Old 11-26-2010, 07:29 PM   #51
Yint
Member#: 199751
2002 Impreza TSX
Savanna Green
Originally Posted by ThaPuertoRican15 View Post
looking at the car from anywhere besides the front, it looks like just another bug eye, and even at times you cant see the FMIC. its fast, but it doesnt really look it...
and therefore is what I consider a proper sleeper.
Yint is offline   Reply With Quote
Old 11-26-2010, 07:47 PM   #52
TMSmith
Member#: 216496
2009 Cobalt
07 Ninja 250R
Originally Posted by Kadavr View Post
So the link you posted shows a car with a large exhaust, flashy wheels, a cage, and looking at the specs it has a TiAL 50mm BOV & 4mm wastegate.
very sleeper...
Those wheels are the stock eclipse wheels. And you can barely notice the cage when the top is up.
TMSmith is offline   Reply With Quote
Old 11-26-2010, 08:21 PM   #53
cubuff
Member#: 38345
2004 WRB WRX
I like to think of mine as a bit of a sleeper. The 4" exhaust can give it away if you know what youre looking at. But it has stock wrx sideskirts, wrx wing etc...
It makes good power for 28psi.
cubuff is offline   Reply With Quote
Old 11-26-2010, 08:32 PM   #54
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
^holy ****!!!!!
blakkboxer is offline   Reply With Quote
Old 11-26-2010, 08:50 PM   #55
yfzracr89
Member#: 225601
2009 WRX
details now!!
yfzracr89 is offline   Reply With Quote
Old 11-26-2010, 08:56 PM   #56
wrxuk
Member#: 172778
2003 sti spec c
12.47 at 108mph
We have a winner.
wrxuk is offline   Reply With Quote
Old 11-26-2010, 09:04 PM   #57
801_STi
Member#: 200756
07 yellow clearbra
swp sti "Pearl"
thats what i consider a sleeper^^^
i dont care if it has rims exhaust or a blow off valve. any car can have all that. but when something that looks like that^^ average enough car daily driven that has 600 wheel??? gees.......
anything that doesnt look like a full out race car and runs under 12s... sleeper.
801_STi is offline   Reply With Quote
Old 11-26-2010, 09:25 PM   #58
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
cubuff have any street or dyno vids?
Old 11-26-2010, 10:05 PM   #59
cubuff
Member#: 38345
2004 WRB WRX
There are a couple of videos floating around. No street videos though. The thing I like about it is that it looks like any other wrx with rotas.
The car has a built ej207 with a whole bunch of supporting mods. The car can make another 100whp when I go back to the dyno and I also have a direct port nitrous system that can be used to help improve the curve and spool the turbo fast enough. Its plenty fast without no2 but with the spray it will be absolutely scary.
Here is a dyno run and another of the in car tac. None of these runs were at full power.
fixed.
Old 11-26-2010, 10:25 PM   #60
ben_art
Member#: 172635
2003 WRX Wagon
do you have a link to your engine build or a mod list?! 9k redline!!!!!!! Geeze!
ben_art is offline   Reply With Quote
Old 11-26-2010, 10:33 PM   #61
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
9k redline!
engine mod list now
is that ptp turbo blanket, how ya like it?
Old 11-26-2010, 10:39 PM   #62
CWLTT
Member#: 239283
2016 CWP STI
VF 2002 WRX (old)
Honestly it is hard for a subie to be considered a sleeper lol. Then on top of that the subie brand has a kind of respect already. Plus even when you just put a simple exhaust on our _4, it sounds hella rumbly with a pinch of mean to it. Idk it is hard to pass off as sleeper, IMO lolz...
CWLTT is offline   Reply With Quote
Old 11-26-2010, 10:43 PM   #63
CUwallaby
Member#: 255679
2007 Impreza wagon
Originally Posted by cubuff View Post
*snip
*snip
693 hp isn't scary enough?
CUwallaby is offline   Reply With Quote
Old 11-27-2010, 12:13 AM   #64
jcovey2.5
Member#: 126195
05 CGM WRXTi
Wagon , 95 Red SVX L
05 WRX wagon work in progress. no finished picks yet but it will be done mid December.
STi fog light stickers are coming off and the front mount will be painted black too.
I cant wait till its done!!!
-full STi swap
-built motor
-SZ55
-07 6 speed
-and many more mods...
Here is my last car. 05 RS that had the same STi motor and trans in it. I wrecked it unfortunately...
jcovey2.5 is offline   Reply With Quote
Old 11-27-2010, 03:32 AM   #65
cubuff
Member#: 38345
2004 WRB WRX
9k redline!
engine mod list now
The modifications are as follows. Yes its a ptp blanket. It is cracking a little bit, which is probably somewhat normal. Its very minor and im sure the benefits of it outweight that.
Engine block/heads:
ej207 block
Custom Wiseco pistons 8.5:1 compression deep valve reliefs
Custom Wiseco wrist pins
Tomei rods
ACL bearings with Mains pinned
spec c crank
Machine work, balanced/blueprinted/line honed/bored and honed with torque plate/ polished crank etc.
block pinning
Blueprinted and shimmed 11mm oil pump 100+psi cold start oil pressure/ 95psi at 9000rpm/ 45psi at idle.
Moroso steel oil pan with internal baffling and moroso oil pickup
version 7 big port heads
cosworth 278/274 avcs cams (AVCS not functional)
Oversized custom manley valves
Supertech valvetrain, dual springs, titanium retainers
port work, valve job, new guides and seats
cometic head gasket
ARP 12mm head studs
Heads assembled with brand new buckets and all assembly hardware within the block and heads was brand new at time of assembly, block bolts, cam bolts etc...
Gates timing belt
Turbo/Exhaust/intercooler
Twinscroll uppipe
Twin tial vband 38mm gates with 18psi spring setups in each
APS header
Airwerks/borgwarner s300sx turbo. This is larger than a 4088r and fits somewhere between it and a 42r. Capable of 45+psi
4" downpipe
full 4" exhaust
Precision turbo 900hp intercooler
Reverse manifold piping, custom 2.5" hotside 3" charge piping, custom painted. Tbolt clamps,
tial bov
fuel/nitrous
2150cc injectors (FIC's rendition of the magical ID2000's. The same EXACT injector as the ID2000)
2ltr surge tank fed by intake walbro
fuelab fuel pump with built in speed controller 1200hp pump
-8 hardline feed to regulator -8 an line to rails -6 hardline return to tank
Aeromotive regulator and fuel pressure gauge
Zex direct port nitrous wet kit. 10lb bottle, blow down tube mounted in trunk
driveline:
front range aluminum one piece driveshaft
STi 04 6 speed swap complete with Brembos f&r and r180 rear diff
ACT 6 puck clutch
stock brand new fly wheel
dccd controller
Old 11-27-2010, 03:46 AM   #66
thatkhmer
Member#: 217500
2009 SWP Wrx
2010 WW Evo X
60-120 in like 4 secs? thats bad ass
thatkhmer is offline   Reply With Quote
Old 11-27-2010, 03:59 AM   #67
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
such a beautiful list mate!
Old 11-27-2010, 08:32 AM   #68
25rstautoxr
Member#: 43958
99 RS Asphalt-01RS
Dirt-01 Forester swapped
Not so much a hardcore sleeper compared to most of the cars in this thread.
13.20 @ 104 mph
03 WRX swap, VF22 turbo, Legacy gt gears.
Makes for a fun daily driver thats not getting rev'd at when stopped at evey light.
25rstautoxr is offline   Reply With Quote
Old 11-27-2010, 08:53 AM   #69
nolanator
Member#: 197677
62 Chevy Nova
800+ hp/tq on 91 octane
uhm. i dont have a pic right now(im in afghanistan currently), but my STi swapped bugeye wagon is completely stock looking minus a sedan front end conversion. (stock 16" wheels, little scoop, OEM headlights, and all)
nolanator is offline   Reply With Quote
Old 11-27-2010, 09:23 AM   #70
RYNOMOTO
Member#: 197147
2004 Subaru Forester
Java Black Pearl
WINNER!!!!!
ULTIMATE SLEEPER = 95% stock appearing WRX with more than 3X's the stock power at the wheels!!!
Awesome looking car and that engine is a beauty!!!
This is what happens when a car owner knows what he is doing or is willing to find out the right answer and sort through a bunch of e-knowledge, along with a good tuner and good engine build.
If missing any of these three pieces of the fast car puzzle, don't even try.....
RYNOMOTO is offline   Reply With Quote
Old 11-27-2010, 10:44 AM   #71
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
Originally Posted by ShugSTi View Post
Looks Dept. WRX Skirts, wingless, Limited Front Lip, Crawford Performance Cat-back / e85 @ 24psi - 447whp & 417wtq
I'd like a little info on this set up.
Rotated w/top mount set up.
I likey.
Team Scream is offline   Reply With Quote
Old 11-27-2010, 02:56 PM   #72
eph
Member#: 83120
1992 SS EJ225T
cj91legss
Default My 1992 Legacy Sport
Name's CJ and here's my 92 Legacy sport.
Needs painted but this is what it looks like now, and paint is definately last on my list.
Cant remember when i finished the swap exactly but i know i have about 10k on it now and im into it about 2-3 grand total
Ayyways all the work done by me
Mods list
2.2T Block with 20H Twin turbo Heads
greddy & cx racing fmic piping
VF39
jdm 440s
Vikash's Dirt Cheap FCD (Made by me)
02-03 wrx suspension
17x8 MSR wheels
AEM Tru Boost
Cometic Head Gaskets
3" Turbo Back
Heat Wrapped up pipe
And to come is wideband, & Greddy E Manage Ultimate(Currently being a paperweight), coilovers, larger turbo (Not happy with the vf39) and some other stuff...
eph is offline   Reply With Quote
Old 11-27-2010, 03:07 PM   #73
GDB FAN
Member#: 105814
Originally Posted by 25rstautoxr View Post
http://i50.photobucket.com/albums/f325/Smitch260/DSC_0670.jpg
http://i50.photobucket.com/albums/f3...0/100_3481.jpg
http://i50.photobucket.com/albums/f3...0/IMG_9244.jpg
13.20 @ 104 mph
So freakin sweet.
GDB FAN is offline   Reply With Quote
Old 11-27-2010, 06:39 PM   #74
ShugSTi
Member#: 187128
Is this at elevation? Thats even more incredible lol!
ShugSTi is offline   Reply With Quote
Old 11-27-2010, 06:43 PM   #75
ShugSTi
Member#: 187128
I likey.
What would you like to know? As of late; the motor is getting refreshed and I'm picking it up next week! I will have a new tune on it in a couple of weeks lol...
FS : Any Scooby Drivers live near Knotts? gwright1091 SCIC Private Classifieds 1 11-23-2010 12:56 PM
wrx swap sleeper or sleeper n/a with enigne work??? shade1569 Normally Aspirated Powertrain 45 01-07-2010 03:49 PM
European Car's Top 10 Sleepers // Top 10 American Sleepers snvin Off-Topic 42 03-20-2008 07:26 PM
Sleepers and definitely-not-sleepers slippers2k Off-Topic 32 10-08-2003 04:02 PM
