Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 11-24-2010, 05:21 PM   #1
slowscooby
Member#: 69520
- '05 STi
"White Thunder"
Default Specific Offset/Clearance Question
I have a 2005 Sti with a set of AST coilovers on it. They are single height adjustable, and at the height they need to be the lower spring perch ring sits next to the tire. I cannot raise it above the tire or the rear of the car would be sky high.
Right now the ring clears the tire, just barely, by like 1/4". I am running a 2007 STi limited wheel, 17x8", not sure on the offset? Same as a stock BBS STi wheel I beleive.
I am looking at getting a set of Rota DPTs in 17x9, with a +42 offset. For tires I will be running a 255 width, not sure on brand yet.
MY question is this: Will the Rotas clear my suspension with that size tire?
I'm assuming a wheel/tire guru can do the math and tell if the offset will either make the tire sit in the same spot or farther out, or I dread..farther in...
Thanks!
slowscooby is offline   Reply With Quote
Old 11-24-2010, 05:43 PM   #2
slowscooby
Member#: 69520
- '05 STi
"White Thunder"
Pic for reference. It's a bad angle, it's not touching, but you can see how close it is.
Old 11-24-2010, 06:12 PM   #3
sc00by4life
Member#: 97135
I believe the stock bbs come with something in the +53 area. they will clear your suspension just fine, but you will need to roll your fenders with that size tire.
Old 11-24-2010, 07:42 PM   #4
nhat
Member#: 140163
03 STi
hellaflunctional
stock bbs are 17x8 +53. if the wheels aren't touching the suspension at rest, they never will. i had about the same clearance with my 18x8.5 +48 wheels and 255/35/18s and never had an issue.
the 17x9 +42 DPTs will clear just fine.
Old 12-09-2010, 12:07 PM   #5
slowscooby
Member#: 69520
- '05 STi
"White Thunder"
Thank you
wheel offset and brake clearance question dynamicprojeKtz Tire & Wheel 3 12-07-2004 10:01 PM
Shaving wheel for offset clearance zacek Tire & Wheel 3 04-24-2003 11:29 PM
ATTN: Florida residents...specifically Jacksonville...emissions question hobbzz South East Region Forum 5 01-13-2003 06:40 PM
Some '96-99 Legacy specific stereo install questions Patrick Olsen Car Audio, Video & Security 3 07-17-2001 11:54 AM
Some '96-99 specific stereo install questions Patrick Olsen Legacy Forum 4 07-15-2001 11:19 PM
