Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Old 11-27-2010, 06:53 PM   #76
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
either the dyno reads not right or that really is your power band.
Still not the final tune??? need to try and bring up the lower end because most cars that are 500whp like say a Mustang/Camaro/Vette will jump you quickly and will stay ahead quite a bit.
Originally Posted by cubuff View Post
FuJi K is offline   Reply With Quote
Old 11-27-2010, 08:34 PM   #77
punk kid
Member#: 195194
1999 2.5rs
blue, ej22t ftw
I like to think of mine as a bit of a sleeper. The 4" exhaust can give it away if you know what youre looking at. But it has stock wrx sideskirts, wrx wing etc...
It makes good power for 28psi.
being that i live in denver i want to see this car in person
punk kid is offline   Reply With Quote
Old 11-27-2010, 08:52 PM   #78
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
Originally Posted by punk kid View Post
being that i live in denver i want to ride shotgun with this person
fixed ahah
blakkboxer is offline   Reply With Quote
Old 11-27-2010, 09:39 PM   #79
RYNOMOTO
Member#: 197147
2004 Subaru Forester
Java Black Pearl
From reading other threads, that is the best tune he can get at this time because of it blowing out the spark at high boost and richer fuel numbers.... HKS ignition booster is not enough..... he can't enrichen the fuel mixture to make more power and earlier without it blowing the spark out...
running STI coils and E85 puts a huge load on the ignition system..... when you consider that this was at 28psi and the target max goal was for over 35psi if he can get the ignition system to handle the fueling and boost loads....
this is another reason he is looking at one of the new Borg Warner turbos also, to get more powerband out of it....
Besides, I kinda like how it climbs 200+WHP per every 1,000 RPM above 6,000 RPM ...
And think of it like this, there are several 35R cars that don't spool well until 4,000 rpm and shift at 6,800-7,000 , so there is still only 2,800-3,000 rpm worth of powerband, just like this engine, it just comes in a little later....
Also, notice the Direct port N20 system....
It hasn't been used yet to help spool up the turbo sooner....
everyone knows that works well...
SLEDGEHAMMER!!!!!
I also like that rotated setup Shug!!
I may aim for something like that with a T67 and a cartech intercooler if I have room.... on a FXT..... For fun!
RYNOMOTO is offline   Reply With Quote
Old 11-27-2010, 10:27 PM   #80
Junior2JZ
Member#: 64908
10.8 XT+10.0@143 GR+
2x9.0@170mph GTRs
I forgot about my GC... That used to be pretty sleepy.
Pwrd by this
I ruined it though, the 10pt and parachute kinda give it away now
Junior2JZ is offline   Reply With Quote
Old 11-27-2010, 11:23 PM   #81
THE_SMURF
Member#: 260624
2007 Z06/ZX10R
Originally Posted by ShugSTi View Post
Looks Dept. WRX Skirts, wingless, Limited Front Lip, Crawford Performance Cat-back / e85 @ 24psi - 447whp & 417wtq
omg, i want this setup on my 2011 wrx sooooooooo bad
custom DP 550-600
custom up-pipe 200
PTE 5857 950
process west tmic 850
custom charge pipe and 2 couplers 250-300
custom 4 to 3" intake 250
would be sleeper as fukc, but being a wide body, wrbp and fully polished SSRs i couldnt be sleeper even if i never pulled it out of the garage.
Originally Posted by Junior2JZ View Post
Doesn't exactly look like a POS.. but it looks like your run of the mill Forester XT.. You wouldn't expect it to beat down slicked up classic muscle or run close to a modded new GTR.. Let alone run 11s
YouTube - Stock Engine Turbo Fastest forester QM
pure sex!!!!
THE_SMURF is offline   Reply With Quote
Old 11-27-2010, 11:33 PM   #82
Olson
Member#: 51277
1991 Galant VR4
Blk
Originally Posted by Kadavr View Post
So the link you posted shows a car with a large exhaust, flashy wheels, a cage, and looking at the specs it has a TiAL 50mm BOV & 4mm wastegate.
very sleeper...
You want a sleeper.
Here
I know its not a subi but you wanted to know what a real sleeper is there you go.
It chases down bolt on Evo's Sti's at Thunderhill then drives home
Olson is offline   Reply With Quote
Old 11-28-2010, 12:40 AM   #83
cubuff
Member#: 38345
2004 WRB WRX
Im pretty sure I could take a 500whp mustang/camaro/vette. I ran this car against a new z06 with a tune on the highway and pulled on him very easily once I got into boost. From 4th to 5th I put probably 3 cars on him before I let out. I wait for boost once. Thats is. Think about it this way with 22psi and bouncing off the rev limiter I went from 90mph in the 1/8th to 125mph in the 1/4. 35mph in the back half isnt too bad especially considering that I hit the rev limiter and fell out of boost briefly because of this. I ran such a slow time because I had a 2.5 60ft. Plus, it was my first time driving the car down the track and shifting like a granny. Track closed after my first run that day due to the rain.
cubuff is offline   Reply With Quote
Old 11-28-2010, 01:19 AM   #84
CPC
Member#: 123085
2006 WRX
Surprised this hasn't been posted... Also not a Subi, but defines a true sleeper (for those still struggling with the definition):
1160+hp, worn out bench seat etc
http://www.hotrod.com/featuredvehicl...w2w/index.html
Chris.
CPC is offline   Reply With Quote
Old 11-28-2010, 01:29 AM   #85
Lt. Shinysides
Member#: 265281
1999 2.5RS
World Rally Blue
Originally Posted by v7ps View Post
King of Sleepers, my boy DcMurdock!
'98 L wagon w/ full STi swap. Now making 470whp at EFI Logics mustang dyno.
God damn dude, this thing is dope. Kudos. Wagons/outbacks make the best sleepers around. Nobody ever sees it coming.
Lt. Shinysides is offline   Reply With Quote
Old 11-28-2010, 02:31 AM   #86
wrx21
Member#: 99851
2008 sti
aspen white
wrx21 is offline   Reply With Quote
Old 11-28-2010, 03:33 AM   #87
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Old 11-28-2010, 05:28 AM   #88
VladiWrX
Member#: 145658
On my 5th scoob
and lovin it
humongous turbo sticking out of hood = sleeper?
VladiWrX is offline   Reply With Quote
Old 11-28-2010, 07:50 AM   #89
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Best shot I have of how the car kind of looks like when its moving from the front:
And how it looks when moving from the back:
Sleeper look:
No STI badging anywhere (even inside)
Tinted windows
CF wingless trunk painted body colour
No front lip, no body modifications
Small exhaust tip, looks brown/not shiny (rarely washed)
Rims and brake calipers rarely washed (keeps it dirty, hard to see brembos)
Fully built motor
29 psi on pump gas + meth = 575whp
11.24 on street tires and 18" rims:
+lots of stories where people will think it's just another stage 2 sti.
alcoolaid is offline   Reply With Quote
Old 11-28-2010, 09:39 AM   #90
GVR4 420
Member#: 105450
2005 Forester XT
Originally Posted by Olson
You want a sleeper.
Here
Had the same gvr4, the best car I ever owned!!! Great pics
GVR4 420 is offline   Reply With Quote
Old 11-28-2010, 11:20 AM   #91
GoSloTurbo
Member#: 195743
08 wrx built ej25
lots of e85
"do you have a rollbar in this?"
"no"
"then your gonna have to slow down a bit"
love it!!
GoSloTurbo is offline   Reply With Quote
Old 11-28-2010, 02:38 PM   #92
ShugSTi
Member#: 187128
+1 for alcoolaid's Twinscroll w/ anti-lag = BMF!
ShugSTi is offline   Reply With Quote
Old 11-28-2010, 05:48 PM   #93
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
that's good. I hope you can get the issues solved!!!
I drove one of my friend's 600whp+ Precision 6262 EVO8 and waiting for the power was like... ekkkKKK. However when it actually swung into the RPMs at near 6000rpms, power came and off we went. That motor was built for 9000rpms as well on a 2.0L.
Good look!
Old 11-28-2010, 05:53 PM   #94
Jakubgt
Member#: 233051
2010 4dr WRX
+1 this is a GREAT sleeper
Jakubgt is offline   Reply With Quote
Old 11-28-2010, 06:03 PM   #95
ReubenH
Member#: 172522
1998 Legacy GTB Ltd.
lol...
ReubenH is offline   Reply With Quote
Old 11-28-2010, 06:04 PM   #96
edchuck
Member#: 265328
11 STI sedan stg2
that wagon looks awesome! sick
Originally Posted by jcovey2.5 View Post
05 WRX wagon work in progress. no finished picks yet but it will be done mid December.
STi fog light stickers are coming off and the front mount will be painted black too.
I cant wait till its done!!!
-full STi swap
-built motor
-SZ55
-07 6 speed
-and many more mods...
Here is my last car. 05 RS that had the same STi motor and trans in it. I wrecked it unfortunately...
edchuck is offline   Reply With Quote
Old 11-28-2010, 07:48 PM   #97
eph
Member#: 83120
1992 SS EJ225T
cj91legss
Originally Posted by Olson View Post
You want a sleeper.
Here
I love vr4s
eph is offline   Reply With Quote
Old 11-29-2010, 01:20 PM   #98
Doctor Murdock2
Top Scoob 016
Member#: 72981
1998 OBSTI
Thanks man, I didnt even see this thread. Here is a quick shot of the updated setup, not really much to look at. Put down about 470whp like said above, and runs like a champ. All the tracks have closed up here in Mass, but Ill be bringing it to the 1320 first thing in the spring.
Doctor Murdock2 is offline   Reply With Quote
Old 11-29-2010, 02:42 PM   #99
CarverSnell
Member#: 256218
2004 Impreza WRX
PSM | VF30 300whp
I have a couple sleepers...
Wait do I have the wrong Scoobys? God I'm cheesy
CarverSnell is offline   Reply With Quote
Old 11-29-2010, 10:13 PM   #100
eph
Member#: 83120
1992 SS EJ225T
cj91legss
Unhappy
The bottom scooby isnt sleeping :P
FS : Any Scooby Drivers live near Knotts? gwright1091 SCIC Private Classifieds 1 11-23-2010 12:56 PM
wrx swap sleeper or sleeper n/a with enigne work??? shade1569 Normally Aspirated Powertrain 45 01-07-2010 03:49 PM
European Car's Top 10 Sleepers // Top 10 American Sleepers snvin Off-Topic 42 03-20-2008 07:26 PM
Sleepers and definitely-not-sleepers slippers2k Off-Topic 32 10-08-2003 04:02 PM
