Old 10-03-2011, 03:48 PM   #301
hipowernut
Member#: 254184
TR42 06 WRX w/5 spd
Syn Green w/carbon fiber
As long as it's not a private school, that's ok
hipowernut is offline   Reply With Quote
Old 10-03-2011, 04:30 PM   #302
hipowernut
Member#: 254184
TR42 06 WRX w/5 spd
You want me to send you a set of these?
Vibrant Performance Flat Black 2.5" Oval "Sleeper" Muffler
Inlet Diameter: 2.5"
Tip Style: Dual 3" Round Tip, Angle Cut (Single Wall)
Muffler Size: 5" x 9" Oval Muffler Body, 15" Long
Overall Length: 20" (including tip)
Tip Length: 5"
Old 10-03-2011, 04:48 PM   #303
MatrixPooK
Member#: 268609
I'm worried about the length, I have room for an oval but 20" is to much.
what else is out there?
PooK
MatrixPooK is offline   Reply With Quote
Old 10-03-2011, 04:50 PM   #304
MatrixPooK
Member#: 268609
The above are 13.5" tip to tip, fear is that we get into the axle area?
PooK
Old 10-03-2011, 07:15 PM   #305
hipowernut
Member#: 254184
TR42 06 WRX w/5 spd
What about making our own?
Run two sets of 3" stainless pipes (one for the turbo downpipe, one for the wastegate). Stack them on top of each other sorta like the idea Ryan had, with both pipes on the passenger side. Just transition the wastegate pipe to a 3" so both are the same size.
Have the pipes run to a point where they will clear everything (if possible) and then have them sweep upwards like a sport bike exhaust for the portion that will hold the inserts. Cap off the inserts with these 360 degree adjustable turndowns.
Inserts are made for 3" pipes and are 7" long
Old 10-03-2011, 07:34 PM   #306
MatrixPooK
Member#: 268609
I can do that on the drivers side by dropping under the trans (tons of room) cross under then up and out?
Old 10-03-2011, 10:07 PM   #307
badermatic
Member#: 295750
2014 TR-82 EXO CAR
Candy red frame/blk body
I'm a bit nervous about the same issue (running out of room &/or running into the axle) when we go to do the V-8 exhaust on the TR-82 (Chassis #5). It looks like you folks, however, have the matter well in hand on this build. It certainly will be unique.
badermatic is offline   Reply With Quote
Old 10-03-2011, 10:31 PM   #308
MatrixPooK
Member#: 268609
There's room its more about the aesthetics at this point, It'll actually work a number of ways we just have to pick one and run with it.
PooK
Old 10-04-2011, 12:05 AM   #309
hipowernut
Member#: 254184
TR42 06 WRX w/5 spd
I found a company that offers you-weld-it custom muffler kits in stainless.
Cone Engineering = www.coneeng.com
Prices = http://www.coneeng.com/pdf/Muffler%20Components.pdf
Old 10-04-2011, 10:06 PM   #310
hipowernut
Member#: 254184
TR42 06 WRX w/5 spd
Default Powder coat
Danny delivered the chassis to the powder coating company today. Should be back later this week. Can't wait to see how it looks.
Old 10-05-2011, 10:12 AM   #311
MatrixPooK
Member#: 268609
We went with the same powder as the engine parts were done in, Cant scratch it unless you try and even that would be hard to do.
Cant wait till she's back
PooK
Old 10-05-2011, 05:50 PM   #312
Nickarub
Member#: 230509
06 vf39 wrx
ugm
subscribed
Nickarub is offline   Reply With Quote
Old 10-05-2011, 08:49 PM   #313
hipowernut
Member#: 254184
TR42 06 WRX w/5 spd
Default Body paint color
It's official - the hood, side pods and intercooler scoop will be painted Synergy Green from the new Camaro. I have loved this paint since I first saw it in person, which pictures cannot do justice.
The center inset section of the hood and side pods will be wrapped in a 3M carbon fiber as well as the center dash, center console, seat backs and about anything else that comes to mind.
Old 10-05-2011, 11:18 PM   #314
hipowernut
Member#: 254184
TR42 06 WRX w/5 spd
Still goofing around on muffler ideas (even though Danny says he has a solution).
Found these Hooker Aerochamber mufflers, which are the same kind I have on my 540hp 68 Camaro.
Universal Turbo Style - Black Finish
4.75 in. H x 10.25 in. W x 14 in. L
3" Center inlet
2.5" Dual outlet
Part Number: 21518HKR
MSRP: $97.80
Your Price: $79.38 (@ sportcompactonly.com)
Old 10-06-2011, 07:44 AM   #315
badermatic
Member#: 295750
2014 TR-82 EXO CAR
Marty that color is spectacular. Will be a real head turner.
Old 10-06-2011, 07:49 AM   #316
MatrixPooK
Member#: 268609
I agree!
PooK
Old 10-06-2011, 07:58 AM   #317
MatrixPooK
Member#: 268609
Quick question, do you still want the calipers powder coated? If so ill take them apart and take them in the next load......and what color?
PooK
Old 10-06-2011, 08:01 AM   #318
hipowernut
Member#: 254184
TR42 06 WRX w/5 spd
Danny - see if you can find the status of powder coat today. I'll be headed your way later this afternoon.
Old 10-06-2011, 08:09 AM   #319
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I'd say run a large chambered exhaust, dual exit.
Something like that. You could also position it to help 'hide' the trans that's poking out.
I'm planning to run a similar style exhaust on mine. I also don't think they sound to bad on a Subie with equal length.
http://youtu.be/4XFt7TO7_Pw
Old 10-06-2011, 09:24 AM   #320
MatrixPooK
Member#: 268609
I see where your headed. I was thinking more like this, making a mount that comes off the sides of the trans and straps the mufflers to the engine/trans so that it can rock (rubber engine mounts) with the motor instead of flex pipe.
911's use the same style.
Bad drawing but it shows my idea.
The trans tail shaft wont be there and the block off plate will be inside the lower chassis tube.
PooK
Old 10-06-2011, 09:33 AM   #321
Homemade WRX
Member#: 33782
96 bastard child
yeah, 911's actually tuck two on the sides and then one center as well.
Old 10-06-2011, 09:44 AM   #322
MatrixPooK
Member#: 268609
Exactly! Has to be Black to go with Marty's scheme is why we are looking at the various flat black ovals for the right size....we'll find it!
Wonder if Powder coat can take muffler temps? I know the pipes are much hotter than the final mufflers....?
PooK
Old 10-06-2011, 09:51 AM   #323
MatrixPooK
Member#: 268609
You know, I love the Atom! (its my inspiration) but doesnt it seem they went to great lenghts to mount everthing that weighs anything as high in the chassis as they could? I wonder why?
PooK
Old 10-06-2011, 10:43 AM   #324
Homemade WRX
Member#: 33782
96 bastard child
^^^I had thought the same thing. However chamber mufflers are usually rather light as they are normally pretty dran empty.
I have the dimensions from the Megan one, that someone took for me. I say just make it.
It's simple to do. We use to make our own for FSAE.
Old 10-06-2011, 12:11 PM   #325
MatrixPooK
Member#: 268609
I like these!
http://www.cherrybomb.com/Catalog/Ca...s/extreme.aspx
I can sandblast the red off and we can get them jet coated
PooK
FS: 2003 EVO 8 Track/Street car. bhhamblin RMIC Private Classifieds 11 02-20-2010 12:37 PM
Better Track/Street Car E36 M3 or WRX? dpspeed Motorsports 71 05-20-2008 11:04 PM
WTT: M3 Track/Street Car redefinedWRX Private Vehicle 'For Sale' Classifieds 17 11-28-2007 04:54 PM
Anyone have a 06 wrx? not TR Dszerox Mid Atlantic Impreza Club -- MAIC 14 05-02-2007 09:57 AM
I want to trade my 06 STI Black Trunk for an 06 WRX or TR trunk in the socal area skubydew16 Private 'Wanted' Classifieds 0 07-25-2006 09:37 PM
