Old 12-01-2010, 04:20 PM   #1
42Autosports
Member#: 257297
2002 H6
Default Another 42 Autosports 3.0RS, EZ30D Swapped GC Impreza
For Round 3 in the EZ30D Swap Department we have another 2001 2.5RS to take apart.
First we needed to start taking it apart. We removed the engine, wiring harness, some interior stuff and the headlights and grill.
Next we prepped the H6 for installation.
The headlights, grill and wiring harness have returned!
The owner no longer wants his STi Hood Scoop so if anyone is interested let me know.
An empty dash makes it easier to get the wires where they are supposed to go.
With most of the wiring done the dash beam goes back in and it starts looking like a drivable car again.
The engine goes in and runs great!
Keep tuned for more updates. Right now we have to install the cooling system, finish the wiring and get the car back in the hands of its owner.
Thanks for checking it out.
Miles
Email:[email protected] -----------------Website:www.42Autosports.com------------------Call:704.425.3044
Check Out 42 Autosports On Facebook
42Autosports is offline   Reply With Quote
Old 12-01-2010, 05:46 PM   #2
otistag18
Member#: 170502
2004 WRB WRX
2006 PSM STI
That's sick man! How many of these have you guys done? What tranny are you using?
otistag18 is offline   Reply With Quote
Old 12-01-2010, 05:52 PM   #3
42Autosports
Member#: 257297
2002 H6
This is number 3. First was an 07 2.5i and the last one was a 2001 2.5RS.
We reused the stock 5MT in all 3 cars. So long as your are not launching at 5k the trans should last pretty well.
Old 12-04-2010, 05:43 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I know your first swap was a Haltech; what about the next two? Are they stand-alone ECUs as well, or are you using the stock EZ30D ECU?
Pat Olsen
Old 12-05-2010, 01:31 PM   #5
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Miles, what did you do for the radiator on the three cars? I have Dylan at DS1 making me one but he hasn't finished it and my R will need SOMETHING at some point at least to let it start and move around. Also if you happen to find a cheap source for accessories I'd Appreciate it. The PS pump is different and I haven't checked the AC yet.
Seraphinwolf is offline   Reply With Quote
Old 12-05-2010, 03:50 PM   #6
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
please tell me you guys are going to make an intake to make that STi scoop actually be effective
Old 12-05-2010, 05:07 PM   #7
Seraphinwolf
Member#: 150922
97 OBS EZ30R
I think a shortram would be better.
Old 12-06-2010, 11:43 AM   #8
Homemade WRX
Member#: 33782
96 bastard child
uh, why?...there is a reason every racecar that can, does have a pressurized via aero intake box
Right now that monster scoop is just a drag and lift enducing machine. Not to mention that it would technically be a 'cold air' intake then too.
Old 12-06-2010, 06:13 PM   #9
42Autosports
Member#: 257297
2002 H6
The radiators were stock or stock replacement Legacy H6 radiators and hoses with a custom radiator support and custom overflow tanks. Which accessories are you referring to?
The scoop is for sale. No STi scoop intake will happen on this car.
Old 12-06-2010, 09:54 PM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Can you be a little more specific and/or provide some pics to show what you did to fit the radiator? Are you using the stock H6 fans with the radiator? Are you able to retain the A/C condenser, or is the radiator pushed forward to where the condenser would be sitting?
Thanks,
Pat
Old 12-07-2010, 12:20 PM   #11
42Autosports
Member#: 257297
2002 H6
The radiator is in the stock location, as is the AC condenser. It was necessary to use (2) 12" slim fans in place of the stock fans, otherwise it is all in stock locations using stock Legacy parts.
Here are some photo's of Jon's H6 car we did over the weekend. The big difference in his car is that we set up the fans to push instead of pull because his car has no AC and thus no AC condenser.
This install was the same as our previous H6 cars. A stock H6 Legacy radiator in the stock Impreza location using stock H6 Legacy radiator hoses.
Old 12-07-2010, 03:17 PM   #12
Yeah Its A Wagon
Member#: 229506
02 wagon
wrb
just curious .. how much would a swap like this go for .. including everything ..
Yeah Its A Wagon is offline   Reply With Quote
Old 12-07-2010, 04:12 PM   #13
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Excellent, thanks for the info!
Pat
Old 12-07-2010, 04:17 PM   #14
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
Very cool swaps, subscribed.
OppositeLock is offline   Reply With Quote
Old 12-08-2010, 09:52 AM   #15
42Autosports
Member#: 257297
2002 H6
A turn-key swap where you bring us a good car in decent shape could run as little as $5-6k. This includes an untouched used H6 motor, stock H6 ECU, new Clutch, Flywheel, Header, Radiator, Slim Fans and all necessary wiring to make it work. I'm sure there are some other new parts we include that I'm just not thinking of right now.
Depending on what you want to do with the car it can significantly increase from there, e.g., built motor with turbos, high-compression NA Build, stand alone ECU, 6 Speed swap etc.
PM or call for more details.
Old 12-08-2010, 11:38 AM   #16
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Miles I was asking about the motor accessories. The PS pump, AC compressor, and the bracket for the AC and alternator(I have a ps bracket already)
FS : NJ: 2001 Ej205 swapped GC VF39 275whp 260wtq $8500 tscott915 Private Vehicle 'For Sale' Classifieds 28 01-17-2011 01:34 AM
42 Autosports 2001 2.5RS H6 Swap - EZ30D Inside! 42Autosports Subaru Conversions 21 12-04-2010 07:04 PM
Subaru Extra-S 1L Bottles + 42 Autosports Synchro Magic Packages Starting at $75!!!!! 42Autosports Vendor 'General Sale' Forum 1 09-15-2010 06:21 PM
42 Autosports - 1L Bottles of OE Subaru 75w90 Extra-S Gear Oil + Synchro Magic 42Autosports Vendor Announcements 2 09-14-2010 05:14 PM
New Vendor - 42 Autosports 42Autosports Vendor Announcements 0 09-10-2010 03:16 PM
