Old 11-19-2010, 09:25 PM   #1
nicko360
Member#: 249036
2002 rhd s2000
spa yellow
Default need a new computer help?
just picked up a 98 legacy gt sedan w the 2.5 engine
the car idles low and check engine is on, previous owner told me he took it to a mechanic and swears up and down that they all told him it needs an ECU. my question is, will an automatic ecu work (car is a 5 speed) I cant seem to find a 5 speed ecu online for a 98. also will a 97 or 99 ecu work? thanks
nicko360 is offline   Reply With Quote
Old 11-20-2010, 01:17 AM   #2
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Yes, you can use an ECU from an automatic in a manual (or the other way around) with out issues.
My understanding is the fuel tank on the 99's has different emission issues so it may or may not work. You might want to swap in the newer fuel tank and evaperative emission controls from the 1999 model along with the newer '99 ECU.
You can also use an ECU from a '98 Impreza RS, although the '99+ Impreza used the MAP sensor instead of the MAF sensor so those are out.
Do to all the changes in the '99 2.2 motor, their ECU will not work in any pre 2000 EJ25 powered cars. You could use an ECU from an earlier 2.2 motor, although the electronically controlled speed limiter would kick in at ~ 112 MPH.
Jonathan is offline   Reply With Quote
Old 11-20-2010, 02:20 AM   #3
kirbykirb
Member#: 183596
2005 WRX/9-2x
Obsedian Black Pearl
I have an ECU available if you need to test it out. :P
kirbykirb is offline   Reply With Quote
Old 11-20-2010, 02:59 AM   #4
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
How low is the idle, and what is the CEL code for?
If the car runs and drives fine otherwise, my guess is that the PO was too lazy to fix the real issue. ECUs don't fail often, and a low idle isn't usually an ECU problem.
Huffer is offline   Reply With Quote
Old 11-20-2010, 04:56 PM   #5
nicko360
Member#: 249036
2002 rhd s2000
spa yellow
check engine is on, car sometimes at idle drops to 500 and acts like its going to die, ive always worked on hondas and never really ran into the problem of a bad ecu, but i was wondering if maybe it was a subaru think
also the car sounds like it has a bad wheel bearing and the abs engages at low speeds, the seller told me somehting was wrong with the hub and it would be best to just replace the whole thing
Old 11-20-2010, 05:04 PM   #6
nicko360
Member#: 249036
2002 rhd s2000
spa yellow
so my other question is, will any hub assembly off a 96-99 work the same or does it need to be exclusivley off a gt>
Old 11-21-2010, 07:45 AM   #7
Huffer
Member#: 36735
99 GF8 Impreza 2.0
What is the CEL code?
500 isn't bad, the tach starts at 500.
Sounds like you need to clean the idle air control valve. In the winter these cars have a fluctuating idle if the ambient air temp is quite cold.
If it sounds like a bad wheel bearing, and the ABS continues to engage, then it could be a broken ABS sensor ring.
Old 11-21-2010, 01:34 PM   #8
nicko360
Member#: 249036
2002 rhd s2000
spa yellow
some times the idle drops though and it dies at stopsigns, im going to have the CEL checked today. and when it idles between 500-1000 it sputters like its goin to die
Need a lil computer help, blue screen of death. Hondaslayer Off-Topic 15 01-31-2006 06:30 PM
Need a little computer help linux>windows Off-Topic 34 12-30-2004 01:58 PM
Need a new computer KapaFool Alaskan Impreza Club Forum -- AKIC 46 10-28-2004 12:11 AM
I need a new computer, help me choose please BrysImpreza New England Impreza Club Forum -- NESIC 24 09-05-2003 10:03 PM
Gauging Interest - do you need a new computer? maaw Bay Area Impreza Club Forum -- BAIC 4 07-12-2003 12:51 AM
