Old 11-28-2010, 11:04 AM   #1
simon930
Member#: 231504
2003 WRX
Sonic 16G
Default Drag dr-31 +17 or +28 offset
im looking to get the Drag dr-31 17x9 and i wanted to know the difference between the +17 and the +28 offset.
if any one can help i will really appreciate it.
thanks
simon930 is offline   Reply With Quote
Old 11-28-2010, 11:21 AM   #2
jdmboy
Member#: 240161
2002 wrx wagon R.I.P
87 bmw e30
the offset is a measurement that in a sense tells you how far the wheel is going to stick out, +17 and +28 are extremely aggressive for a subaru. i highly suggest you read this http://forums.nasioc.com/forums/showthread.php?t=335263
jdmboy is offline   Reply With Quote
Old 11-28-2010, 12:14 PM   #3
sc00by4life
Member#: 97135
you will be very limited on tire sizes. Especially if you don't want to modify your fenders. You'll have to roll all around for both of those fitments. If you don't want to pull, the +17's will require a 215/40 tire at the max, and the +28's would require a 225/40 at the max. If you are OK with fender modification, pull the **** out of your fenders and you can run much wider tires.
You will be extremely limiting yourself.
Old 11-28-2010, 01:32 PM   #4
jdmboy
Member#: 240161
87 bmw e30
yup not to mention if you go with a 215/40 or even a 225/40 the side wall is going to be really small
Old 11-28-2010, 01:44 PM   #5
simon930
Member#: 231504
2003 WRX
Sonic 16G
Thanks for the comments.
I want it to be aggressive but not to the point that I have to pull the fenders and also I am sitting on BC racing BR coilovers.
If I get the +28 and I roll the fenders will I be able to run 245/40/17?
Share your opinions
Old 11-28-2010, 01:46 PM   #6
jdmboy
Member#: 240161
87 bmw e30
Share your opinions
depends on how low you are and how much camber your running but generally no
Old 11-28-2010, 04:09 PM   #7
simon930
Member#: 231504
2003 WRX
Sonic 16G
So what's the biggest tire I would be able to run?
Old 11-28-2010, 04:21 PM   #8
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Both of those wheel offsets are god awful for Subarus. They will limit your tire choices, require irreversible mods to make them fit, reduce handling characteristics, and make the car less reliable.
I suggest getting a wheel that fits.
Byzantium is offline   Reply With Quote
Old 11-28-2010, 05:01 PM   #9
sc00by4life
Member#: 97135
Like i said. 225/40 is the max if you dont want to pull fenders. I had to pull the hell out of my fenders to fit 235/40's. I'm now at the point of no return, with 17x9 +10/+15 with 245/40 595's.
it requires alot of work.
Old 11-28-2010, 05:17 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
anything less than +40 is a LOT of offset
NOT the best of ideas
Old 11-28-2010, 05:21 PM   #11
simon930
Member#: 231504
2003 WRX
Sonic 16G
Ok thanks for all your comments
I'm probly going to roll my fenders and go with the +28 on 225/40/17
Old 11-28-2010, 05:26 PM   #12
Byzantium
Member#: 207826
85k 2002 WRX
Why on earth would you run a 9" wheel and use tires that belong on 7" wheels?
For the record, 225/40/17s are too short.
Old 11-28-2010, 05:42 PM   #13
jdmboy
Member#: 240161
87 bmw e30
hes trying to be k00 of course as scotty would say
Old 11-28-2010, 06:11 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
d000000000000d
yew kneed a hunduha....not a subaru
Old 11-28-2010, 09:45 PM   #15
simon930
Member#: 231504
2003 WRX
Sonic 16G
I'm tryin to use the biggest tire I can without pulling the fenders
What do u guys recomend?
Old 11-28-2010, 09:47 PM   #16
sc00by4life
Member#: 97135
They already gave you your answer. Use a higher offset wheel (40+). It will not be "flush" or aggressive, but it will clear larger tires with pretty much 0 modification.
Old 11-28-2010, 10:53 PM   #17
simon930
Member#: 231504
2003 WRX
Sonic 16G
My question now is what's the widest tire I can put on the 17x9 +28 with just rolling the fenders?
Also does anyone know how much it costs to pull fenders?
Thanks
Old 11-28-2010, 11:09 PM   #18
sc00by4life
Member#: 97135
^^ having a shop do it will be texa$. this is typically something that is done by yourself, at home. every wheel set up requires a different amount of work, and needs to be customized to your fitment.
did you not read a single ****ing post in this thread?
+28 is still an aggressive fitment! If you are trying to avoid doing a lot of fender mods you need to run a skinny tire!!! If you want wider tires, you need to pick a different wheel!
Old 11-28-2010, 11:15 PM   #19
simon930
Member#: 231504
2003 WRX
Sonic 16G
so then a 225 would work without pulling? or no?
Old 11-28-2010, 11:23 PM   #20
BarnzyRX02
Member#: 185112
2002 Impreza WRX
PSM 17x9 +17
try it. let us know how it goes.
then ask the question again.
BarnzyRX02 is offline   Reply With Quote
Old 11-28-2010, 11:25 PM   #21
simon930
Member#: 231504
2003 WRX
Sonic 16G
is that a no?
Old 11-28-2010, 11:26 PM   #22
Uncle Scotty
Member#: 16200
OK buy Nates beans
Thanks
d00000000000000d
yew can NOT make them properly wheels fit your 2003 wrx
I dont care what tires yew put on
they are gunna hit the front AND back and NOT where you think they will hit
they wont fit without extreme stupidity of some sort
Old 11-28-2010, 11:33 PM   #23
simon930
Member#: 231504
2003 WRX
Sonic 16G
basically what will i need to do to make them fit?
Old 11-29-2010, 12:22 AM   #24
Uncle Scotty
Member#: 16200
OK buy Nates beans
buy a different car???
d000000000000d
yew will look like some hooptie driving down the road IF---IF you can **** the suspension up enough to MAKE those wheels fit at all
the bugeye was almost impossible to make a 17x9 fit even with a +40
and you wanna try a +28????
good ****ing luck
Old 11-29-2010, 12:24 AM   #25
Uncle Scotty
Member#: 16200
OK buy Nates beans
oh yeah
you will HATE driving the car it you can, by some miracle, make those wheels fit the car
I PROMISE....it WILL suck....but I guess you are gunna find out
FS : FS: Drag DR-31 17 x 9 with 255/40/17 also track brakes!!! C Branch SWIC Private Classifieds 2 08-31-2010 11:46 PM
FS : Drag DR-31 18x9.0 +28 5x100/114 (Gold) QwaktastiK Wheels/Tires 3 07-22-2010 05:47 AM
FS or FT Drag dr-31 17x9 +28 5x100 | 5x114 wheels with tires beedee SCIC Private Classifieds 27 10-23-2009 09:14 PM
FS or FT Drag dr-31 17x9 +28 5x100 | 5x114 wheels with tires beedee Wheels/Tires 10 10-19-2009 07:59 PM
FS: Drag DR-31 17x8, 5x100, 35mm offset nukeart Wheels/Tires 1 10-09-2009 10:52 AM
