Old 07-02-2002, 10:54 AM   #1
Sparks
Member#: 16495
2013 BRZ
Sterling Silver Metallic
Default Help with CEL P0457 EVAP
Well I changed my inlet pipe (Samco) over the weekend and now the CEL won't clear.
I stopped by AutoZone to see what the code was and they said P0457. I did some checking and searching and can find nothing about that code but I did find P0456 - Evaporative emission control system malfunction (pretty close to what AutoZone said).
I checked all my vac lines to make sure they're hooked up.
Anyone had this code or can offer any trouble shooting help?
Thanks-in-advance,
Shaun
Sparks is offline   Reply With Quote
Old 07-02-2002, 11:23 AM   #2
kenshiro
Member#: 15917
2002 teh FastAR rex
Black like my soul
Tighten your gas cap dude.
P0457 Evaporative emission control system leak detected (fuel filler cap loose/off)
http://66.24.68.150/wrx/2002troublecodes.txt
kenshiro is offline   Reply With Quote
Old 07-02-2002, 11:42 AM   #3
Sparks
Member#: 16495
2013 BRZ
THAT is a nice link to have. I spent all morning looking for that exact reference.
I'm off to re-seat my gas cap.
Old 07-03-2002, 09:54 PM   #4
Sparks
Member#: 16495
2013 BRZ
Filled up the tank and made sure the gas cap is on.
The CEL has came back.
What should I look for?
Old 07-03-2002, 10:48 PM   #5
bingo
Member#: 13665
2004 sti
rally blue
Is it back? or never went off. If it never went off you can either re-set (remove battery ground and pump brake pedal) or leave it alone and it will go off after a while.
If it went away and then came back, I am stumped.
bingo is offline   Reply With Quote
Old 07-04-2002, 09:29 AM   #6
Sparks
Member#: 16495
2013 BRZ
The code keeps coming back after clearing it.
Anyone have service manual info on the EVAP system.
I'm wondering what components are in the loop (PCV, head vents, gas cap, ect..)
Old 07-04-2002, 09:45 AM   #7
Cocoa Beach Bum
Member#: 17355
It's possible, according to this memo, that this trouble code is spurious and the problem is within the ECU.
Cocoa Beach Bum is offline   Reply With Quote
Old 07-15-2002, 09:00 AM   #8
kenshiro
Member#: 15917
2002 teh FastAR rex
Black like my soul
Take it to the dealer.
Old 07-15-2002, 10:35 AM   #9
Sparks
Member#: 16495
2013 BRZ
I fixed it.
Found a vac line off under the intake. Right next to the inlet pipe, small blue connector.
****need Help With Cel Codes-please Help************** stito Subaru Conversions 4 07-29-2007 04:55 AM
Need help with Cel code. WRX Joe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-16-2002 10:40 PM
need help with CEL slammedWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-06-2002 12:16 AM
Help with CEL! WRXavier Service & Maintenance 3 06-26-2002 08:24 PM
Need help with CELs BluJay Tri-State Area Forum 3 11-03-2001 08:31 PM
