Old 11-19-2010, 07:18 PM   #1
Soarer
Member#: 134872
2005 LGT Ltd Wagon
Mods, Mods, Mods!
Default How do you test OBD2 port wiring?
So, I've got my wrx motor installed in my 97 legacy and it runs! I bought a code scanner and hooked it up to see what codes it is throwing but the reader won't register. It says it's not getting a signal from the port. How do I test the pinouts on the port to see which one is not functioning as it should?
Soarer is offline   Reply With Quote
Old 11-21-2010, 05:36 PM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Check for continuity between the OBD2 pinouts and where the other end of the wire is supposed to be.
For the correct ECU pins to test it depends on what year WRX wiring harness you are using.
First check the grounds to make sure they are connected.
speedyHAM is offline   Reply With Quote
how do you test a fuel pump relay fyr3 Newbies & FAQs 2 04-04-2013 05:38 PM
how do you test to see if you your center diff works moorebl Transmission (AT/MT) & Driveline 0 08-13-2008 10:33 PM
How do you test the Factory Boost Solenoid? stealthECC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-13-2008 11:24 AM
How do you test your coilpack? Sephro New England Impreza Club Forum -- NESIC 13 12-20-2007 12:24 PM
OBD2 test with EMS.. how do you guys pass?? jdchmiel Engine Management & Tuning 0 03-10-2004 12:48 PM
