Old 11-26-2010, 05:09 PM   #1
shakermaker
Member#: 254535
Default Will 225-50-16 Tires work on 2010 Impreza 2.5i stock rims?
Its all in the title folks.
The rims are aluminium of course
shakermaker is offline   Reply With Quote
Old 11-26-2010, 05:17 PM   #2
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
They're less then ideal size for that wheel but they will fit and shouldn't rub as long as you're on stock suspension. Note that you're speedometer will be thrown off a little bit due to the profile change.
Mike
GrimmSpeed is offline   Reply With Quote
Old 11-26-2010, 05:17 PM   #3
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
If you can find them, they should fit just fine (sidewalls might be a little squishy with the wider tire on a 6.5" rim, but people have been running 225's on 02-05 WRX rims with no major drama - also - speedo should be nominally identical since the tires are only 0.1" different in circumference (so technically, the speedo will read 0.1% fast - so when you are going 50 on the speedo, you'll actually be going 49.95 mph... so not a concern))
Old 11-26-2010, 05:29 PM   #4
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
ran that size for years on my old 99rs on wrx wheels 16x6.5 (for the track) till i got some 15x7 race wheels.
Robin2 is offline   Reply With Quote
Old 11-26-2010, 05:32 PM   #5
shakermaker
Member#: 254535
thanks for the tips guys!
much appreciated.
So there will be no noticeable gain in performance?
If anything, a noticeable/slight loss?
how about mileage?
Old 11-26-2010, 07:24 PM   #6
DrDanimalSize
Member#: 254097
2010 2014 Impreza
Everything should be just about the same, maybe a little bit more grip in the dry. Mileage and the rest should be the same.
DrDanimalSize is offline   Reply With Quote
Old 11-27-2010, 01:55 PM   #7
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
how about mileage?
All of those really depend on what you buy for tires... all things being equal, going to a wider tire will increase grip (which is why it's popular for autocrossers), and the bulged sidewalls will result in a little more compliant ride - for fuel economy, I can't imaging there would be that much of a difference. However, you can compensate for sidewall flex by getting a tire with stiffer sidewalls, fuel economy can suffer if you get a higher rolling resistance tire (or get better if you get one with lower rolling resistance), etc.
Old 11-27-2010, 03:00 PM   #8
shakermaker
Member#: 254535
Im looking into Bridgestone Potenza 760 Sport
Wheel and tires fit on 08 Impreza 2.5i PP juny102004 Tire & Wheel 5 05-10-2009 06:59 PM
WTB: 16" Tires for Stock Wheels or 2- 225/50/16 tires G Langa Tri-State Area Private Classifieds 2 09-16-2008 01:09 AM
How will 225/50/16 on stock WRX wheels perform on track? WimpWgn Tire & Wheel 4 02-24-2005 03:27 AM
Stock Rim with 225/50/16 tire ronan1975 Tire & Wheel 11 10-18-2004 07:51 PM
Will 225 or 215/50/16 tires rub on stock WRX sedan with Prodrive or Eibach springs? AdmireWantWillLove Brakes, Steering & Suspension 4 05-06-2004 10:10 AM
