Old 12-02-2010, 11:05 AM   #1
solort
Member#: 261484
Default Need help with 17in wheels-max tire size
I bought a set of 17x7.5 ET48 wheels for my 03. I know the guides give limits to wheel width to tire width, but if I put 255/40-17 tires on the wheels, will they fit under the wheelwells and not rub the stock suspension? I would normally put 225/45-17s, but I can get a great deal on the wider tires. Thanks for any suggestions
I autocross and used to fitting 245/45-16 tires on a 16x6.5 wheel (for a stock class vehicle). I remember a guy that would fit a 225 tire on a 13x5 Honda rim! Looked like a cantiliver slick!
solort is offline   Reply With Quote
Old 12-02-2010, 11:34 AM   #2
mosc
Member#: 177401
2015 STi White
255/40R17 require 17x8.5" wheels minimum. The wheels you listed are a full inch too narrow to use those tires. The widest tires you can fit on your wheels are 225/45R17.
Remember that 45 sidewall is designed to stretch more than 40 sidewall.
in terms of fender clearance, 255 at +48 clears the strut fine but is very close to the fender. Rear fender roll recommended.
mosc is offline   Reply With Quote
Old 12-02-2010, 03:33 PM   #3
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
where can i find a great deal on 255/40/17's?
feint05 is offline   Reply With Quote
Old 12-02-2010, 04:09 PM   #4
DrDanimalSize
Member#: 254097
2010 2014 Impreza
235/45 will fit fine, probably even 245/45 (which is pushing it IMHO), but it's true that a 40 series sidewall won't have as much give.
DrDanimalSize is offline   Reply With Quote
Old 12-02-2010, 04:22 PM   #5
wrxBRAH
Member#: 256841
2004 FXT
on stock height 255s wont rub and you can fit those on 17s but i wouldnt recommend it. just buy federal 235. the fit and look will be about the same.
wrxBRAH is offline   Reply With Quote
Old 12-02-2010, 04:53 PM   #6
REX8
Member#: 24038
I think you mean, 8.5" is recommended. Don't we do this like every other day?
And no again. A 235 will certainly fit. A 245 would "fit" as well. You are the king of tire/wheel overstatements.
Anyway OP, I think you'd be happiest with a 225, but a 235 will certainly fit, without issue, depending on the tire. On a stiff summer, the 235 will feel fine. With a softer sidewall, you probably don't want to give up the steering response of the 235 compared to the sharpness of the 225.
245 on 7.5 inches starts to feel a bit sloppy, even on stiff tires, let alone a smashed on 255. There's just no reason for it.
I need help pricing some wheels & tires. Inspector Gadget Tire & Wheel 2 01-08-2010 11:28 PM
04 STI wheels... what max tire size slobaru Tire & Wheel 1 10-27-2008 01:09 AM
LGT wheels width? Max tire Size?? Rapid_Roo Legacy Forum 12 11-24-2005 02:16 PM
'03 wrx wagon: max tire size on OEM wheels and suspension setup. 03RexWgn Tire & Wheel 5 11-02-2005 12:29 AM
Help Me Decide Wheel and Tire Size STi_Pete Brakes, Steering & Suspension 0 07-31-2002 12:04 AM
