Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Complete Car Part-Out
Old 11-29-2010, 03:05 PM   #1
Rizzo314
Member Sales Rating: (23)
Member#: 42215
2002 WRX being built
and going for 10s :evil:
Default Complete Part Out: 2003 WRX
The rules/guidelines for my part out are as follows:
1. I will update this post with any items that are SOLD/UNAVAILABLE and PENDING PAYMENT. If there is an item on either of those lists, it is either SOLD or AWAITING PAYMENT. DO NOT ask if these items are still available. You will be made fun of.
2. I am doing my best to provide parts, pieces, and items at affordable, reasonable prices. Please do not insult me by making an offer that is well below market value.
3. Parts are on a first come, first served basis. If you call "dibs" please have cash in hand. I am not going to pass on other offers, just to have you not follow through with your "dibs". I do realize that location and schedule will effect when payment/pick up can be arranged, and I am willing to work with you on that.
4. Car and parts are located on the Westside of Indianapolis. Although cash and carry is preferred, I will ship at Buyer's expense.
5.Please DO NOT PM me. Additional fees will be charged for any items asked about through PMs. Consider it an illiteracy tax. I prefer you post in this thread or email me. ri22o at earthlink . net
If there is a part you are interested in, just ask. I will update this post with items that have sold. If you don't see an item in that list, chances are it is still available. At this time, there is no item, part, or piece too small.
I am parting out a 2003 PSM WRX Sedan that was hit in the front right. The airbags did not deploy. The main items damaged were the fender, ABS module, front bumper, headlight, hood, and engine. Everything else appears to be fine.
KNOWN Non-Stock PARTS
Draw-tite Tow Hitch w/ harness
SOLD / NO LONGER AVAILABLE
KYB Struts
Pink Springs
Wheels
Clutch
Flywheel
Front Seats
Radio
VF34 Turbo
All 4 doors
Side Mirrors
Door Panels
Door Glass
Rearview Mirror
Radio/HVAC Surround
Entire Long Block
Complete Intake Manifold
Fuel Injectors
Belt Driven Accessories
Coolant Reservoir
ECU
Wiring Harness
Intake
Boost Gauge
Blow-off Valve
Entire Gas Tank
Fuel Pump
Dash
Dash Bar
Complete Turbo Back Exhaust
SPT STi Shifter and Linkage
Foglights
Front Bumper Beam
Driver's Headlight
Driver's Fender
Exhaust Manifold
Up-Pipe
Cupholder
Shift Boot
Driver's Window Trim
Passenger's Window Trim
Boost Control Solenoid
Radiator
Radiator Overflow Tank
Front o2 Sensor
Rear o2 Sensor
Aftermarket Aluminum Intercooler
Transmission
Transmission Crossmember
Shift Knob
Entire Pedal Set w/ Switches
Throttle Cable
Carpet
Hood Latch
Hood Cable
Both Fender Liners
Both Front Sidemarkers
R160 Rear Diff
Both Rear Axles
Both Front Axles
Trunk Carpet
Trunk Floor
Both Trunk Liners
Front Tow Bolt
Front Sway Bar and Hardware
Rear Sway Bar and Hardware
Driver's Side Grill Insert
Clock Spring
Passenger's Side Hub
Driver's Side Hub
Trunk
Front Brake Calipers/Brackets
Rear Brake Calipers/Brackets
Front Rotors
Rear Rotors
PENDING PAYMENT
< Nothing at this time. >
Rizzo314 is offline   Reply With Quote
Old 11-29-2010, 03:36 PM   #2
mtcs
Member Sales Rating: (29)
Member#: 180640
2000 FF Drag Impreza
6765,PPG,brakeman,Chute
How much you want for the Throttle body and sensors?
mtcs is offline   Reply With Quote
Old 11-29-2010, 04:10 PM   #3
cabikejumper
Member Sales Rating: (10)
Member#: 226604
2000 Mustang GT
Maybe I misread. The Hvac surround is sold?
I need the upper vent trim also..
cabikejumper is offline   Reply With Quote
Old 11-29-2010, 04:18 PM   #4
Rizzo314
Member#: 42215
Yes, that is why it is listed in the sold column.
Upper vent trim, the one with the hazard button?
Old 11-29-2010, 05:11 PM   #5
cabikejumper
Member#: 226604
2000 Mustang GT
Yes, Wgere the hazard button sits. I only need the trim. Not hazard,and vents behind trim. ONLY TRIM
Old 11-29-2010, 05:24 PM   #6
gtfaded
Member Sales Rating: (12)
Member#: 142322
2002 wrx
wrb
Small red plug cover on alternator and front ac hose. How much?
gtfaded is offline   Reply With Quote
Old 11-29-2010, 05:36 PM   #7
Rizzo314
Member#: 42215
SGP shows it at $75. $35, shipped?
I will need to see if I still have that cover. It may have went with the wiring harness, but I may have one laying around.
Which AC hose are you looking for? I'm pretty sure I have all of them, I just need to make sure it's not damaged.
Old 11-29-2010, 06:31 PM   #8
Pudge
Member Sales Rating: (8)
Member#: 264114
2001 2.5 rs
do you have the interm wiper stalk and momo shift knob and pedal set?
Pudge is offline   Reply With Quote
Old 11-29-2010, 06:44 PM   #9
Rizzo314
Member#: 42215
Yes, I still have the entire steering assembly. Make an offer on the stalk.
I don't have the knob or pedals. It came with a Pep Boys Special Knob, so I never thought to add it to the list. The pedal set just sold, I must have forgot to add it.
Old 11-30-2010, 11:04 AM   #10
gtfaded
Member#: 142322
2002 wrx
wrb
Very intetrested in that plug cover if you find it, and the AC hose I need connects by the radiator, it's the discharge hose.
Old 11-30-2010, 12:26 PM   #11
Rizzo314
Member#: 42215
Alright, I'll check tonight and let you know.
Old 11-30-2010, 04:23 PM   #12
Rizzo314
Member#: 42215
I have the cover, and I think I found the hose you need. Get me your email address and I'll send over a picture to make it's the one you need.
Old 11-30-2010, 06:58 PM   #13
freerider42
Member#: 265455
how much for the front window motors and and left inside door handle with compnents, and all the drivers window mechanics for the racks and llever
freerider42 is offline   Reply With Quote
Old 11-30-2010, 07:17 PM   #14
Rizzo314
Member#: 42215
All four doors have been sold in their entirety.
Old 11-30-2010, 09:41 PM   #15
Fierysun
Member Sales Rating: (92)
Member#: 82745
2005 Subaru STI
2003 WRX Wagon
How much for the wiring harness? The one that's connects to the ECU.
Fierysun is offline   Reply With Quote
Old 11-30-2010, 10:10 PM   #16
Rizzo314
Member#: 42215
It is SOLD and not available.
Old 11-30-2010, 10:37 PM   #17
soobster_2003
Member Sales Rating: (1)
Member#: 150113
2003 impreza wrx
sonic yellow
just outta curiosity how much are u wanting for all the trim pices around the radio, a/c vents. and door handles. and the spedo bezel if so are they still the factory silver?
soobster_2003 is offline   Reply With Quote
Old 11-30-2010, 10:45 PM   #18
Rizzo314
Member#: 42215
Of the items listed, the only one still available and not on the SOLD list is the gauge cluster/speedometer bezel.
Old 11-30-2010, 11:54 PM   #19
TheDutchman
Member#: 248992
I'm looking for the insert that goes into the rear bumper, above the license plate.
TheDutchman is offline   Reply With Quote
Old 12-01-2010, 12:31 AM   #20
Pudge
Member#: 264114
2001 2.5 rs
crap just read your think, sorry aobut PMs. 20 for wiper stalk?
Old 12-01-2010, 07:14 AM   #21
Rizzo314
Member#: 42215
The styrofoam low mph bumper insert?
Old 12-03-2010, 07:14 AM   #22
Rizzo314
Member#: 42215
Lots of questions answered, but no further responses. Oh how I've missed NASIOC.
Old 12-03-2010, 03:23 PM   #23
fobert
Member#: 40608
2003 Impreza WRX
WR Blue Pearl
Wondering if the driver side fender liner is available.
What is the condition of the passenger side fender liner?
Are you willing to ship to 20878?
fobert is offline   Reply With Quote
Old 12-04-2010, 11:35 AM   #24
Rizzo314
Member#: 42215
Sorry. The driver's side was non-existent, and the passenger side was ripped.
Old 12-07-2010, 12:17 PM   #25
scoobydoo914
Member Sales Rating: (3)
Member#: 235500
2004 psm wrx
02 psm wrx
how much for the rear bumper shipped to 10804
scoobydoo914 is offline   Reply With Quote
Complete part out: wrecked 2002 wrb wrx. Lots of goodies! Javi_LGT South East Region Private Classifieds 110 06-23-2012 07:00 PM
Part out: 02 wrx hybrid/vf34/ppg trans all new parts. wrxej205 Complete Car Part-Out 201 04-27-2011 04:28 PM
COMPLETE PART OUT: 20g, tmic, tbe, injectors, more.....L@@K! VladiWrX Engine/Power/Exhaust 16 06-03-2008 01:46 PM
NYC part out: STI, WRX, Legacy, RS parts andivic Private 'For Sale' Classifieds 39 07-05-2006 12:29 AM
Message Board Statistics All times are GMT -4. The time now is 09:39 AM.
