Old 11-30-2010, 09:29 PM   #1
loose Subie
Member#: 262067
Default What does 16 flashes mean
So I got ran off a winter road today, it took me quite a bit to get it out, a little bit of full throttle forward and reverse. And i got a little poof from under the hood, no big deal it made it out.
Anyways the car is a 93 turbo auto, running 13pounds of boost water to air intercooler and 3" turbo back exhaust.
I wouldn't be heart broken if the tranny had to go or the center diff, I just hadn't planned on doing right now. Any idea what 15 or 16 flashes of the green power light on the dash means on start up? I'm dying to know cause the car doesn't move on it's on power anymore, it takes like half throttle before it surges forward, and as quick as that comes on it's gone, also putting it back in park sounds like something grinding, so I quickly turn it off.
I checked the tranny fluid looks good doesn't smell burnt, front diff fluid looks okay too.
Any ideas?
loose Subie is offline   Reply With Quote
Old 11-30-2010, 09:40 PM   #2
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
runninstrong is offline   Reply With Quote
Old 12-01-2010, 08:49 AM   #3
loose Subie
Member#: 262067
Well it appears it's a shift solenoid
Old 12-01-2010, 12:32 PM   #4
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
The 16 flashes is just the default number to let you know there's a problem. You have to perform the diagnostic check to determine the actual code.
I'd suggest trying both test procedures, and then reset the TCU to see if the same code comes back right away.
Legacy777 is offline   Reply With Quote
What does a flashing CEL mean? Patrick Olsen Normally Aspirated Powertrain 10 02-04-2002 04:08 PM
205/55-16's 215/45-17's what does it all mean? Matey Brakes, Steering & Suspension 10 04-06-2001 12:43 AM
what does ST X mean? v6scoobie Newbies & FAQs 3 11-19-2000 01:19 PM
what does SUS 304 means? antonRS Newbies & FAQs 7 11-02-2000 06:06 PM
What does the rabbit mean? chyisan General Forum Archive 17 08-22-2000 12:01 AM
