Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 07-02-2002, 12:39 AM   #1
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
Default JDM engine swap=short driveshaft
So i am puting a JDM turbo Legacy engine in an Impreza and i try to bolt up the drive shaft and its about 3 inches too short. I figure i have to use a Legacy drive shaft but why? Is the Legacy tranny shorter then Impreza?? The center carrier to diff length is OK. Anyone Know??
Scoobie Steve is offline   Reply With Quote
Old 07-02-2002, 09:16 AM   #2
go go go
Member#: 2784
Are you talking about prop shaft? the one goes from front to rear?
I had the opposite problem.
My car was 2WD and I converted to AWD.
My new tranny is 99RS, propeller shaft/rear diff assy/rear subframe were from old Impreza (93?)
The prop shaft was too long!! I couldn't figure out why? I went to junk yard and bought 99RS prop shaft and it fitted perfect.
Older tranny might have been shorter.
go go go is offline   Reply With Quote
Old 07-02-2002, 03:33 PM   #3
TaiChih
Member#: 3467
1998 Dinan3
Bleck
Didn't the JDM turbo legacy motor only have 188hp?
TaiChih is offline   Reply With Quote
Old 07-02-2002, 04:35 PM   #4
Gonthrax
Member#: 18925
The GT-B makes 280 bhp / 6500 rpm and 249 lbft / 5000 rpm I think the Auto version makes 260bhp.
*Edit*
thats the F 4 DOHC 16v twin turbo, not sure if that's the same engine he was talking about
Gonthrax is offline   Reply With Quote
Old 07-02-2002, 08:13 PM   #5
XT6Wagon
Member#: 524
04 STi
which section is shorter? BTW the legacy should be longer. As far as I know the Impreza uses the shortest 2 peice driveshaft, followed by the Loyale.
Did the driveshaft come with a CV joint? it could be that they took a legacy rear shaft and a impreza front shaft.
XT6Wagon is offline   Reply With Quote
Old 07-02-2002, 10:24 PM   #6
Scoobie Steve
Member#: 2289
1998 11.87@112mph
well XT6 is on the right track i think. I got a legacy driveshaft today and its the correct lenght but the carrier bearing is in the wrong place. I am gonna try a hybrid driveshaft using the legacy front half and impreza rear half. this engine is around 220hp.
JDM engine swap SLIGHTLY Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-06-2005 05:36 PM
f/s full jdm engine swap ej20 turbo omar14 Private 'For Sale' Classifieds 0 08-20-2004 04:02 PM
Jdm Engine Swap TUWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-06-2004 05:42 AM
JDM Engine Swap? ph34rac1d Normally Aspirated Powertrain 3 06-07-2002 05:05 PM
Turbo kit or JDM engine swap? FLUBYUx2 Normally Aspirated with bolt-on Forced Induction Powertrain 51 01-17-2002 02:53 AM
