Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Car Care & Detailing
Old 11-18-2010, 05:24 PM   #1
Draco Performance
Vendor Sales Rating: (7)
Member#: 111202
2004 STi
Blue/Gold
Default The BEST most ADVANCED detailing product line in America! - TRY IT AND SEE!
WAXING FRENZY!!
Please read about this product. TRY this product... You will see why this is the BEST that's out there!
**Waxing Frenzy is sold EXCLUSIVELY by Draco Performance**
STARTING @ $19.95
Contains #1 grade Brazilian ivory carnauba wax (the most refined carnauba in the world), silicon, and polymers not found in any other wax in the United States. The silicon bonds itself to your surface, prolonging protection. It’s easy to apply and even easier to remove. Once it hazes, simply wipe it off as if you are dusting. Goes farther than most waxes. In fact, the less you use, the better. Removes light to medium oxidation. Helps to keep colors bright and whites white. Waxing Frenzy is a breakthrough in boat care. It is a true cleaning wax. The chemical makeup allows it to lift dirt from the surface and dry with the wax that is wiped off. We have incorporated the needs of the vehicle owner with the latest in American & European technology to achieve the following results:
- Easy on; easy off. You can wax an entire boat or car before wiping off. --- - Wipes off as if you're dusting a polished table.
-Can be applied in direct sunlight without the risk of streaking or swirling. Apply to surfaces up to 120 degrees.
- Can be used on fiberglass, painted surfaces, plexiglas, isinglass (clear plastic windows), glass, and metal (aluminum, chrome, brass, and stainless steel).
- For best results, apply sparingly. A little goes a long way (generally 2-3 times farther than other waxes).
- When used on race boats recently, teams noticed that there was no salt evident when boats came out of the water.
- Waxing Frenzy! can be used in place of Rain-X on Lexan windshields and canopies. Water "flies" right off, leaving a cleaner, clearer view for driver. This also reduces drag caused by most windshield waxes.
- Protects surfaces up to 1210 degrees. This is excellent for exhausts.
- Brings out the best in your boat. Graphics and colors will often be deeper and richer than when new.
- Scientifically formulated for no-wax buildup. Actually detects previous wax applications, removes and replaces with itself.
- NO DRAG! By preventing water from sticking, Waxing Frenzy creates a smooth, slick surface which in turn increases speed.
- Recent prop testing shows no sign of corrosion 64 days (and counting) after Waxing Frenzy was applied.
- Wait 'til you see it on dark colors! Black and red....no problem!
Waxing Frenzy can last anywhere from one month to 6 months, depending on use, storage, and overall condition. Remember, your gelcoat is porous. It will soak up as much wax as it needs. If your boat has not been properly maintained, it becomes "thirsty" and may require several applications to achieve the results you are looking for.
We have had calls recently questioning the longevity of Waxing Frenzy! Some people are under the impression that if the wax does not bead, it is gone. Our wax is designed to bead for about 2 weeks. Once the Carnauba dissipates, the polymers take over and result in a "sheeting" action. These polymers are giving you lasting protection, while helping to prevent water spots.
Frenzy! Spray Wax
STARTING @ $12.75
Read the directions on the label of any Spray Wax or Quick Detailer and the first thing you'll see is "do not use in direct sunlight" or "find a shaded area".
Frenzy! Spray Wax can be applied to surfaces up to 170 degrees F and protects up to 190 degrees.
Most spray waxes (quick detailers) will dissipate when heated or evaporate as soon as they hit a hot surface.
Frenzy! Spray Wax is a polymer based product. It does not contain water; you get what you pay for!
Use Frenzy! Spray Wax on your boat right after you pull it out of the water to prevent water spots (no more vinegar and water, which strips the wax and creates a vicious cycle).
Treat your surface to a beautiful feel and shine between waxes.
Will not streak windows, so don't worry about overspray.
Safe on clear coat, gel coat, and fresh paint.
Will not leave a wax buildup on rubber or vinyl.
This is an excellent product for quick touch-ups, cockpit areas or your entire boat, car, motorcycle or RV.
Prepping boats for a boat show? Nothing works better or faster. In fact, Frenzy! Spray Wax has cleaning capabilities, as well.
Ready to use. Simply spray a light mist over surface. Wipe on, insuring complete coverage. Remove with soft, dry cloth.
Don't let the light and easy application fool you. Frenzy! Spray Wax offers superb protection for up to 3 weeks on cars and 1 to 2 week on boats.
Ok, you know who you are. The guy who takes painstaking efforts to make sure his boat is immaculate before leaving the dock. Now, what to do when you arrive. Remember, once the motor is turned off, it's all about the looks! How about a quick touch up with Frenzy Spray Wax? Only takes a few minutes and you'll be the shining example of a truly HOT BOAT!
Geoffrey Bodine's Frenzy! Ultra-V Pro
STARTING @ $15.50
Alcohol-Free Conditioner and Protectorant for Vinyl, Leather, Plastic, and Rubber
*Frenzy! Ultra-V Pro does not seal the material. It adsorbs, allowing the material to "breathe"
*Bonds with the surface, enhancing and locking in the natural plasticizers of the material to keep it soft and supple
*High concentration of UV protection prevents premature drying, cracking, splitting, and fading
*Interior and exterior protection
*Helps to maintain color on vinyl decals
*Does not "eat away" at stitching
*Soaks in immediately, leaving no oily film behind to attract dust
*Decreases the need for frequent cleaning
*Use on dash, seats, rubber gaskets, hose, trim, bumpers, convertible tops, headliners, and plastic trim (such as found in many new trucks and SUV's)
*Does not fling onto sides of vehicle when used on tires
*Contains no harmful silicone oils or petroleum distillates.
Frenzy! Wash & Wax
STARTING @ $11.75
Highly Concentrated -- A 16 oz. bottle makes up to 40 gallons of wash!
*Heavy duty emulsifiers lift dirt, contaminates and bird droppings from surface
*Rinses clean; no soapy residue
*Helps to maintain that just-waxed luster
*Excellent wash for boats, cars, RV's and motorcycles
*In our boat detailing business, this product has cut our cleaning time dramatically and produced outstanding results!
*Frenzy Wash & Wax uses positive and negative charges which react to the surface after it's been waxed with Waxing Frenzy! This will help to maintain your shine and protection between waxes.
Don't be fooled by the consistency of this product. You'll notice that it is not very thick. This has nothing to do with the concentration. MOST washes on the market use a thickening agent to expand the product and make it almost gel-like in consistency. The ingredient that they use to do this is....SALT! Not exactly something you want to ADD to the surface of your boat.
__________________
Tuning*Suspension*Engine Builds*Quality Performance Parts* Race Track Prep*Enthusiast Educational Classes
For Draco Performance Merchandise -
Draco Performance is offline   Reply With Quote
Old 11-20-2010, 06:51 PM   #2
Sales@Draco
Member#: 202645
PMs replied!
Sales@Draco is offline   Reply With Quote
Old 11-23-2010, 09:38 AM   #3
Sales@Draco
Member#: 202645
Just used the wash and wax on my Lexus.... nothing comes close to this stuff!
Old 11-24-2010, 09:01 AM   #4
Sales@Draco
Member#: 202645
Last bump for the holidays!
Old 11-29-2010, 08:14 AM   #5
Sales@Draco
Member#: 202645
Hope everyone had a good holiday!
Old 12-01-2010, 02:34 PM   #6
Sales@Draco
Member#: 202645
Wax on.... Dust Off.....
Old 12-02-2010, 03:23 PM   #7
Sales@Draco
Member#: 202645
b u m p
Old 12-07-2010, 09:15 AM   #8
Draco Performance
Member#: 111202
2004 STi
Blue/Gold
gift card bump!
__________________
Old 12-08-2010, 04:44 PM   #9
Sales@Draco
Member#: 202645
Bump.....
Old 12-13-2010, 10:33 AM   #10
Sales@Draco
Member#: 202645
bump......
Old 12-14-2010, 03:44 PM   #11
Sales@Draco
Member#: 202645
BUMP!!!! Check Out www.Draco-Forum.com
Old 12-17-2010, 10:29 AM   #12
Sales@Draco
Member#: 202645
bump.......
Old 12-20-2010, 12:54 PM   #13
Sales@Draco
Member#: 202645
bump*****
Old 12-27-2010, 03:11 PM   #14
Sales@Draco
Member#: 202645
Bump!!!!!!
Old 12-30-2010, 07:47 AM   #15
Sales@Draco
Member#: 202645
Thank you for all of your orders! Let me know what you think!
Old 12-31-2010, 08:15 AM   #16
Draco Performance
Member#: 111202
2004 STi
Blue/Gold
Show season is right around the corner.... be sure you stock up on detailing products
__________________
Old 12-31-2010, 09:33 AM   #17
xaznxeclipsex
Member Sales Rating: (8)
Member#: 179310
2008 WRX Stage 2
WR blue
Everyone claims their products are the best, can you post some pics of your results?
xaznxeclipsex is offline   Reply With Quote
Old 01-03-2011, 08:10 AM   #18
Draco Performance
Member#: 111202
2004 STi
Blue/Gold
sure will! Once we finish moving to a new location I will use the full line on my Lexus and take lots of Picts!
One thing about this wax is that there is no silicone which is found in most waxes to give it the shine. Also this can be applied in temps up to 130 degrees in direct sunlight... and just about be dusted off! Instead of a 3-4 step waxing process, the Waxing Frenzy has all of the steps rolled into one!
__________________
Old 01-04-2011, 08:23 AM   #19
Sales@Draco
Member#: 202645
Bump!!!!!
Old 01-05-2011, 08:39 AM   #20
Sales@Draco
Member#: 202645
Bump!!! I should be detailing my IS250 this weekend or early next week. I will post up photos when I am done. I think I am going to do a video on how easy it is removed as well.
Old 01-06-2011, 04:21 PM   #21
Sales@Draco
Member#: 202645
bump bump bump
Old 01-10-2011, 08:09 AM   #22
Sales@Draco
Member#: 202645
PMs replied!
Old 01-11-2011, 11:52 AM   #23
Sales@Draco
Member#: 202645
bump^^^^^^
Old 01-12-2011, 02:09 PM   #24
Sales@Draco
Member#: 202645
Well all of the snow and ice we have had here in NC has really done some swirl damage on my Lexus. I will be using this product soon and will take lots of photos to show everyone how awesome this stuff really is! stay tuned!
Old 01-24-2011, 04:57 PM   #25
Sales@Draco
Member#: 202645
Bump^^^^^^^^
TurboXS Full Product Line Sale, You Have Got To See These Prices! Spun Autosports Vendor 'General Sale' Forum 156 05-02-2010 07:23 AM
What's the latest/most advanced/coolest product from each of the military branches? -=C=- Off-Topic 53 06-18-2008 02:14 PM
the best, most obscure, most elitiest GINGER beer in the world. alacrity024 Off-Topic 33 09-07-2007 05:32 PM
Someone try this and see if it works. Thunder Lungs Off-Topic 12 04-24-2007 04:23 AM
Sprint is the Devil, you know it is... just try it and you will feel better Hunter S. Thompson Off-Topic 5 08-27-2003 08:17 AM
Message Board Statistics All times are GMT -4. The time now is 06:07 AM.
