Old 12-03-2010, 11:52 AM   #1
VDMTom
Member#: 105226
08 Impreza
Default Adapter spacer on rear drum assembly safe? And different offset, but same tire OK?
I have an '08 Impreza Base model, and the rear brakes are a drum assembly(God damn Subaru. =/)
1. I was thinking about running a 20mm adapter spacer with studs from Kics. And I was wondering if the rear hub will be able to run the adapters safely? I chose 20mm, as I researched I wouldn't need to trim my stock studs.
2. The difference for the front and rear offset would be 15mm.
38 in front
23 in rear
Same tire, same wheel height and length.
My diff won't be messed up correct by running two different offsets?
VDMTom is offline   Reply With Quote
Old 12-03-2010, 04:39 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
No, your diffs won't be bothered by different wheel offsets.
I'm sure someone will jump in and tell you this idea is stupid and your wheel bearings will explode into flames in short order and blah blah blah, but assuming the spacers are bolted on properly there shouldn't be any safety concerns with the Kics spacers.
Old 12-03-2010, 11:44 PM   #3
VDMTom
Member#: 105226
08 Impreza
Thanks, just what I wanted to hear. I am aware of my wheel bearings exploding as soon as I place them on
I just need someone to answer the damn spacer on rear drum question. God damnit.
Old 12-04-2010, 03:15 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
just d0000 it d0000000d
tell us if ya crash and burn
Old 12-04-2010, 12:38 PM   #5
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Your car is going to handle awful. Understeer galore.
Conversion spacers are absolutely in no way an acceptable way to convert lug patterns. The idea needs to be stricken from your mind. The only viable way is to swap hubs.
Also, is there any reason your are only wanting to convert the rear?
Byzantium is offline   Reply With Quote
Old 12-04-2010, 01:05 PM   #6
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
My only question is why? Why would you only want to run the spacers in the rear?
That said, I don't see why it would be any more harmful/bad to run spacers on a drum over a disc setup. I guess you'll just have to try and find out.
Old 12-04-2010, 04:11 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Where did he say he was converting bolt patterns? As far as I can tell Kics just sells bolt-on spacers with the same lug pattern.
Old 12-04-2010, 09:24 PM   #8
VDMTom
Member#: 105226
08 Impreza
I'm running an adapter spacer in the rear 20mm, and a nonadapter 5mm in the front. The difference would be 15. I'm not changing any bolt pattern....
Old 12-04-2010, 10:12 PM   #9
sc00by4life
Member#: 97135
then you aren't running "adapter spacers" if you aren't changing the bolt pattern.
Old 12-04-2010, 11:19 PM   #10
VDMTom
Member#: 105226
08 Impreza
Ok, spacer with studs......
Old 12-05-2010, 12:18 AM   #11
pnutbutta
Member#: 192572
2007 Impreza
CGM
youll be fine with drums as long as the spacer sits flush on the mounting surface of the drum itself.
pnutbutta is offline   Reply With Quote
Old 12-05-2010, 01:18 PM   #12
Byzantium
Member#: 207826
85k 2002 WRX
He said he was going to run adapters in the rear...
mixing same tires, but different load rating. Beanboy Tire & Wheel 2 03-19-2010 04:08 PM
15 mm spacer on 52mm offset wheels ? How safe ? Serkan Tire & Wheel 20 09-15-2009 05:42 PM
Rims are bent, but are tires ok? Fleek04 Vancouver Impreza Club Forum -- VIC 11 01-17-2006 09:52 PM
What causes major squeal on rear drum brake (cold only)? newrxnj Brakes, Steering & Suspension 1 07-02-2004 06:51 PM
different height front/rear tires ok? sick1.8t Interior & Exterior Modification 6 08-04-2002 05:30 AM
