Welcome to the North American Subaru Impreza Owners Club Thursday July 10, 2014
Old 11-22-2010, 05:45 PM   #1
bwilliams373
Member#: 210785
Default Cheap and Skinny... STI Snow Wheels!!!
Found this fitment on another subaru forum so I thought it would be a good idea to share with everyone here. I was shopping for a cheap set of snow wheels for my 08 STI. Everyone knows the skinnier the better for snow/winter traction, but with the big brakes on the STI's it's hard enough just to find something that fits.
Solution: 07+ Honda CRV steelies!
They are 17x6.5 and are supposed to clear the big brakes. You can buy them new if you need them now, and they are steelies so if you come across a used set they should be dirt cheap! I picked up some 215-55-17 Blizzak tires this morning and am picking up the wheels tonight. I'll be painting mine black tonight and mounting them tomorrow so I'll post pics of them on my car when I get them installed. Here is a pic for now of what they look like for reference.
bwilliams373 is offline   Reply With Quote
Old 11-22-2010, 05:58 PM   #2
JamesBernard
Member#: 180038
IB You dont even
own a subaru!
so they're 5x114.3? all 05+ STi could run these for cheappp
JamesBernard is offline   Reply With Quote
Old 11-22-2010, 06:03 PM   #3
bwilliams373
Member#: 210785
Yes they are 5x114.3
Old 11-22-2010, 06:04 PM   #4
AWD>FWD
Member#: 107027
2007 SWP WRX STi
w/MPS-built 2.34l
Yeah, I saw this on IWSTi... good repost! (being serious). Some CRV owners will let these things go for for like $50 for 4.
AWD>FWD is offline   Reply With Quote
Old 11-22-2010, 06:10 PM   #5
bwilliams373
Member#: 210785
FYI: I just called the local honda dealer and they are actually like $220 each new so the used market is definitely gonna be the way to go!
Old 11-22-2010, 07:04 PM   #6
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
great find, i'll stick with my 05-07 bbs wheels
post up pics asap!
Old 11-22-2010, 07:30 PM   #7
dantastic
Member#: 66815
2005 WRX Wag -SOLD:(
CGM STX #125
FYI, OEM Honda wheels use ball seat lug nuts. Technically, you should get new lug nuts (ball seat, M12x1.25) to use with those wheels.
dantastic is offline   Reply With Quote
Old 11-22-2010, 07:48 PM   #8
Cartmans 03_Wagon
Member#: 222833
. Guess who's
back. Back again.
Stole these pics from a classified ad, they just sold.
BTW he ended up selling the wheels for $100 so don't go buy them at the dealer.
Cartmans 03_Wagon is offline   Reply With Quote
Old 11-23-2010, 01:05 AM   #9
Cloneboy17
Member#: 244834
2006 STI
Wow those actually look really good painted...... i just spent 600 for winter wheels.... DOH!!!
Cloneboy17 is offline   Reply With Quote
Old 11-23-2010, 01:14 AM   #10
DrDanimalSize
Member#: 254097
2010 WRX Hatch
More pics!!!!
Is the center bore the same or do you need centering rings?
DrDanimalSize is offline   Reply With Quote
Old 11-23-2010, 11:15 AM   #11
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
While I agree for the price they are pretty good painted. But I think the stock wheels painted look better and then spend your money on summer rims and tires. Yes it is more expensive, but I think nicer as well.
Some people like steelies for winter, but with stock wheels so cheap, who needs steelies.
As far as skinny, never had a problem with stock 205 in the snow.
Ernest is offline   Reply With Quote
Old 11-23-2010, 11:08 PM   #12
bwilliams373
Member#: 210785
Actually the stock tire size for a 08+ STI is 245-40-18... and on a 05-07 STI is 225-45-17... any less width on either stock wheel set would leave the rims completely exposed! You are a little off base with 2004 wrx reference in a STI fitment thread.
Anyhow... here is a pic of what they looked like after a few coats of semiflat black and clear... I put them on the car tonight but too dark for pics. I do think it looks good tho, will put pics up tomorrow.
Old 11-23-2010, 11:17 PM   #13
bwilliams373
Member#: 210785
Originally Posted by DrDanimalSize View Post
More pics!!!!
You will end up with a gap because these have a slightly larger center bore. Although the rings may help, they are not completely necessary. As long as you tighten the lugnuts very slowly to be sure the wheel centers itself before torque you should be fine. You can clearly see for yourself after install if they look centered or not. Because of the fresh paint I also drove a few miles on them and retorqued just to be safe. Also, these are factory steelies made for a different car so they do not have the 1/8" lip inside the center bore like aftermarket wheels used to hold the hub adapter ring in place during install so I'm not sure what sort of spacer you would use anyways???
Old 11-24-2010, 10:40 AM   #14
Ric WRX
Member#: 187009
2008 WRX Sedan Prem
VF52, CAMTuned, Stage 2
Anyone know what steelies would fit an 04 STI in 17"?
Ric WRX is offline   Reply With Quote
Old 11-24-2010, 11:07 AM   #15
chickencherryaki
Member#: 240580
that's not correct. i am running 215/50/17 snows on the stock 17x8" bbs (05 sti). the tires fill out the wheels just as much as the stockers. and no they aren't over stretched either.
http://www.rimsntires.com/rt_specs.jsp
chickencherryaki is offline   Reply With Quote
Old 11-24-2010, 01:07 PM   #16
bwilliams373
Member#: 210785
^^^Wow... really???
Obviously going down 10mm and adding a bit more sidewall is not going to make much difference. I was simply making the point that stretching a skinny tire on a wide wheel for a winter setup is just a dumb idea. It seems that is not what you did so it isnt really an example of what I was referring to. This is not a fitment thread BTW, it is simply to let other STI owners know there is another option besides aftermarket wheels for a winter setup.
Here is a pic of what these steelies look like on my car...
Old 11-24-2010, 03:37 PM   #17
DrDanimalSize
Member#: 254097
2010 WRX Hatch
That looks awesome! If I had an STi I would totally rock those for winter, and I'd even put the stock Honda center caps back on
Old 11-24-2010, 07:06 PM   #18
chickencherryaki
Member#: 240580
^^^Wow... really???
Yep np. And I didn't mean to hijack your thread. I just wanted to correct you so that others are not mislead by incorrect information. I agree with you 100% about stretching tires and trust me I searched for months trying to find some cheap skinny wheels (17x7 and less than 150 per wheel). I even looked at the crv wheels but I decided against it. They look good on your car though - you did a nice job painting them.
Old 11-24-2010, 07:41 PM   #19
nhat
#Belieber
Member#: 140163
03 STi
hellaflunctional
what's the offset on them? they're ugly as all get out but prettier than a set of steelies
Old 11-24-2010, 07:51 PM   #20
Ernest
Member#: 45076
Point taken, but do you really think a difference from 225 to 215 will make that much of a difference. Maybe the 245, but the compound and tread of the tire will be more important than 1cm.
They look nice, and for the price you cannot beat it. But I would rather have nicer summer rims and keep the stocks for winters.
Old 11-25-2010, 12:53 AM   #21
HClRain
Member#: 222426
2006 Subaru WRX STi
SGM
how'd you paint them? I wanted to do a flat black but i read that you shouldn't clear coat them. If you do they wont be a flat black, and they will be more prone to chipping. Any suggestions?
HClRain is offline   Reply With Quote
Old 11-25-2010, 06:24 AM   #22
ChronicPoe
Member#: 185255
2007 STI
i like, I think they are sexy.
ChronicPoe is offline   Reply With Quote
Old 11-25-2010, 06:31 AM   #23
ChronicPoe
Member#: 185255
2007 STI
if he has the upgraded 08+ bbs, they are nice summer wheels.
Old 11-25-2010, 09:36 PM   #24
bwilliams373
Member#: 210785
I sanded them down with 100 grit paper.
Wiped them thuroughly with rubbing alcahol to clear any dust/dirt from surface.
Painted with semiflat black 2 coats.
Used 2 coats of clear that is made for wheels.
After they completely dried the clear didnt seem to change the semiflat look at all.
Im not really sure if putting clear on makes them prone to chipping, the theory is actually to make them a bit more durable. I used a rattle can clear that is specifically made for wheels.
Old 11-26-2010, 11:54 AM   #25
HClRain
Member#: 222426
2006 Subaru WRX STi
SGM
Oops meant NOT clearing them would make them more prone to chipping. Id like to clear them without them getting too glossy. Is there a clear paint that can do that?
WTB : 05 Sti Shift Knob/ And a 2005 STI Cluster/ And 2005 STI steering wheel airbag chuckmn8 Private 'Wanted' Classifieds 3 08-26-2010 01:02 PM
05-07 STI Snow wheel options??? bwilliams373 North West Impreza Club Forum -- NWIC 4 01-05-2010 02:27 AM
WTB: STi Up pipe and 04 STi bbs wheels atc5 Private 'Wanted' Classifieds 0 08-29-2007 07:10 PM
SPT Pinks for way cheap. Also: 5x114 STi BBS wheel (1) Mach V Dan MAIC Vendor Classifieds 17 04-30-2007 06:11 AM
WTB - STi Interior and 04 STi BBS Wheels!!! advanwrx NWIC Private Classifieds 7 07-23-2006 11:00 PM
