Old 11-20-2010, 02:52 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default EQ - 2010 STI Cobb Stage 1 vs. Custom Tune
This is a 2010 STI that came in yesterday for a custom tune. The car was bone stock running the Cobb OTS Stage 1 91 Octane map, so we decided to do a couple baseline pulls before proceeding. This is the black line on the chart. The Cobb Map was putting down 215whp/247ft-lbs. This is a bit lower than expected, but everything seemed to be running safely.
After the baseline pulls, we installed an AEM CAI and GrimmSpeed 3-port EBCS and proceeded with the custom tune. The customer wanted the tune to be very safe and didn't care much about the peak numbers. After the tune, we ended up with 239whp/261ft-lbs keeping things very conservative. I could have easily gotten another 4-5whp out of it, but that's not what the customer was after, so we stopped there. You can see in the graph that at 4k RPM, we have a healthy 30ft-lbs gained and above 6k RPM, we have a about a 25whp gain. These are very healthy gains for a relatively low reading dyno and conservative tune. The car is also much smoother and more responsive all around.
Here's the info and chart:
Event: Custom Dyno Tune
Dyno: Dynocom DC-Tuner AWD Chassis Dyno
Ambient Temp: 65 Degrees Fahrenheit
Elevation: ~100ft above sea level
Car: 2010 Subaru WRX STI
Tuner: Ed @ Equilibrium Tuning
Peak HP at RPM: 239whp @ 5950RPM
Peak Torque at RPM: 261-lbs @ 4250RPM
Target Boost: 18psi Tapering to 15psi
Fuel: California 91 Octane
Stock HP for this dyno: 06 STI @ 215whp
Engine/Power Modifications:
AEM CAI Intake
GrimmSpeed EBCS
EQ Custom Tune using Cobb AP V2
*** Standard Dyno Chart Disclaimer ***
This dyno reads low and should be compared to the lower reading mustang and DynoDynamics dynos with no correction factors. Here are some proven numbers and trap speeds for reference:
Stock 02-05 WRX - 155whp
Stock 04-06 STI - 215whp
265-275whp - 107-108mph traps
300-310whp - 112-113mph traps
325-335whp - 115-116mph traps
350-360whp - 120-121mph traps
Thanks
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 11-20-2010, 04:36 PM   #2
Skers
Member#: 258917
2011 WRX
Its always nice to get the baseline read for comparison. Nice gains and thanks for sharing.
Skers is offline   Reply With Quote
Old 11-20-2010, 04:40 PM   #3
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Thanks. We always try to do a baseline when possible.
-- Ed
Old 11-20-2010, 06:54 PM   #4
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Thanks for posting. Nice tune. OTS Stage 1 numbers look a little low, but you made some good gains with the tune.
Just curious, what does a stock 09+ WRX read on your dyno?
xluben is offline   Reply With Quote
Old 11-20-2010, 07:42 PM   #5
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I actually haven't had a stock 09+ WRX on this chassis dyno yet, but on my road dyno software I usually see about 210-215whp out of the 09+ WRX. This chassis dyno reads VERY close to my road dyno software, so I imagine the numbers would be similar. Interesting note, I usually see 08+ STI's put down about 200-205whp bone stock which is about 10-15whp down from the 04-07 STI's.
-- Ed
Old 11-20-2010, 07:55 PM   #6
KpT KiM
Member#: 242422
-- Ed
That is funny. Any thoughts as to why?
KpT KiM is offline   Reply With Quote
Old 11-20-2010, 07:56 PM   #7
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Also, these pulls were done in 3rd gear. I did tuning pulls in 4th which brought boost and torque in much sooner, but I figured it would only be fair to compare with the Cobb map in the same gear.
-- Ed
Old 11-20-2010, 07:59 PM   #8
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Not too sure why honestly. I imagine its in the stock tune as they usually end up making similar power after tuning.
-- Ed
Old 11-23-2010, 06:39 PM   #9
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
FWIW, we had a bone stock 2011 WRX at our dyno day on Sunday and it put down 214whp.
Thanks
-- Ed
aftermarket skid plate for 2008-2010 wrx?? kodirat7 Interior & Exterior Modification 9 12-29-2010 02:09 PM
Photos from the 2010 LA Auto Show edkwon Non-Subaru News & Rumors 28 11-23-2010 12:29 PM
Ford F-150 With Torture-Tested EcoBoost Engine Finishes 2010 Tecate SCORE AVANTI R5 Non-Subaru News & Rumors 13 11-22-2010 09:27 AM
Custom Exhasut mesagsxbkr Normally Aspirated Powertrain 5 11-21-2010 10:59 AM
Wagon Geometry, sedan geometry Vs. Wheels Size seedstyl1 Newbies & FAQs 0 11-20-2010 01:16 PM
