, 12:18 AM   #21
Legba
Member#: 88589
2012 STI
the best one
Thats not exactly a good thing. Those fail and leak all the time
I'd like to head more details on wall thickness on the up-pipe and that stamped collector. I'm sure RallySport can answer some questions, but really if it's got a decent warranty I'd care less about those kinds of details.
Old 11-28-2010, 12:31 AM   #22
08WhiteRex
Member#: 187453
2012 Mulletmobile
^lol, uh huh and not true. I was not being sarcastic. I have seen just as many high quality, "brand name" headers fail as ebay's. The exposure to rapid changes in temperature under the motor, the span that the manifold has to meet, and the HUGE amounts of torque experienced by making a seal between the manifold and the cantankerous subaru up pipe in combination with the previously mentioned factors lead to failures of either the header or the up pipe.
And they come with a 4 year warranty. It says, clearly, on their site under "warranty"
Old 11-28-2010, 12:35 AM   #23
bhhamblin
n00b Moderator
Member#: 99397
13 STI, 83 DR30
^Ive personally never seen a stock up pipe fail. Ive owned 3 subarus and currently own 2. None of them has had problems. If you want to talk about an exhaust manifold cracking look at the APS. My first set cracked in 3000 miles, I then had it welded back up. I plan to do the same with these HKS headers if it comes down to it. This manifold has some nice bracing where the welds are connecting to the collector so I dont think there will be problems with cracking there. Guess we will find out.
Ive seen lots of different manifolds crack made from all different kinds of metals. They will all crack eventually. For now this header was a more than reasonable price with perfect fitment and I dont mind spending the 45 minutes to install and un-install if I need to get it welded. Which you should be used to by now with all the ebay manifolds you speak of.
These ones you dont have to hit with a mallet to get off either
Old 11-28-2010, 12:36 AM   #24
Legba
Member#: 88589
2012 STI
the best one
OK, thanks. Did not see the warranty info.
Old 11-28-2010, 01:38 PM   #25
zizux
Member#: 199836
2011 STi
V2 Cobb Accessports Back in Stock- get yours today! EviL Performance Engine/Power/Exhaust 36 01-14-2008 12:24 PM
HKS Kansai Rear Diffusers, new Chargespeed items in stock! Other items too! Gruppe-S Exterior/Styling 6 04-14-2006 03:09 PM
New shipment of Knobs in stock as of today dentsport NESIC Vendor Classifieds 7 01-11-2006 08:25 AM
F/S: New HKS Header/Great Deal From A Private Seller giovanni Private 'For Sale' Classifieds 14 12-09-2003 11:05 AM
