Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 11-27-2010, 10:52 PM   #1
mdusek1576
Member#: 231660
2006 Cobb Stg 2 STi
Default Replacing Wheel Stud on front of 06 sti
SOOO...i was going to put my winter tires/bbs wheels on my car so i took my Volks off and did a quick brake check and then started putting on all my wheels. 5 min later i was going to impact on my "all ready hand started lug nuts" and one of the lug nuts on the RF wheel stuck about 75% of the way on. (i am thinking it was some gummed up threads on the nut or somwthing) i went to loosen it and SNAP!! there goes one of my wheel studs
so the next day i got a wheel stud and figured out how to put it on. HERE IS WHAT I DID!
1. Jack up and take off the wheel.
2. remove the brake caliper. (two 19mm bolts on the back)
3. next your going to have to remove the bolt holding the brake hose up "i believe" This is going to allow you to remove the rotor.
4. Screw the bolt into the holes nearest the center of the hub. IT WILL FIT! and this will remove the rotor.
5. now you hammer the bad stud out.
6. put the other one through.
7. pull it through with washers and an EXTRA LUG NUT. NOT WITH THE O/E nut. it wont work cuz its closed end. so buy an open end. mine was a 12x1.25
8. now put the bolt back you used to press the rotor off. replace rotor. then caliper. then wheel and torque all the lugs down and hit the new one a few times. making sure its all the way through.
9. lower car and enjoy driving with all 20 lugs attached
So there ya go. thats my experience with replacing a stud on my 2006 sti
mdusek1576 is offline   Reply With Quote
Old 12-03-2010, 12:02 AM   #2
mdusek1576
Member#: 231660
2006 Cobb Stg 2 STi
feedback?
Old 12-11-2010, 07:27 AM   #3
NPB Subie
Member#: 228462
2012 WRX
Default Thanks!
Hey thanks great job, it's just what I'm gonna do today on my 09 WRX now that you explained it including nut sizes. Where did you get the stud, stealership? I hate waiting for days to get one, they stock very little here in Florida.
NPB Subie is offline   Reply With Quote
Old 12-11-2010, 08:39 PM   #4
mdusek1576
Member#: 231660
2006 Cobb Stg 2 STi
awesome! glad to help a fellow subie owner. I work at les schwab over here in washington. its a NW tire shop. i would try auto parts stores or tire shops.
Old 12-12-2010, 08:12 AM   #5
wrxbert
Member#: 89886
2006 WRX
SGM
Same thing happened to me yesterday....
wrxbert is offline   Reply With Quote
Old 12-12-2010, 04:13 PM   #6
mdusek1576
Member#: 231660
2006 Cobb Stg 2 STi
ya man, its a bad feeling! its like you tore off one of your childrens finger nails. but its just a stud on your car. supppperrr easy fix, let me know how everything goes
Old 12-13-2010, 09:43 AM   #7
Badler
Member#: 133597
Reason #85 not to use an impact gun on lugs.
Badler is offline   Reply With Quote
Old 12-13-2010, 11:19 AM   #8
mdusek1576
Member#: 231660
2006 Cobb Stg 2 STi
it makes workin at a tire shop a whole heck of alot easier
Old 12-30-2010, 02:25 PM   #9
nexus sw21
Member#: 139711
2004 sti
psm
SO THE SCREW THAT HOLDS THE BRAKE HOSE WILL FIT INTO THE HOLES TO PUSH THE ROTOR OFF?
PLS PM ME THE ANSWER =)
THANX!! AND SORRY FOR CAPS
nexus sw21 is offline   Reply With Quote
Old 12-30-2010, 05:23 PM   #10
mdusek1576
Member#: 231660
2006 Cobb Stg 2 STi
i replied to your pm but for everyone else. yes. my 06 sti.the bolt holding the bracket for the brake line threads to the rotor to press it off. glad to be of assistance
Old 01-21-2011, 04:22 PM   #11
xlsupreme
Member#: 120789
2005 USDM STi
it's an M8 hole, any M8 bolt will do. The rotors get kind of seized in place, so this screw-jacks them off of the hub.
xlsupreme is offline   Reply With Quote
Old 01-23-2011, 09:19 PM   #12
mdusek1576
Member#: 231660
2006 Cobb Stg 2 STi
what the heck is m8
Old 01-27-2011, 03:28 PM   #13
xlsupreme
Member#: 120789
2005 USDM STi
Originally Posted by mdusek1576 View Post
what the heck is m8
8mm bolt diameter, course thread = M8x1.25
Old 01-27-2011, 04:22 PM   #14
DutchOven
Member#: 220629
2010 White WRX Hatch
2015 White WRX Limited
I just used a rubber mallet to bang the sht out of the rotor and it came free. After jacking up the car and taking the wheels off, the rest of the work took me 10 minutes to do.
I bought studs from a local dealership, just start calling all of them near you, they most likely will have some. I paid around $3 for each and bought 5, just in case
DutchOven is offline   Reply With Quote
Old 01-28-2011, 01:45 AM   #15
mdusek1576
Member#: 231660
2006 Cobb Stg 2 STi
ya. you can hit the rotor if you would like but there is a possibility of it cracking, chipping, or warping. using the bolt was easier in my opinion. but to each there own i guess. and i got my lugs for free! i love working at a tire shop
Replaced wheel studs, now ABS light on...Arghh wadejg Brakes, Steering & Suspension 5 06-29-2010 01:21 PM
Replacing a wheel stud on a Mazda 6... Sephro Off-Topic 10 08-02-2007 04:29 PM
replacement wheel studs jaxscuby Tire & Wheel 1 04-06-2004 06:47 PM
replacing wheel studs okamikatekore Brakes, Steering & Suspension 2 07-01-2002 10:04 AM
Will any 15" wheels fit on front of 02 WRX MTREX Brakes, Steering & Suspension 3 06-28-2001 10:09 AM
