Old 03-17-2012, 07:22 PM   #51
azn2nr
Member Sales Rating: (23)
Member#: 35276
Yes. Factory Sti coolers are not angled and are straight up and down. Because they still utilize coolant to control temp the same coolant lines on the 06 07 wrx cooler should line up fairly well with the Sti cooler. You may need new rubber line at best
Btw Sti coolers are kinda expensive. You can get a legit cooler kit with a core for the same as a new Sti cooler. At that time you would still have to either bypass the coolant lines.
azn2nr is offline   Reply With Quote
Old 03-17-2012, 07:47 PM   #52
yamahaSHO
Member Sales Rating: (12)
Member#: 73932
2005 STi BROtuned
2004 S2000
He'll buy used for probably nothing.
yamahaSHO is offline   Reply With Quote
Old 03-17-2012, 07:52 PM   #53
azn2nr
Member#: 35276
That works too. Either way the filter/cooler is the only thing that gets in the way.
Old 03-17-2012, 08:48 PM   #54
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
Thanks for the additional info mang!
Old 03-18-2012, 08:03 PM   #55
SuaveCougarBait
Member Sales Rating: (22)
Member#: 255092
2007 WRX Limited
Garnet Red Peal (33j) e85
Good info. I need to do an oil change so I'll peek at the cooler n see.
SuaveCougarBait is offline   Reply With Quote
Old 03-19-2012, 04:51 PM   #56
azn2nr
Member#: 35276
And just to answer any other lingering questions it does fit with an aftermarket oil cooler for sure. I just fitted a glow shift sandwich plate to the car with -10 line. Fits like a charm.
Old 03-19-2012, 05:30 PM   #57
SuaveCougarBait
Member#: 255092
2007 WRX Limited
Good to know.
Old 03-23-2012, 12:24 AM   #58
Patrack92314
Member Sales Rating: (1)
Member#: 223810
1999 legacy gt
green
So I wonder how these sound.
Patrack92314 is offline   Reply With Quote
Old 03-23-2012, 12:29 AM   #59
yamahaSHO
Member#: 73932
2005 STi BROtuned
2004 S2000
http://www.iwsti.com/forums/3526800-post2686.html
Old 03-23-2012, 12:43 AM   #60
Patrack92314
Member#: 223810
1999 legacy gt
green
Thanks sounds good not like other ones
Old 03-28-2012, 01:56 AM   #61
azn2nr
Member#: 35276
Old 05-22-2012, 10:18 PM   #62
Mark2JZ
Member Sales Rating: (25)
Member#: 83818
so this is discontinued now? i was trying to find it on rallysportdirects site (i saw it a couple months ago) and now its saying its out of stock and may no longer be available
Mark2JZ is offline   Reply With Quote
Old 05-23-2012, 12:31 PM   #63
azn2nr
Member#: 35276
Hk's pulled out of the states.
Old 11-17-2012, 11:05 AM   #64
bhhamblin
n00b Moderator
Member Sales Rating: (35)
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
I sold my 2008 that this header was installed on, header now has about 55k miles with no issues. Since Azn2nr is going twin scroll I will be taking his and putting it on my 2013 Sti.
bhhamblin is offline   Reply With Quote
Old 01-14-2013, 08:33 PM   #65
icemanftr
Member Sales Rating: (4)
Member#: 320444
2012 WRX
Has anyone wrapped the HKS header's before install? Wonder if it would make them more prone to cracking? Definitely a great price with a bigtime name in performance and JDM...
icemanftr is offline   Reply With Quote
Old 02-19-2013, 03:34 PM   #66
azn2nr
Member#: 35276
neither bhhamblin or i wrapped ours so im not sure what to tell ya on that.
Old 05-22-2016, 10:34 PM   #67
hueyduey
Member#: 295135
2006 Grocery Getter
XT SGM
Originally Posted by azn2nr View Post
Best fitting header ever. No flex pipes no slip joints. Just fits.
this header will fit any triangular pan'd wrx/sti from 05-11.
on wrx 06 and 07 WRX ONLY you will need to remove the oil cooler and cocking bracket pictured together here
the cocking bracket is pictured by itself here
and make it look like this here
to do this you will need to blockoff or bypass the coolant line that runs into the oil cooler as well as aquire an N/A oil filter bolt. blocking off requires you to tap the water pump or ghetto rig a plug. the bypass just requires cutting the hard line bracket off which ends up looking like this here (displayed with N/A oil filter bolt)
finished product
Thanks for this. My 06 forester xt has the same oil cooler and without finding this post i would have given up on installing the headers.
hueyduey is offline   Reply With Quote
FS : OBX Equal-Length Headers for 06-07 WRX/STI! $100 yvk NWIC Private Classifieds 4 09-17-2010 12:08 AM
FS:BRAND NEW authentic V-limited lip AND OEM underskirt for 06/07 WRX and STi PICS phlegmon MAIC Private Classifieds 0 11-27-2009 04:54 PM
tire fitment on an 06-07 wrx rim jetblacac Tire & Wheel 2 12-10-2008 06:18 PM
fs- ap2 for 06-07 wrxs and 04-07 stis FATgc8 SWIC Private Classifieds 0 07-14-2008 08:44 PM
FS: SPT intake and heat sheild for 06/07 wrx dewthedew Engine/Power/Exhaust 13 01-27-2008 02:42 AM
