Old 11-29-2010, 12:25 PM   #1
krautklimb
Member#: 257446
Default Effect of Wheel Weight on Mileage?
Does anyone know if the weight of the wheel has a significant effect on mileage? I'm assuming steelies weigh more than alloy rims. I've seen alloys down in the 17-20 lb range.
Just wondering if it's even worth consideration.
Thanks!
krautklimb is offline   Reply With Quote
Old 11-29-2010, 12:38 PM   #2
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
No gas mileage difference at all.
<---- has 16 lb and 24 lb wheels
Byzantium is offline   Reply With Quote
Old 11-29-2010, 12:41 PM   #3
DrDanimalSize
Member#: 254097
2010 2014 Impreza
My winter set-up is 16" alloys instead of my stock 17". Probably lost 6-7lbs per corner, no mileage difference to speak of.
DrDanimalSize is offline   Reply With Quote
Old 11-29-2010, 12:44 PM   #4
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Weight generally has little effect on highway mileage. It only increases rolling resistance, which is peanuts compared to drag.
The effect on city mileage will be slightly more, but not any more than putting some luggage in the trunk.
sniper1rfa is offline   Reply With Quote
Old 11-29-2010, 01:59 PM   #5
68Cadillac
Member#: 95901
Agreed.
The more stop and go driving you do the more the rotational mass of the wheel and tire will effect your gas mileage, and brake wear.
By how much? Not enough to justify buying a full set of new wheels and tires. $1500 buys a lot of fuel. Especially considering that $1500 is on top of the fuel you would normally purchase.
68Cadillac is offline   Reply With Quote
Old 11-29-2010, 02:15 PM   #6
Leftlane2
Member#: 251904
2010 WRX 5 Door
SSM
Leftlane2 is offline   Reply With Quote
Old 11-29-2010, 02:46 PM   #7
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
OK, great example of correlation not equating to causation in that article.
It's extremely unlikely that the change in wheel weight was what caused the big change in mileage in the Car and Driver test. Much more likely is that it was caused by the increase in drag resulting from a shorter sidewall, along with the progressively wider tires and, in the 18" and 19" sizes, the softer compound increasing rolling resistance.
Take a look at bicycle wheels for an example: the more aerodynamic wheels have larger "sidewalls" which reduce drag at the expense usability (crosswinds become a bigger issue).
Wheels width vs. wheel weight on street car CR22 Tire & Wheel 34 12-10-2008 01:33 PM
How much cooling effect does wheel have on brakes? shemoves Brakes, Steering & Suspension 13 07-05-2006 01:23 AM
Effects of tire/wheel weight on 1/4 mile times??? B-Kerr Brakes, Steering & Suspension 0 02-17-2003 03:15 AM
Effect of aftermarket parts on market value? Sauginius General Forum Archive 6 01-19-2001 01:56 AM
