Old 11-24-2010, 11:08 AM   #1
2011WRBlue
Member#: 264508
Default Can I have two sets of TPMS for 2011 WRX?
I would like to buy another set of winter wheels and tires for my 2011 WRX, and I was wondering if it was possible to have 2 sets of TPMS/wheels programmed for the same car, or do I have to get it reprogrammed everytime I change wheels.
Thanks
2011WRBlue is offline   Reply With Quote
Old 11-24-2010, 12:19 PM   #2
ki4syr
Member#: 247574
2013 PBP GV STI
2008 Impreza 2.5i
Got to reflash the TPMS module each time you switch wheels. The current OEM module only supports 4 sensors.
ki4syr is offline   Reply With Quote
Old 11-24-2010, 01:59 PM   #3
2011WRBlue
Member#: 264508
Thanks for the quick reply! I don't think I'll be paying for that every season, so I might as well go with wheels that don't have TPMS (and just ignore the light).
Old 11-24-2010, 02:13 PM   #4
Baddmnkey
Member#: 211812
09 WRX
SSM, mostly stock!
my dealership charges $18 to reprogram just fyi
Baddmnkey is offline   Reply With Quote
Old 11-24-2010, 02:15 PM   #5
beast464
Member#: 58149
2011 WRX
You can put the codes into an ATEQ Quickset and just reflash it yourself each time.
beast464 is offline   Reply With Quote
Old 11-24-2010, 02:36 PM   #6
2011WRBlue
Member#: 264508
Even for 2011's? How much is this tool and where can I find one?
Thanks,
Old 11-24-2010, 07:57 PM   #7
daverup
Member#: 3708
2015 WRX Ltd Sedan
ISM
Thanks,
Tire Rack, about $125 I think.
daverup is offline   Reply With Quote
Old 11-24-2010, 09:56 PM   #8
ki4syr
Member#: 247574
2013 PBP GV STI
2008 Impreza 2.5i
I believe tirerack has stopped selling them. I couldn't find them last night on there.
Also, the local dealership here charges $45 to reset TPMS.
Old 11-26-2010, 10:01 PM   #9
Hefner413
Member#: 243725
2015 Limited WRX 6MT
I've read elsewhere that the TPMS is pretty important... I've never had a vehicle with it - so I'm new to this. I've gotten use to simply checking pressures on my own. Are they that essential?
And tirerack indicates that the quickset doesn't work for the 2011.
Hefner413 is offline   Reply With Quote
Old 11-28-2010, 01:10 PM   #10
ki4syr
Member#: 247574
2013 PBP GV STI
2008 Impreza 2.5i
After having the sensors save a tire on both my WRX and the wife's Foz, I wouldn't go without TPMS. It may seem like a headache, but well worth the trouble considering you get an early warning before tire damage happens.
Not sure why the Quickset doesn't work for 2011. I'm not aware of any changes that were done with the systems. I know for a fact the Tech400Plus I have will work with 2011.
Old 11-28-2010, 02:46 PM   #11
flstffxe
Member#: 155358
2008 Forester
Steel Silver
Yes you can,
Here is a new option. Shrader-Bridgprot has new TPMS sensors. They are of a programmable type, you program the new sensor to the same ID as your old sensor vs programing a new ID into the TPMS module.
What this allows one to do is to run as many sets of wheel as one would want as long as they all had the new Shrader EZ sensors in them. Basically the EZ TPMS sensors in each set of wheels would be a clone of the original set of TPMS sensors. So as far as the TPMS module is concerned it sees no change, it still sees the same ID codes.
Some info:
http://www.ez-sensor.com/what-is-the-ez-sensor.html
http://www.ez-sensor.com/programming-the-sensor.html
I can't believe how far behind the times NASIOCs tire crowd is
flstffxe is offline   Reply With Quote
Old 11-28-2010, 04:25 PM   #12
duc1100s
Member#: 260393
Not quite clear from your post, do you have to replace the stock sensors with these also or will they mimic the stock ones so you only have to buy for the second set of wheels? Ie do I need 4 or 8?
Also where do i buy them retail?
duc1100s is offline   Reply With Quote
Old 11-28-2010, 04:54 PM   #13
flstffxe
Member#: 155358
2008 Forester
Steel Silver
You read the IDs from your stock sensors and program those IDs into the EZ-Sensors.
Example: factory tire set with factory TPMS sensors(lets call these the "summer set") and you want to run a winter set.
1. You buy a set of EZ-Sensors to install in the winter wheels.
2. In this case you would pull the IDs from your summer TPMS wheel sensors.
3. You then program the EZ-Sensors with the IDs of the summer set, you clone the summer set. You now have two sets of TPMS sensors with the same IDs, one being the factory set, the second being the EZ-Sensors in the winter wheels.
You are now free to swap between the summer set and winter set with out reprogramming the TPMS module in the car to new sensors. You program a new sensor/s to an existing ID/s
Basically you could have any number sets of wheels you want and be able to swap between them. You would just have to have EZ-Sensors installed in each set so you could clone your originals.
As for where to get them, I have not looked online, I have a small private tire shop by me that carries them after calling around.
No different then making a copy of a key, either key will now open the door. As the tpms module will now see both sets of sensors.
Old 11-28-2010, 07:30 PM   #14
mr.temagami
Member#: 241233
2011 WRX Hatch
I purchased a wheel/tire package with sensors from a local shop along with the ATEQ QuickSet tool. I entered the codes marked on the sensors (I took pictures before they were installed) and I've used the tool to read-back the data and verified that the new codes were loaded. Unfortunately, this hasn't cleared the codes.
Is it necessary to know which code is installed in which tire? I didn't think it was but I'm not sure what else it could be (yes, I've also verified that the pressures are ok).
Thanks for any help.
mr.temagami is offline   Reply With Quote
Old 11-29-2010, 08:22 AM   #15
ki4syr
Member#: 247574
2013 PBP GV STI
2008 Impreza 2.5i
Well, unless you have access to a Schrader 21230 or Bartec Tech400Plus (what I have), you can't "program" these sensors. This is the first I've heard of these sensors, even though I have the current updates to my Tech400Plus, I've not seen mention of the EZ sensor. I'll have to do a little more digging.
Great concept though, luv the idea of programmable sensors. I'm sure though these sensors are gonna be twice-three times the price of normal sensors.
OH, and this ain't so old news, they were only unveiled at the SEMA show on Nov. 2, 2010.
Old 11-29-2010, 09:24 AM   #16
flstffxe
Member#: 155358
2008 Forester
Steel Silver
If you want to do it in a shop setting yes, You need the tools. However for the average Joe Blow off the street who wants to swap between summer and winter sets with out having to reprogram the TPMS module each time they swap back to one of the sets, you are only looking at a 1 time programing(fee) the first time you program the EZ-Sensors to be clones of the originals(or current set), after that swap those sets at will.
Sure the hell beats paying a tire shop/dealer ~$20-50 twice a year when you do the change over. After a couple times of paying a shop twice a year to reprogram the TPMS module I am sure the EZ-Sensors have more of a competitive price.
They may have been unveiled for the first time to the public at SEMA but they were/have been up on their site since at least July.
Old 11-29-2010, 12:25 PM   #17
ki4syr
Member#: 247574
2013 PBP GV STI
2008 Impreza 2.5i
I agree with the savings, but here's why I bought the Tech400Plus. There is not a shop (nor dealership) within 45 min of me that has capability of re-flashing a Subaru TPMS. I've asked all of the tire shops around town here and none of them even have a clue about TPMS, they just send 'em to the dealerships, lol. It may be different in larger cities, but even a Subaru dealership cannot program the EZ sensors without either a Shrader or Bartec unit. Check around and see how many tire shops know about the EZ sensor and how to program it. You may be surprised. I've been calling around town today trying to find a supplier for those EZ sensors.... nothing yet.
Old 11-30-2010, 01:18 PM   #18
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
You can also run 2 sets of wheels with 2 sets of TPMS sensors without reprogramming each season, BUT you will need to buy a spare receiver and have it programmed with your spare set of TPMS sensors. After that is done, you can swap boxes when you swap tires/wheels.
http://legacygt.com/forums/showthrea....html?t=108338
phenryiv1 is offline   Reply With Quote
Old 02-03-2011, 01:06 AM   #19
team23jordan
Member#: 48132
2011 STi
interesting.
any updates about the EZ-TPMS?
team23jordan is offline   Reply With Quote
Old 02-03-2011, 01:21 AM   #20
team23jordan
Member#: 48132
2011 STi
hmm..looks like, if i were to buy programming device and ez-sensors, getting this is the cheapest..but still $600+
http://www.tooltopia.com/otc-tools-3...googlebase_18u
Old 02-05-2011, 09:15 AM   #21
Topplayer
Member#: 272650
2011 STi
dam i didnt think about this when i get my new rims with another set of tpms sensors, I hope they dont charge alot to get it reporgramed at the dealer!
Topplayer is offline   Reply With Quote
Old 02-07-2011, 12:07 AM   #22
G_REX
Member#: 266384
2011 WRX Limited
Spark Silver Metalic
I think the factory computer stores up to 2 sets (8 TPMS codes)....no?
G_REX is offline   Reply With Quote
Old 02-07-2011, 09:51 PM   #23
wtwwholesaletire
Vendor
Member#: 98066
2003 forester
white
wtwwholesaletire is offline   Reply With Quote
Old 02-08-2011, 12:25 AM   #24
team23jordan
Member#: 48132
2011 STi
just a website that sells TPMS sensors
who makes the best and cheapest sensors?
can anyone confirm that quickset tool doesnt work on 2011 subarus?
Old 02-08-2011, 11:30 AM   #25
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
The older ones only stored 1 set, IIRC. If they stored 2 sets and you could just toggle, that would be optimal. Unfortunately, I don't think that the system can store more than 4 at a time.
FS : Two sets of tires for sale beachbum12tree SCIC Private Classifieds 28 02-18-2011 01:09 AM
FS(IL) 2 sets of tires (Azenis and Pilot sport A/S)I have 2 sets of tires for sale. g2wanderer MWSOC Private Classifieds 1 05-25-2010 08:36 AM
Two sets of wheels for cheap:) Icon 16/OE Subaru 14's D1SKOOLBUS Wheels/Tires 0 05-06-2010 09:29 PM
I have a set of crossbars for sale if anyone wants Sobelizard109 Legacy Forum 9 11-14-2003 03:28 PM
where can i get a set of heads for my wrx STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-01-2002 02:38 AM
