Old 11-24-2010, 08:56 AM   #1
TheLordChesterfield
Member#: 234539
Default Blue wire on STI Alternator -> STI ECU
On STI's alternator you find a third blue wire that runs to the ECU.
Does anyone know what this does? The alternator I have lacks this wire - is this a problem? I can't find a CEL for the generator either.
I'm finishing up the wiring on a swap and I'm not sure what to do?
TheLordChesterfield is offline   Reply With Quote
Old 11-27-2010, 02:58 PM   #2
TheLordChesterfield
Member#: 234539
Bump.
Anyone? I may just leave it open and see what happens, but I would prefer not to....
Old 11-28-2010, 11:25 AM   #3
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
I'm reviewing a manual and have yet to locate this particular circuit on the ECU.
But for now, that blue wire is listed as for the STI only.
Also note that the STI is drive-by-wire, as well as for having the DCCD, electronic gauge cluster, and a host of other electronic items not normally found on non-STI models. So this may be a signal wire to the ECU to tell it if the alternator is charging or not. If not, then this may signal the ECU to shut the car down to prevent any possible damage to the electrical system and/or electronic items and components as a whole.
Old 11-30-2010, 02:46 PM   #4
atm92484
Member#: 213374
2009 STi
On a lot of newer cars, the computer controls the alternator output. I'd be willing to bet that is the wire that does it.
I vote for finding the correct alternator. Even though a 2 wire one should work without the ECU, its hard to say whether or not something will get damaged.
atm92484 is offline   Reply With Quote
Old 12-03-2010, 12:39 PM   #5
Britain
Member#: 247604
1974 Porsche 914
1700lb AX Car w/ Spec-C
Yes, the Blue wire is the alternator output control wire from the ECU.
-Britain
Britain is offline   Reply With Quote
2 smaller wires coming from alternator? 06 sti jasv11 Electrical & Lighting 0 06-09-2010 07:28 PM
Blue wheels on an 06 CGM STi? suby_dude Member's Car Gallery 28 06-26-2008 06:41 PM
newb wiring question: 4 AWG -> small terminal on Basslink marsh Car Audio, Video & Security 16 05-10-2007 10:55 AM
RPM sensor wire on STI ecu ? The Donnn Electrical & Lighting 1 10-13-2003 11:11 PM
Sighting: BLUE WRX on La Puente Rd -> Nogales... Onderboy?? karazyman Southern California Impreza Club Forum -- SCIC 5 02-17-2002 09:41 PM
