Old 11-21-2010, 04:19 AM   #1
DutchOven
Member#: 220629
2010 White WRX Hatch
2015 White WRX Limited
Default Rear wheel stud install on an 2010 WRX..
I searched and couldn't find anything on an 08+. However, I did find this:
http://www.mfavp.com/wheelstud/index.htm
which is for 02-07's i believe.
Are they any different from an 08? One of my rear studs got stripped and need to replace it.
Thanks for any input!
DutchOven is offline   Reply With Quote
Old 11-21-2010, 10:57 AM   #2
DrDanimalSize
Member#: 254097
2010 2014 Impreza
If you're replacing a stripped stud that looks like the way I'd do it. If you are reusing the stud thread a lugnut on it first so that the nut sticks out 1-2mm farther than the stud and hammer the nut instead
DrDanimalSize is offline   Reply With Quote
Old 11-21-2010, 04:26 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
if you dont know what you are doing
you MAY destroy $omething expen$ive....loke the ABS tone ring
Old 11-22-2010, 02:30 AM   #4
sc00by4life
Member#: 97135
THIS.
If the tone ring even gets a slight nick in it, its toast. I've replaced several studs with that method, and all I can say is go slow and be very careful.
Old 11-22-2010, 03:09 AM   #5
DutchOven
Member#: 220629
Looks like my car is different. I didn't see an ABS tone ring. Pics:
and the culprit of the initial problem:
I just hammered it out and it was fine. Thanks for all your help/input!
Anyone having luck with aftermarket springs on stock struts on an 08+ WRX? Kal-El in SLO Newbies & FAQs 11 09-13-2010 12:46 PM
08+ Legacy SPT Intake on an 08+ WRX?? DreadScourge Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-13-2009 11:59 PM
anyone install extended studs on an 08 sti? Damon Tire & Wheel 1 12-31-2008 06:16 PM
05-07 STi BBS wheels fit on an 08 STi? criz Tire & Wheel 9 10-31-2008 10:23 PM
Will an 03 WRX rear diff work on an 02 WRX? zroom tsuchiya Transmission (AT/MT) & Driveline 3 03-17-2004 05:41 PM
