Old 11-30-2010, 09:29 AM   #1
VTrider36
Member#: 208656
2004 WRX Premium 4dr
WR Blue
Default Ultra Performance tires and gravel
I'm looking into buying my rex some new shoes and i'm thinking of Dunlop's Direzza star specs. My question is how do these kinds of tires (with large tread blocks, performance compounds and few grooves) handle on dirt?
My house is off of a 1mile dirt road with hills and a usually loose gravel setting. Do these tires have less grip on off-road surfaces? dangerously poor traction, or just less than awesome?
Thanks in advance.
VTrider36 is offline   Reply With Quote
Old 11-30-2010, 09:43 AM   #2
oldskoolWRX
Member#: 66248
1983 turbo brat
black and white
dangerously poor. but it isn't like you can't drive around it. just drive according to that particular set of conditions. they will also not like the cold. the dz101's are fine, but the z1 star spec rubber is very high performance and needs heat (hence the summer only rating). i loved mine in the snow, but i enjoy slipping and sliding, keeps you on your toes!
oldskoolWRX is offline   Reply With Quote
Old 11-30-2010, 09:43 AM   #3
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Much less grip, but it's not excessive. The main thing you notice is floating at higher speeds since you're skipping over the loose gravel. A little wheelspin clears that right up. I wouldn't worry about it; be aware of the tires but otherwise drive normally. FWIW I run starspecs and am comfortable getting sideways with them on gravel.
The soft compound is actually good for the surface once you get down past the loose stuff. Even gravel rally tires are made from race rubber.
EDIT: I completely disagree with oldskoolWRX. Summer tires can even be the right choice for rallycross sometimes, depending on the surface. Also, euro rallycross is typically done on tarmac tires as the loss on the dirt is not nearly as big as the gain on tarmac.
EDIT again: obviously they won't work in the cold or in snow. I don't think that was the question, though.
sniper1rfa is offline   Reply With Quote
Old 11-30-2010, 09:53 AM   #4
F3nris
Member#: 262657
2016 WRX Prem
Lapis Blue Pearl
<- Not an expert but plays one in commercials when paid to.
But my best guess is that they would handle like slick tires on dirt. I know the stock Dunlops from my '11 don't like dirt roads very much.
Ultra performance tires are meant to be as slick as possible and give max dry traction by sticking to a high friction surface (tarmac/concrete) with just enough groves in it to pass a DOT inspection and wick some water from the occasional car washing puddle away.
F3nris is offline   Reply With Quote
Old 11-30-2010, 11:02 AM   #5
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
fwiw I've driven a ~15 mile section of logging track a couple of times on Hankook R-S2s (when I didn't have time to swap out to something more suitable)
this is graded gravel but it tends to wash into quite deep gravel in the corners - and also gets quite washboarded
definitely floaty - I don't think I'd want to do it every day, got to stay pretty alert
UkNuck is offline   Reply With Quote
Old 11-30-2010, 11:20 AM   #6
n2oiroc
Member#: 141952
15 legacy 16 wrx
they work fine on gravel except they pick up rocks and toss them at your fenders like mad.
n2oiroc is online now   Reply With Quote
Old 11-30-2010, 11:26 AM   #7
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
That's true, I forgot about that. I once broke a guy's windshield because he was following too closely on a gravel road. He yelled at me as if I could do something about it.
Old 11-30-2010, 01:13 PM   #8
VTrider36
Member#: 208656
WR Blue
well thanks gentleman, much appreciated.
I'm sure its not that bad in gravel, but i do live in VT where cold might be an issue... and i loathe my winter tires so i keep my summers on till october.
Shall i find some tires with some more conservative tread patterns to be on the safe side?\
But i want that grip so bad...
Old 11-30-2010, 02:13 PM   #9
n2oiroc
Member#: 141952
15 legacy 16 wrx
you have snows and want max dry performance. pick one of these 2. they are the best and are fine for "normal" driving on gravel. you wont regret either one!
http://www.tirerack.com/tires/tires....el=Ventus+R-S3
http://www.tirerack.com/tires/tires....t+Z1+Star+Spec
Old 11-30-2010, 04:10 PM   #10
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
In new england the cold isn't really a problem, honestly. If you swap in october you're in the clear by a long way. I only swapped a couple weeks ago. Besides, you need to downgrade a looong way to get any meaningful cold weather performance. Have fun with your sticky rubber.
Old 11-30-2010, 07:46 PM   #11
oldskoolWRX
Member#: 66248
1983 turbo brat
black and white
hahaha! thanks for disagreeing to agree! re: drive according to conditions!
yes rally tires are made of race rubber, but also don't have as flat tread blocks. see the snow part of my post, but way to be contrary!
Old 11-30-2010, 08:41 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
you shouldnt post things like this because
the above is just wrong in many ways
WAY-WAY wrong
Old 11-30-2010, 11:42 PM   #13
VTrider36
Member#: 208656
WR Blue
i love when my thread attract uncle scotty.
makes me feel special, even if its not my post...lol
Old 11-30-2010, 11:55 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
my experience with off road here in florida is mostly sand/gravel and I have not had too bad of luck with my UHP tires on sand
I have gone places with my car that had the local rednecks
Old 12-01-2010, 12:08 AM   #15
Back Road Runner
Member#: 60082
2004 Forester STI
Funny thing is the soft compound actually conforms pretty well to gravel, so the tire doesn't actually end up too slick. Most of what a high performance tire lacks is the tread block design to really bite. You get the soft compound conforming some over the gravel to give ok operation, but you never really get any serious bite from the tire. Gravel pick-up is dependent on the tire used. I have RE01R, and that does not throw rocks. A different brand/model may be very different though.
Please Explain High Performance vs Ultra High Performance Tires. andyfish Tire & Wheel 10 02-04-2005 12:52 AM
BRAND NEW 2004 WRX STI RE070 Ultra High Performance Tires kaktuspete Private 'For Sale' Classifieds 6 10-29-2003 12:44 PM
Goodyear F1: only AA Traction Ultra High Performance Tire? What about Falken 451? dug-e-fresh Brakes, Steering & Suspension 6 01-16-2003 08:15 AM
performance tires and gravel/dirt biggreen96 Brakes, Steering & Suspension 5 03-10-2002 01:55 AM
Performance tires and snow?!? Mike&Michele Technical Forum Archive 9 10-07-2000 07:42 AM
