Old 11-26-2010, 01:39 AM   #1
Luckyduck919
Member#: 107430
1993 Impreza
Seafoam
Default No Cranking, car will start when push started.
Hi Everybody,
So the car is a 1993 Subaru Impreza L. The car will not crank over on it's own. But if I have momentum ( i.e backing down a driveway) and I engage the clutch the car will start just fine.
There is a small connector/fob thing that is underneath the steering column and in between the gas and brake pedals. When I put pressure on it the car will start to turn over and run just fine. So it looks to me like an electrical short that is occurring in some sort of removable security mechanism.
My question is, what in the world is this piece? I do not see it in any of the starting system electrical diagrams I have found.
Luckyduck919 is offline   Reply With Quote
Old 11-26-2010, 03:47 AM   #2
Jaren1
Member#: 195061
1997 \_(ツ)
Green
My car had this exact same bull****. All you have to do is just bypass that piece and remove it. Its an anti theft dissabler deal. Its stupid really. So as soon as you remove that and its wiring and hook it up without it your problem should go away
Jaren1 is offline   Reply With Quote
Old 11-26-2010, 04:06 AM   #3
Luckyduck919
Member#: 107430
1993 Impreza
Seafoam
Ok, I figured that that would be the case. Would you by chance be able to walk me through the process of doing that?
Right now there are 5 wires, 3 of them look like they go to ground, 1 comes from the steering column and is fused, and the other goes somewhere else (steering column maybe?). What do I do with these five wires specifically in order to bypass the whole disabler unit?
Any help or just a link to some sort of wiring diagram would be awesome.
Again, thanks
Old 11-28-2010, 03:21 AM   #4
2.5i
Member#: 112986
N/A Cam'd & Cornfed
DOM TUNED 06 Impreza
It's real easy... I've removed many of these. Its a basic starter kill, do not put a put a quarter in there thinking that's the fix. It will only work once then you'll have to replace the fuse and start all over.
The couple wires that are screwed into the chasis you can remove. There should be one wire going to the ignition wire and another two should be going to the starter wire. If you can take some pics I can walk you though this, or if you come on the other side of the mountains I can help you remove it.
2.5i is offline   Reply With Quote
No Crank no start mmkay? Trogasarus Electrical & Lighting 3 11-20-2009 12:45 AM
car will only start when i shake the steering wheel?? crosta21 Legacy Forum 5 03-15-2006 07:54 PM
Why does my clutch release when I start to push on the peddle? Brooke Transmission (AT/MT) & Driveline 5 11-03-2005 10:42 PM
Running Link car cranks but will not start subaru mike Engine Management & Tuning 31 02-15-2005 10:57 PM
Long cranking to start when cold? RS4DR Normally Aspirated Powertrain 6 04-10-2001 04:18 PM
