Closed Thread
Old 11-18-2010, 07:10 PM   #1
cj_WReX
Member#: 243660
89 964 c4
Default alignment question
only have 10k miles on my 2010 wrx 5-door.
bought 16 inch enkei edr's with bridgestone blizzak ws60 195/60/16 from tire rack pre-mounted and balanced.
Mounted the new setup a couple of days ago. the tires are sloppy as hell on dry pavement as expected. The only thing that concerns me is that the car pulls slightly right on the interstate. And I mean slightly. Is this a concern? Should I get an alignment? How often are you supposed to get an alignment? Once a year or every time I swap out tires?
cj_WReX is offline
Old 11-18-2010, 08:18 PM   #2
jutes85
Member#: 127232
E92 M3
98' Foz
I get an alignment once a year regardless of suspension or tire changes.
jutes85 is offline
Old 11-18-2010, 08:40 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
your factory alignment is garbage in any event....they all are
factory 'specs' suck real-REAL bad
Uncle Scotty is offline
Old 11-18-2010, 09:25 PM   #4
calibrationx
Member#: 257423
2014 Legacy
Ice Silver Metallic
If it pulls to the right you should take it in for an alignment. The dealer covered my 1st under warranty.
calibrationx is offline
Old 11-18-2010, 10:36 PM   #5
cj_WReX
Member#: 243660
89 964 c4
wonder if an alignment will still be covered under warranty now that I've put on a different wheel/tire setup
cj_WReX is offline
Old 11-18-2010, 11:47 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
irrelevant
Old 11-19-2010, 12:16 AM   #7
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Most dealers will only check to make sure the alignment is within spec under warranty. The factory specs are so loose that your car is more than likely well within spec.
Take it to somewhere that knows what they are doing and will give you a printout of the results after they have aligned it.
speedyHAM is offline
Old 11-19-2010, 11:08 AM   #8
calibrationx
Member#: 257423
2014 Legacy
Ice Silver Metallic
If the wheel/tire set up is the same or close to oem spec, then they likely won't deny it. But i've heard of some getting denied for wheel/tire setups too far off from oem.
Old 11-19-2010, 11:56 AM   #9
sc00by4life
Member#: 97135
the point being that if hes only changing out wheels and tires, he does not need an alignment.
sc00by4life is online now
Old 11-21-2010, 08:09 PM   #10
cj_WReX
Member#: 243660
89 964 c4
Could it be that the wheels are.out of balance? Tire rack mounted and balances them but maybe they got unbalanced during the shipment
cj_WReX is offline
Old 11-21-2010, 11:52 PM   #11
jdmboy
Member#: 240161
2002 wrx wagon R.I.P
87 bmw e30
its not likely, an unbalanced wheel and tire is more likely to cause a vibration or something of that sort the only way i know of (could be wrong) that a properly mounted and bananced wheel and tire will cause your car to pull is if there is a radial pull problem with the tire, you can diagnose this by swapping the wheels around and seeing if the pull changes.
as for the alignment its tricky as everyone has said the factory alignment is trash. as for how often you should get an alignment, you need to get one as often as you need to get one (when something gets out of whack). I work at a car dealer and like many other users i can do an alignement my self or have one of my techs do it for next to nothing. that said i get an alignment every winter (when i put my winter set up on) and every spring (when i put my summer set up on). I always go with zero toe all the way around and -1.5 degrees of camber up front and -1 degrees of camber in the back (for winter) and -2 degrees of camber up front and -1.5 degrees in the back (for summer).
jdmboy is offline
Old 11-22-2010, 12:53 PM   #12
cj_WReX
Member#: 243660
89 964 c4
I dropped the car off at the dealership today for an alignment. Highly doubt this will be covered through warranty.
cj_WReX is offline
Old 11-22-2010, 03:55 PM   #13
cj_WReX
Member#: 243660
89 964 c4
Picked up the wrex from the dealership.............. $90 alignment. It is not pulling to right like it was which is good.
The front right was adjusted from -0.5 degrees camber to 0 degrees
The front right toe was adjusted from 0.12 degrees to -0.01 degrees
The right rear toe was adjusted from -0.08 degrees to -0.01 degrees
So it wasn't too far out of alignment.....
cj_WReX is offline
Old 11-22-2010, 05:24 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
you got ****ed in the ass with that alignment
0 camber is DANGEROUS
Old 11-22-2010, 06:06 PM   #15
sc00by4life
Member#: 97135
Take it back and get it realigned. Tell them you want a competent technician doing the alignment.
Old 11-22-2010, 06:52 PM   #16
cj_WReX
Member#: 243660
89 964 c4
it only has 0 degrees camber in the front.
The rear is -1.4 degrees on the right and -1.3 on the left.
I don't feel like going back and arguing with the service department. Is o degrees camber really dangerous?
cj_WReX is offline
Old 11-22-2010, 07:42 PM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
THAT is a REAL-REAL stupid alignment
guaranteed to kill you quick if you ever have to make a quick turn
you WILL slide straight into whatever it is you think you will avoid
promise
bad juju
Old 11-22-2010, 08:01 PM   #18
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Scott's flair for exaggeration strikes again. 0deg camber up front is certainly not optimal, and will almost certainly lead to accelerated wear on the outside shoulders of the tires, but it's hardly "dangerous". To say that is just silly.
Maybe Scott drives like an ass-clown on the street and thus is in danger of sliding straight into anything he's trying to avoid. The other tens of millions of drivers on US roads today, the overwhelming majority of whom have crappy alignments, don't seem to be crashing all around me as I run errands.
As is covered in basically every alignment thread on this forum, you want some negative camber up front for improved handling and tire wear. I don't know what the new body styles will get with the factory adjustment, but on the pre-'08s you would get somewhere in the -1 to -1.5 ballpark, which is about perfect for the average driver.
It certainly can't hurt to go ask the dealer to re-perform the alignment, but I would guess they're not likely to help you. The alignment is in spec, and that's probably what they'll tell you.
Pat Olsen
Patrick Olsen is offline
Old 11-22-2010, 08:06 PM   #19
Uncle Scotty
Member#: 16200
OK buy Nates beans
Pat Olsen
blow me, Pat
0 camber in front is dangerous
no possible doubt....and just plain stupid as well
only a total ****ing moron would align a wrx with 0 camber in front
are YOU one of those???
Old 11-22-2010, 08:08 PM   #20
cj_WReX
Member#: 243660
89 964 c4
well what a waste of my fuggin time.
What Camber should I have them setup?
-1 up front and -1.5 in for the rear as suggested by JDMboy?
Why do they do they do 0 degrees camber in front if it's "dangerous"?
BTW - the car is still going slightly right .... getting frustrated
cj_WReX is offline
Old 11-22-2010, 08:16 PM   #21
Uncle Scotty
Member#: 16200
OK buy Nates beans
forget the 'going to the right'....that is because of the crown of the road
but zero camber will make the car understeer even worse than it already does...add slippery surface and all done
ya want as much negative camber as can be made to happen, even side to side and done
Old 11-22-2010, 09:47 PM   #22
jdmboy
Member#: 240161
87 bmw e30
no no no you read my post wrong i said -1.5 up front and -1 in the rear, but seeing as you have -1.5 in the rear as it is(its unadjustable) if i were you i would max out the front in an effort to cut down on understeer and balance the car. honestly you have too much negative camber in the rear, the 08+ subies have a rear suspension problem, that problem being that the rear end grips too well. yes i said it grips too well making the car drastically un balanced from a handling stand point (its going to understeer like a mother****er)
oh and BTW id like to meet the ****tard that put your camber at 0 upfront, if you dont drive like an 80 year old lady your going to destroy the outside shoulder of your tires.
jdmboy is offline
Old 11-23-2010, 11:14 AM   #23
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Originally Posted by Uncle Scotty View Post
blow me, Pat
Grow up.
So what do you know that the Subaru engineers don't? You know, the guys who designed these cars and spec'd an alignment that is "dangerous"? The factory spec for front camber is -10’ (note that’s minutes, not degrees) for the WRX in both sedan and wagon configurations. (The spec for the Outback Sport is even less, only -5', or -0.08°.) The Factory Service Manual says the tolerance is ± 45’, so converting to degrees that gives us -0.17° ± 0.75°. In other words, it's permissible to have positive front camber. Considering how poor the alignments typically are coming off the assembly line I'm willing to bet there are Subarus being sold today with 0° or even positive camber.
To say that such an alignment is "dangerous" is simply not borne out by the facts. If it was dangerous, Subaru's engineers wouldn't spec the cars to be built that way. If it was dangerous, there wouldn't be hundreds of thousands of cars of assorted brands safely navigating the road today with such alignments.
Or a dealer technician aligning a car to factory specifications. If you want more from an alignment, don't take it to a dealership and/or don't let them do the alignment without any guidance on where you want it set.
There are a bazillion alignment threads in this forum. Reading just one of those before you took your car to the dealership would've saved a lot of time.
It's not dangerous. Ignore Scott's hyperbole. Your car won't handle as well as it could, and you will wear the outer shoulders of your front tires (unless you drive like a Grandma, as jdmboy said), but it's not dangerous.
Old 11-23-2010, 09:04 PM   #24
cj_WReX
Member#: 243660
89 964 c4
FYI - if you go to GO Subaru on Arapahoe for an alignment these are the specs you can expect.
cj_WReX is offline
Old 11-23-2010, 09:13 PM   #25
nhat
Member#: 140163
03 STi
hellaflunctional
those are the specs at every dealership. never go to a dealership for an alignment...
nhat is offline
Closed Thread
alignment question for the alignment gurus... jonjonkills101 Brakes, Steering & Suspension 2 01-18-2009 12:57 PM
Alignment question for those that changed their suspension themselves Bob O Brakes, Steering & Suspension 9 04-24-2001 09:26 AM
alignment question mitsubaru Southern California Impreza Club Forum -- SCIC 1 04-18-2001 05:46 PM
Alignment question wrx55 Vancouver Impreza Club Forum -- VIC 4 01-11-2001 04:38 AM
Wheel change & Alignment question? Robmat South East Region Forum 2 01-01-2001 08:02 PM
