Old 11-24-2010, 11:28 AM   #1
ScottyDaug
Member#: 95414
2005 RS 2.5 PRO
San Remo Red
Default Help - Replacing O2 Sensor in 05 - RS 2.5
Hi,
I have a 05 Impreza RS. The CEL came on. I checked the code, and it came back P0131 Sensor Circuit Low Volts (Bank 1 Sensor 1). After doing a little research it sounds like this is a bad, or going bad O2 Sensor. Is Bank 1 the sensor in front of the cat? I would like to do this myself. Does any one know the step by step procedure, or a link to some instructions? I would greatly appreciate any help with this.
Thanks In Advance,
Scott
ScottyDaug is offline   Reply With Quote
Old 11-24-2010, 11:50 AM   #2
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
Its pretty easy as long as you can reach it, you would need ramps or a lift typically. Also, an O2 socket wrench is recommended. Its just like replacing a spark plug.
Samirr76 is offline   Reply With Quote
Old 11-26-2010, 12:32 AM   #3
PULMEOVR
Member#: 222724
2005 Impreza RS
Regal Blue
Just don`t go to the dealer ... $641 CAD is what I paid (stupid me)! OUCH!
PULMEOVR is offline   Reply With Quote
Old 11-26-2010, 02:30 AM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
1) ABSOLUTELY buy a DENSO brand O2 sensor. For whatever reason, the 05 RS chews up and spits out Bosch sensor like they're cheap tobacco. I have no idea what's different about the 05 (and it does seem to be only the 05) but they don't really get along with anything other than the Densos.
2) You'll need a 22mm O2 sensor wrench if you still have the stock heat shields on your cats. If you've removed the heat shields, you can use any random 22mm open end or box wrench in addition to the O2 sensor socket.
Old 11-29-2010, 12:15 AM   #5
DJBybee
Member#: 265221
DIY tip for finding out which sensor is which (especially helpful for systems with 4 or 5 or 6 sensors):
Unplug them one at a time, restart the car and check codes again. The code you generate with an unplugged sensor will probably be for "signal absent" but it will let you know which sensor is which.
Denso sensor or OE.
DJBybee is offline   Reply With Quote
Old 11-29-2010, 12:16 AM   #6
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
... Why the hell would you need to do that?
The DTC itself tells you which O2 sensor is bad.
Old 11-29-2010, 09:03 PM   #7
DJBybee
Member#: 265221
Responding to : "is that the one in front of the cat?"
My last experience was on an 04 Outback that has 5 oxygen sensors. Bank one, bank two, sensors #1, #2, #3.
Old 11-30-2010, 01:19 AM   #8
sc00ter
Member#: 117767
2015 WRX (CWP)
3" TBE | DT Flex Fuel
I had to replace the front 02 sensor on my 05 RS 3 times in 80k miles. P0131 was the code that was thrown every time it needed to be replaced. Average cost was $200 believe. I wish I would have known about the Denso sensors in the 05's.
Listen to williaty. He knows his stuff.
sc00ter is offline   Reply With Quote
Old 11-30-2010, 01:21 AM   #9
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Yup, your postings, my experiences, and a couple of other guys are what convinced me that the 05 is doing something weird with the sensor that kills anything other than a Denso.
Old 11-30-2010, 02:06 PM   #10
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Correct me if I am wrong, but OEM is denso. Can't go wrong with OEM.
formula91 is offline   Reply With Quote
Old 11-30-2010, 02:42 PM   #11
colorfull
Member#: 136688
2005 Impreza RS
Ah the 2005 Impreza...
Changed my sensor 4 months ago (got a Denso unit), and my car is throwing a code again after 10K miles...
Last one came out soothy black, could it be that the 05 runs too rich and the sooth kills them?
Granted, I have a TWE header, and my code is 2096, different of the OP. But still?
colorfull is offline   Reply With Quote
Old 11-30-2010, 03:35 PM   #12
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
You would need to run RICH, like richer than 10, to kill a sensor. Something is definitely amiss, though.
Old 11-30-2010, 04:06 PM   #13
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
According to the parts catalog, the 05 RS uses a different O2 sensor than the other years before and after. Go figure, considering we're the retarded/transition year.
I'm not sure why it's assigned a different part number, or what the differences are, but they are different in the parts catalog.
I also borked an O2 sensor at around 30k miles. At this point in time, I have a strange suspicion that the o2 sensor is starting to go bad again. I get lots of fuel vapor smoke out the tailpipe after autox runs. I think it's starting to go towards rich again.
Check anything that has to do with AFR. I'd probably check the MAF first.
Old 12-07-2010, 03:23 PM   #14
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
I just replaced my front for a third time and I used a Denso. Got the PN from the denso website and ordered it from NAPA. Kinda pricey but I need my car to run for DD uses.
Gr3en is offline   Reply With Quote
Old 12-07-2010, 04:41 PM   #15
GEE-OTTO
Member#: 201277
2009 Legacy GT
Whatever you do DONT buy the splice it yourself sensor LOL. 05's may kill sensors faster due to particulate build due to catalyst substrate deterioration upstream?? Two cats before the rear sensor just a guess.
The dealer put a whole new manifold on my 2008 legacy when I got a similar code and reused the sensors and i havent gotten that since (that was 40K miles ago)
GEE-OTTO is offline   Reply With Quote
Old 04-17-2014, 07:48 PM   #16
CR7_2011
Member#: 308894
2005 Impreza 2.5RS
Does anyone have a specific part number to replace the 02 sensor from rockauto? I am getting conflicted between part #2349011 and #2349015. Which one is it? I have read different things on the forums and I am confused an not sure which one is the correct part. They almost look identical.
CR7_2011 is offline   Reply With Quote
Old 04-18-2014, 05:06 AM   #17
EdHilario
Member#: 137398
2004 Impreza
2349122 is the front O2
2344732 is the rear O2
EdHilario is offline   Reply With Quote
Old 04-19-2014, 05:48 PM   #18
CR7_2011
Member#: 308894
2005 Impreza 2.5RS
Now you give me another two part numbers. So i have now got 4 part numbers from this website for the same code... Even more confused now...
Old 04-19-2014, 07:09 PM   #19
EdHilario
Member#: 137398
2004 Impreza
Which sensor are you replacing? There is FRONT O2 and a REAR O2.
Old 04-23-2014, 07:52 PM   #20
CR7_2011
Member#: 308894
2005 Impreza 2.5RS
I have both these ECL codes on a Subaru Impreza 2005:
p0131 (O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
p0031 (Heater control circuit (Bank 1 sensor 1)
I think it's the front sensor based on those codes right?
I'm just really hoping to find out the correct part number in order to replace the sensor that is giving off these codes. It's too hard to order the part until I am able to confirm the part number.
I have done lots and lots of reading on this forum and it looks like rockauto is the best place to purchase a sensor. However, I have come across two different part numbers on this forum in different threads relating to these codes and replacing the O2 sensor, which is why i am confused about which one to get.
# 2349011 http://www.rockauto.com/catalog/cata...ENSO%2B2349011
and
# 2349015 http://www.rockauto.com/dbphp/x,cata..._2349015.html0
Do I need to replace both sensors? Or will replacing one of these fix the other code at the same time also, considering that the codes are both coming from sensor 1 bank 1. Please help to clarify my confusion and point me in the right direction. I just need to know which one it is that I need to get. Thanks.
Old 04-27-2014, 11:27 PM   #21
EdHilario
Member#: 137398
2004 Impreza
Replace the front sensor.
Old 04-28-2014, 08:48 AM   #22
Subie-Lifer
Member#: 344958
Dude just buy the denso upstream and put it in. It's probably an air/fuel ratio sensor. More $$$. Who ever had 5 sensors must have missed something cause it doesn't.
Also a 7/8's wrench is all you should need. The connector on your new part should help identify the o2 in question if they are both in the front. I love that wrap around exhaust. burn burn burn
Subie-Lifer is offline   Reply With Quote
Old 05-02-2014, 06:14 PM   #23
Uptow4fred
Member#: 316977
2006 Impreza 2.5
Red
I paid for a new 02sensor at Subaru a orange colored wire denso and it fixed both codes on the car also had seeburgs show me which needed done
Uptow4fred is offline   Reply With Quote
Old 05-02-2014, 08:02 PM   #24
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Use only Denso or OEM or you're just wasting time and money because the others will soon fail again. OEM is stupidly expensive but Denso is pretty cheap on Amazon.
Yes, some of them actually have 5 O2 sensors. The only place in the world that gets them is California. I didn't believe it either until a guy from out there sent me a page from their Service Manual.
Old 05-02-2014, 09:34 PM   #25
skramguts
Member#: 379316
2006 Legacy BSM
2009 Impreza DGM (RIP)
by 'front' sensor, do you mean first in line on the header?
skramguts is offline   Reply With Quote
need help with ej20 swap in my 99 2.5 rs jonnyquest Newbies & FAQs 12 05-28-2008 03:00 PM
Nightmare w/ the front O2 Sensor in an 07' 2.5i (help) deviantek North West Impreza Club Forum -- NWIC 9 08-18-2007 01:29 PM
Nightmare w/ the front O2 Sensor in an 07' 2.5i (help) deviantek NWIC Private Classifieds 4 08-17-2007 08:18 PM
O2 sensor recall for '00 2.5 RS- What does it do? Should I get it fixed? pilz13 Newbies & FAQs 1 09-19-2002 04:29 PM
O2 sensor in 2002 RS rupteur7000 Normally Aspirated with bolt-on Forced Induction Powertrain 8 08-09-2002 07:45 PM
