Old 07-01-2002, 11:46 PM   #1
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Default Trying to cope with jacked up ride height
After few weeks of searching I found no springs for BE. I am sure you all knew it, but I didnt want to give up.
So now I know that the springs are different from JDM BE and USDM BE due to the differences in spring perches.
What I do not know is if the struts from the JDM BE can be used on the USDM BE.
- Are the JDM BE top mounts the same? F/R?
- What about the bottom of the struts? F/R?
- Doesn anyone know if the USDM BH struts can be used on USDM BE sedan?
I am not going to give up and I will find a solution to all BE owners wanting to lower their rides.
-Alex
Imprezer is offline   Reply With Quote
Old 07-01-2002, 11:53 PM   #2
TGycageL0002
Member#: 9116
2000 Legacy
Timberline Green Pearl
in my own struggles. the wagon and the sedan are totally different(usdm, i dont know about jdm)That is why wagon springs will not work on the sedan. What i have heard is that by taking the upper mount and upper perch off the GC8 that springs that are out there will work.. i am skeptical to try it. BTW, you didnt happen to call cobb tuning did you??? They have a listing for the BE spring. I've been meaning to call but i dont get done with work untill 5:00 and they are in texas so they are closed by then..... time zones. Anyways thanks for all the help trying to find a solution.. hope you can do better than i did
TGycageL0002 is offline   Reply With Quote
Old 07-02-2002, 12:53 AM   #3
anotherB4
Member#: 6120
BE5B AVOed B4-RSK
Sorta White
There are some pics of suspension bits here:
http://www.lumine.net/subaru/legacyb4/tuning/
Mostly lower stuff end, but may help a bit.
anotherB4 is offline   Reply With Quote
Old 07-02-2002, 01:03 AM   #4
anotherB4
Member#: 6120
BE5B AVOed B4-RSK
Sorta White
Some pics of B4 bits on this auction: http://page4.auctions.yahoo.co.jp/jp/auction/d18120854
Hope this helps.
Old 07-02-2002, 02:52 PM   #5
TGycageL0002
Member#: 9116
2000 Legacy
if i could read it it might help....if my parents had only spent the money on japanese lessons rather than drums.
Old 07-02-2002, 04:46 PM   #6
lucien2
Member#: 1519
1998 Volvo V70R
lucien2 is offline   Reply With Quote
Old 07-02-2002, 08:20 PM   #7
froggert
Member#: 768
OB, legacy, 911,
ram 1500, 1098s, m620
try throwing the link into babelfish.altavista.com
froggert is offline   Reply With Quote
Old 07-10-2002, 11:42 PM   #8
AKSubie
Member#: 6214
92 Corrado SLC
01.5 S4
Man, that's be sweet if cobb had the struts/springs for the BE's.
OK, so did that auction page help anyone out? I'm sorry but I'm not that technically inclined to know what we're looking for in the springs/strut fitment issue thing. Could anyone tell if they'd work or not?
AKSubie is offline   Reply With Quote
Old 07-11-2002, 12:04 AM   #9
tora
Member#: 5851
09 Forester XT
+ NA Miata
I'm pretty sure Whiteline makes springs for the BE. They have different rears for the BE and BH but the front is the same. I know for mine I had to use the RS perches. I have auto-x'ed twice on them with no problem. I know Don at PDM has them for both (cause that's who I got them from). The rears for the wagon and sedan seemed different only in that they (the sedan) is a thinner spring. The actual diameter seems the same but they are lighter and the actual thickness of the material seems a touch thinner.
Anyways, for anyone who really wants springs I wouldn't be afraid to use RS perch and top mounts. I have had no problems.
tora is offline   Reply With Quote
Old 07-11-2002, 12:14 AM   #10
etam
Member#: 439
www
etam is offline   Reply With Quote
Old 07-11-2002, 01:55 AM   #11
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
The bottom line here is that someone has to try the JDM stuff in order to see if it works first-hand. Has anybody EVER tried it? Why would JDM coilovers work but JDM struts wouldn't? That makes no sense to me.
The link that anotherB4 put up has a complete used set of JDM B4 Bilsteins (with springs) for $336 (so far). That's less than most crappy USDM struts.
If someone has enough guts to try, I can help get stuff off the Yahoo auctions, and I'll do it without adding anything to the top for myself.
If nobody ever tries it, then you will all forever be driving around with 3" tire gaps.
monovich is offline   Reply With Quote
Old 07-11-2002, 12:10 PM   #12
AKSubie
Member#: 6214
92 Corrado SLC
01.5 S4
Well, I'd be willing to be a guinea pig for the B4 struts. Where do I sign?
Trying to get more camber up front.. Somboa Brakes, Steering & Suspension 1 04-15-2008 03:16 PM
so i tried to pull my house up a hill... FriedIceCream Texas Impreza Club Forum -- TXIC 4 07-15-2006 11:43 AM
Ground Controls with AGX's and Ride Height 1331 Brakes, Steering & Suspension 7 05-31-2004 12:51 PM
OT! HELP! - trying to hook a friend up with a wrx vhalin Off-Topic 36 02-27-2004 03:02 AM
Anything special to do when jacking up car for uppipe that won't crush oil pan? waitandbleed92 Factory 2.0L Turbo Powertrain 4 04-14-2003 12:40 AM
Message Board Statistics All times are GMT -4. The time now is 09:01 AM.
