Old 11-22-2010, 06:23 PM   #1
The1SloR/T
Member#: 251879
1998 Neon R/T 178whp
2010 Wrx Sedan WRB
Default How do I reset the TPMS sensors?
2010 Wrx sedan.
I took my stock wheels off and put on some winter wheels.
Winter wheels ALSO have TPMS sensors in them
drove for a day and the light didnt come on, it is now on and will not go off.
Stopped at a friend's shop and used a Tech300 http://www.bartecusa.com/wheelrite_tech300_plus.htm
however, he thinks he reset them but all I think is he read the tpms.
How to I put the car into learn mode to reset these tpms sensors?
And can it be done with this tool?
Thanks
The1SloR/T is offline   Reply With Quote
Old 11-22-2010, 06:39 PM   #2
Baddmnkey
Member#: 211812
09 WRX
SSM, mostly stock!
usually needs to be reset at the dealership(I think Tirerack sells a tpms reset tool). I know its kind of a PITA when changing to summers/winter set up having to go to the dealership. they usually charge me $18.
Baddmnkey is offline   Reply With Quote
Old 11-22-2010, 06:47 PM   #3
The1SloR/T
Member#: 251879
2010 Wrx Sedan WRB
I would love to stay away from the dealership. how do pep boys and etc reset your tpms if you damage a wheel or replace them for new ones? Gotta be a way other then dealer
Old 11-22-2010, 07:07 PM   #4
ki4syr
Member#: 247574
2013 PBP GV STI
2008 Impreza 2.5i
The sensors on Subaru's have to be flashed into the TPMS module. If your friend had a Tech400Plus, he'd be able to do it. The Tech300 will only query the sensors, the Tech400Plus will do this as well as plug into your Datalink and reprogram the TPMS module.
As of current, only the Tech400Plus and that Ateq Quickest will flash Subaru's. Snap-On, OTC, etc.... do not even support Subaru's or Suzuki's TPMS.
ki4syr is offline   Reply With Quote
Old 11-22-2010, 07:45 PM   #5
The1SloR/T
Member#: 251879
2010 Wrx Sedan WRB
well craptastic, my other thought was to grab the OTC Genesis and see what I could do with that in conjuction with the tech300..
looks like Im gonna have to get a quickset or go to the dealer and see if they'll do it. ( they'll probably want me to drop the car off for a day or make me wait hours to do the reset..)
also, I cant seem to find the ATEQ quickset for sale anywhere on the net, including tirerack for some reason
Old 11-22-2010, 08:17 PM   #6
ki4syr
Member#: 247574
2013 PBP GV STI
2008 Impreza 2.5i
Well, looks like your right. Might be a sign of the quality of them things.
From the Snap-On perspective, their current 10.4 diagnostic software package does not support TPMS on Subaru nor Suzuki. My rep. can't explain either (knows little about TPMS anyways). I've emailed OTC as well and they couldn't give me a time frame when it would be available either.
How do you Reset the ECU BlueByYou Newbies & FAQs 16 03-28-2003 02:01 PM
How do you reset the ECU to get rid of a CEL? Jasno999 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-19-2002 01:54 PM
How do you reset the ECU khai yang Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-22-2001 10:21 PM
how do i reset the ecu bruno Tri-State Area Forum 2 04-21-2001 10:35 AM
How do I reset the ECU? ImprezaRS2000 Technical Forum Archive 10 07-31-2000 11:52 PM
