Old 11-19-2010, 10:50 PM   #1
vaj
Member#: 59136
04/5 APRWidebody STi
EQ Tuned - Green/Meth
Default tinywrex lc/ffs patching issues - source file corrupt?
Hi guys
I'm trying to patch tinywrex' lc/ffs patch to my tuned rom. I have placed the ROM file into the same folder as the patch, tinypatcher, etc.
When I open tinypatcher using the batch file I see that the rom is loaded. When I press any key to continue I see this error message:
Error: Source file is corrupt at byte 0x29b5c (0x1d expected, 0x8d found)!
Something I'm missing here? Can anyone offer me any advice? Thanks!
rom image is a 32 bit (2004 USDM STi)
vaj is offline   Reply With Quote
Old 11-19-2010, 11:20 PM   #2
vaj
Member#: 59136
Sigh.. I think I found the problem.
My original rom that I had the patch file for: A2ZJ107
Rom my new tuner used: A2ZJ500J
I suppose that would be the issue there.... :facepalm:
Old 11-21-2010, 08:51 PM   #3
vaj
Member#: 59136
...or not. I have the correct patch and when I run tinypatcher it gives a similar error message.
Error: Source file is corrupt at byte 0x296ep (0x5 expected, 0xff found)!
Any suggestions?
Old 11-21-2010, 09:28 PM   #4
Nuke209
Member#: 108089
2003 WRX
NF Performance
you can take your map from your tuner, copy all tables over to the A2ZJ701 rom and then patch that.
Nuke209 is offline   Reply With Quote
Old 11-21-2010, 09:42 PM   #5
vaj
Member#: 59136
Thanks for the reply! I could do that certainly. However, I have obtained the correct patch for the A2ZJ500J rom so I'd rather have it patch as it should. I have seen that other have had to copy/paste tables though... sigh
I'm placing a copy of my rom in the folder. Then opening the batch file which takes me to tinypatcher and when I try to run it it gives me the error. I've renamed the file to the ecu rom id as well to no effect.
Old 11-22-2010, 12:32 AM   #6
Nuke209
Member#: 108089
2003 WRX
NF Performance
copy and paste...give it a shot lol
Old 11-29-2010, 02:20 AM   #7
o3WRXTC
Member#: 200856
2003 Impreza WRX
aspen white
not sure if u fix the problem yet.
but also make sure the size is correct.
im not sure if the 32 bit had different save size's like the 16 bit ecu's.
just a thought, hope this helps.
o3WRXTC is offline   Reply With Quote
Old 11-29-2010, 10:35 AM   #8
quazimoto
Member#: 70395
Also the file name has to be the stock ROM ID and nothing else. S o if your using a ROM named " spankystage2" it's not going to work. If your following the instructions to a tee,there should be no problem.
quazimoto is offline   Reply With Quote
Old 02-05-2011, 01:32 AM   #9
AKSubieDubie
Member#: 190003
2000 RSTi BW8375
I'm having the same problem with my buddies patch file. I've done 3 patches before so I know what im doing
AKSubieDubie is offline   Reply With Quote
Old 02-05-2011, 07:22 AM   #10
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
The patches are specific to the ecuid of the ROM. So make sure you have the correct patch for exact ROm you are using.
Also, if you have a 16bit ROM, you need to ensure your ROM is 192K. If it is not 192K, you will get errors during the patch stage. To convert the ROM to 192K, you need to use ECUedit.
Once patched, you will not see the launch control tables in ECUFlash unless you add the required text to the definition file for your ROM and you set the user privilege correctly.
If you are stuck, read the instructions HERE.
Lastly, Tinywrex has a patch serive available HERE, and he will patch your ROm with launch control for only $10. So if you can't do it yourself, then $10 is a small amount to pay to get it patched without the hassle
wrxsti.l is offline   Reply With Quote
Old 08-20-2011, 12:07 PM   #11
SubiSam
Member#: 156401
'03 WRB WAGON
2.1 stroker GTX3071R
Where can I find instructions to convert my Rom to 192k? I have ecuedit but can't figure out how to save it as a different size file.
SubiSam is offline   Reply With Quote
Old 08-20-2011, 06:17 PM   #12
quazimoto
Member#: 70395
tinywrex lc patch jrrevo1 Open Source Reflashes 9 03-21-2013 12:36 PM
Comparable EM with LC/FFS? Scott_2.5TS AccessPort 7 05-13-2009 04:14 AM
Needed: 04 STi Stg1 (Base) Map w/ LC + FFS Spoolin16PSI Open Source Reflashes 2 05-04-2009 10:47 AM
What pins on the UTEC control LC/FFS GeneralTJI UTEC 2 02-27-2009 03:03 PM
LC/FFS without utec controlling fueling, timing, boost? Zumble UTEC 9 02-04-2007 10:06 PM
Message Board Statistics All times are GMT -4. The time now is 08:39 PM.
