Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 11-24-2010, 02:15 AM   #1
CFM
Member#: 223538
05 WRX Wagon
Default '02 WRX Speedometer problem.
Hello Nasioc,
My friend is looking into a 02 Bugeye, he is concerned about the speedo problem. When ideling, the speedo is consantly at 20 MPH. But when the car gets turned off, it goes to zero. I'm not sure of what this is nor is he, or the owner... any help is appreciated!
CFM is offline   Reply With Quote
Old 11-24-2010, 12:10 PM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Run, don't walk, but run away from that car. It has wiring problems that the last owner probably caused and couldn't figure out.
Or possibly it has a bad speedometer sensor on the transmission. When driven does the speed change at all? Are there any CEL codes?
speedyHAM is offline   Reply With Quote
Old 11-24-2010, 01:36 PM   #3
CFM
Member#: 223538
05 WRX Wagon
Tranmission was previously replaced.... No CEL codes, and it's always consistantly 20 MPH faster than you're actually going.
Old 11-24-2010, 03:18 PM   #4
Haelan
Member#: 151045
2013 Subaru STI
CBP
The ECU reads voltage pulses from the VSS to determine actual speed. If you're getting pulses at idle--that is not a good thing. My guess is the problem resides inside the transmission.
Take the advice....walk away.
Haelan is offline   Reply With Quote
Old 11-25-2010, 01:30 AM   #5
CFM
Member#: 223538
05 WRX Wagon
Should he get the tranny inspected before? It has a one year warranty. He is still determined.
Old 11-25-2010, 12:57 PM   #6
Haelan
Member#: 151045
2013 Subaru STI
CBP
Tell your friend that his stupidity amazes me.
Old 11-25-2010, 01:26 PM   #7
CFM
Member#: 223538
05 WRX Wagon
Hahaha!! Yes, he is determined due to the fact its a WRX with only 72k for 5,500......
Old 11-25-2010, 01:30 PM   #8
Haelan
Member#: 151045
2013 Subaru STI
CBP
That price tag will balloon another 2 grand when the tranny dies after the warranty expires.
Old 11-25-2010, 06:28 PM   #9
CFM
Member#: 223538
05 WRX Wagon
Agreed. Thanks for the help sir.
Old 11-26-2010, 03:14 PM   #10
jmart2332
Member#: 265142
2002 Impreza WRX
I'm the guy set on purchasing the 2002 WRX with the speedometer issue. The speed reads at 20mph on idle and is consistantly 20 over.The transmission was rebuilt with a 1 year warranty, all reciepts are accountted for. No CELS. No electrical mods other than a turbo timer.
Could the speedometer error be a mis calibration?
Could it be a faulty wheel speed sensor?
One theory I have is that when the transmission was installed the VSS (Vehicle Speed Sensor) was damaged or not securely connected.
Do you guys have any other theories?
jmart2332 is offline   Reply With Quote
Old 11-28-2010, 05:36 AM   #11
cabikejumper
Member#: 226604
2000 Mustang GT
Tell your friends to buy my 02 WRX. 115k miles. For 6900...
Got a 2005 WRX speedo and it's spot on
cabikejumper is offline   Reply With Quote
Old 11-28-2010, 12:10 PM   #12
mattminer
Member#: 90642
WKD Everything
wow, you guys are all a little crazy saying not to buy teh car. it likely has a simple issue. id check/replace teh vss first and if that didnt fix it id test swap teh cluster and see if that resolved it.
mattminer is offline   Reply With Quote
Old 11-28-2010, 02:40 PM   #13
CFM
Member#: 223538
05 WRX Wagon
I was told it was the cluster.
Old 11-28-2010, 04:16 PM   #14
Haelan
Member#: 151045
2013 Subaru STI
CBP
The VSS feeds the ECU and the the speedometer in parallel. You would have to log the vehicle speed to see if it differs from what the cluster is showing.
Old 11-28-2010, 04:38 PM   #15
shibby2821
Member#: 229778
04 WRX
WR blue
buy it and see if u could fix it, we told u to walk away but if ur that confident u can fix it, get it. my guy just picked up a 96 integra type r or gsr(i forgot which) for 3k and only like 60k miles. the kid sold it cheap cuz it kept shutting off and he didnt no how to fix it. turned out it was was just some corroded wire
shibby2821 is offline   Reply With Quote
Old 11-29-2010, 02:28 AM   #16
CFM
Member#: 223538
05 WRX Wagon
Yes it's my friend who is purchasing the car. He's confident that it's the cluster... I guess it had some other guages in it before or something like that, something went wrong...
Old 11-30-2010, 12:00 AM   #17
jmart2332
Member#: 265142
2002 Impreza WRX
So.... I found out the problem. The previous owner had indiglo gauges and the current owner removed them because the light had died in them. While removing the gauges he popped the speedo needle off and just put it back. He didnt put it back in the exact spot obviously.
NJ: '02 WRX seats, WRX head units w/problems, amp rack, speakers, GC airbag, more annointed Interior/Dressup/Audio & Security 24 04-06-2010 04:19 PM
I want an '02 WRX, what problems to look out for? A4wheelin Impreza Forum 4 09-12-2008 11:40 AM
'02 WRX Window problems/fix aspeirce Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-23-2004 11:42 PM
Speedometer problem... shadymilkman Electrical & Lighting 3 01-13-2004 09:16 PM
Speedometer problems Hank3 Warranty Issues & SOA Problems 1 04-12-2002 08:38 PM
