Old 11-24-2010, 08:44 PM   #1
zedman
Member#: 129938
2005 92x Aero
arctic silver
Default Hard Starting after fueling up
Everytime I fill up the tank with gas, she does not like to start right away. I will turn the engine over for the normal cycle, it won't start. I'll stop, then turn over again, and she will start, but run very rough, almost stalling, then after about 15 seconds she will be back to normal.
Anyone else have this problem ?
I tried replacing the gas cap, no difference. The fuel pump is new (along with a new sock), all lines/ etc appear to be intact.
On a daily basis she starts with no problems ever.
Cheers and thanks !
zedman is offline   Reply With Quote
Old 11-24-2010, 09:04 PM   #2
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info group lead
Try cleaning the IACV...I had nearly the same trouble (start and almost stall after fueling). I cleaned the IACV and it's so much better.
darkstarmoto is offline   Reply With Quote
Old 11-24-2010, 09:15 PM   #3
WRX357
Member#: 224249
2002 Subiworx built/
Soulless tuned Bugeye
I also had this probrum. I ended up having a couple vacuum lines mixed up on the thinga-ma-bob thats right behing the power steering pump. Could be a combo of what scrapin' said above and the vacuum lines. I'd check em all.
WRX357 is offline   Reply With Quote
Old 11-25-2010, 01:34 PM   #4
zedman
Member#: 129938
2005 92x Aero
arctic silver
cleaned the IACV already, no luck !
Old 11-25-2010, 01:36 PM   #5
zedman
Member#: 129938
2005 92x Aero
arctic silver
I'll the check the thing-a-ma-bob (aka purge control valve circuit). Interesting you mention that, I did accidentily break off one of the nipples a couple months back(JB welded it back). Though I am fairly certain teh hoses are connected properly, I will check that out. I should likely just find a used one in case it no longer function properly !
Thanks for the input, Cheers
Old 11-25-2010, 01:39 PM   #6
chickencherryaki
Member#: 240580
mine runs a little rough after a fill up as well. not as bad as the op. it starts fine but then runs rough for about 10 seconds then it's fine again.
chickencherryaki is offline   Reply With Quote
Old 12-05-2010, 09:04 PM   #7
zedman
Member#: 129938
2005 92x Aero
arctic silver
Well, for any one who cares. I replaced the PURGE CONTROL VALVE CIRCUIT with a used one I sourced, and, voila, problem solved.
New, Subaru wanted $ 233, and from Saab, they wanted, $ 229. Both called it a Duty Solenoid.
Anyways, thanks for teh great input guys, it's most apperciated !
Cheers
Old 12-05-2010, 11:53 PM   #8
vien
Member#: 221538
2003 wrx/ylw wheels
darkness.................
Anyways, thanks for the great input guys, it's most apperciated !
Cheers
how does it look like?
vien is offline   Reply With Quote
Old 12-06-2010, 03:31 PM   #9
MX283
Member#: 266206
Do you have the part number?
MX283 is offline   Reply With Quote
Old 12-09-2010, 01:59 PM   #10
zedman
Member#: 129938
2005 92x Aero
arctic silver
Here's the part number off of my old one: K5T48376 4729
According to subaru, they have about 10 different part numbers. The used one I got as a replacement was actually a bit different in that the vacuum ports were larger, and the mounting bracket was different. I just removed the bracket and used the one from my old one, then just used different size vacuum lines.
I don't know how to load pics, but if anyone wants, send me your email and I'll email it to you.
It's behind the power steering pump, mounted lower on the intake manifold, it has an electrical connector up top (two pin), then two vacuum line outputs below in line
Old 12-09-2010, 02:00 PM   #11
zedman
Member#: 129938
2005 92x Aero
arctic silver
If anyone is interested, I also have the parts look up page with the part in it from subaru in adobe.
cheers
05 WRX hard start after vacation, HELP! maxpower_454 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-28-2010 12:15 PM
'02 Wagon Hard Starting, HOT Fuel Pump Relay !! Hondaeat-r Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 97 08-23-2010 09:05 AM
Hard Starting, HOT fuel pump relay. Hondaeat-r Electrical & Lighting 7 07-28-2010 06:17 AM
Hard start after clutch change Manbike26 Transmission (AT/MT) & Driveline 7 09-14-2008 07:48 PM
Hard start after rain storm NRTmotorsports Service & Maintenance 4 03-20-2008 09:02 PM
