Old 12-03-2010, 02:08 AM   #1
Slvrblur02
Member#: 127986
Default Dangers of mixing tires.
What's up guys, just looking to get some feedback on something. I recently was driving on a 3 hr road trip and had to pull over half way because one of my tires was so warped that it was shaking my entire car. I am not sure if it is because I need an alignment (not that bad), or the possibility that my strut is busted... probably both. I currently am rocking a doughnut and all weather hard compound POS tires and don't have the money for all four tires because I need brake pads and an alignment. To finally get to my question, I really want to get some decent performance tires again like I used to (G forces) but would only have enough to get two for right now. What would the dangers be if any of having higher grip tires on either the front or back and different others for a while? I know that things like this can be hard on our transmissions, but i do not plan on driving that hard and don't want to waste the money on Camry tires again lol. Thanks guys.
-02 wrx
Slvrblur02 is offline   Reply With Quote
Old 12-03-2010, 10:59 AM   #2
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
CN: You really should have all 4 tires the same type and tread depth
If the front and back tires are not very close to the same diameter, your center diff will get cooked.
If the front tires have more traction than the rears, the car will oversteer in an emergency swerve situation, possibly dangerously.
If the rear tires have more traction than the front, the car will understeer in an emergency swerve situation (not usually dangerous).
Mike Wevrick is offline   Reply With Quote
Old 12-03-2010, 11:12 AM   #3
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
this is the reason my 2000 rs did not survive, when i bought it the owner had es100's z rated on front, and kumho 711 g-rated? before i could afford a new set the car was totalled by i friend i let drive, the tires were the second contributing factor, other than me being a 19yr old retard. so heres what you get when you do this
crappy tires on front+sticky rears= terrible understeer followed by snap oversteer(what happened to me)
crappy rear tires+sticky fronts= oversteer and spinning
moral of the story please learn from my stupidity, source some used tires online with even treadwear and never buy g-forces, terrible tires and overpriced, look into some federal ss595's as they are cheap and decent
feint05 is offline   Reply With Quote
What are the Dangers of having uni-directional tires spinning the WRONG way? plunk10 Off-Topic 22 08-10-2010 07:47 AM
Dangers of eating small bits of cast iron? Full_Clip Off-Topic 30 03-23-2007 01:48 PM
Tire Recommendation: Summer/AutoX/Track mix tire? DeusExMachina Tire & Wheel 9 07-05-2005 10:19 AM
Mixing tires... Good? Bad? iBlueVirus Brakes, Steering & Suspension 8 01-17-2002 11:28 AM
danger of high wattage? or What parking light bulb? technix Interior & Exterior Modification 2 09-27-2001 11:38 AM
