Old 12-03-2010, 12:41 PM   #1
Britain
Member#: 247604
1974 Porsche 914
1700lb AX Car w/ Spec-C
Default What is needed to make AVCS function?
I am working on installing a JDM v8 Spec-C engine in a Porsche 914. I have most of the wiring sorted out, however I have been informed that to make the AVCS function properly, I will need the vehicle speed sensor and the neutral position switch. I am not running a Subaru transmission and therefore do not have either of these.
Can anyone provide some input to exactly what is required to make the AVCS function and why?
-Britain
Britain is offline   Reply With Quote
Old 12-04-2010, 09:49 PM   #2
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Small Car sells a magnetic hall sensor for their Vanagon conversions. I just ordered one and will let you know if it can be adapted. I am using 930 cvs and trans so figure I will have to play with the item. Their website says the 5 magnet per rotation simulates the factory unit...
Thanks
RSti_Spyder is offline   Reply With Quote
Old 12-04-2010, 10:06 PM   #3
Britain
Member#: 247604
1974 Porsche 914
I will check that out. The number of magnets as well as the diameter will probably need to be simulated.
-Britain
Old 12-04-2010, 10:10 PM   #4
Britain
Member#: 247604
1974 Porsche 914
Hmmm...that would work perfectly. I might need to make a new plate to fit the 944 turbo CV's that I have on my car. I think I will pick one up.
-Britain
what is needed to make avcs heads non avcs nhsilversti Built Motor Discussion 9 11-02-2010 11:16 PM
JDM STi pinks on a bugeyes. What is needed to make them work? Dizmal Brakes, Steering & Suspension 4 01-29-2006 10:07 PM
I just thought of what Subaru needs to make... Corn-Picker News & Rumors 6 05-01-2003 05:06 PM
What is used to make a front grill? IMPREZA GUY Interior & Exterior Modification 5 07-14-2001 07:16 PM
What is needed to make complete setup.... Rubasu Brakes, Steering & Suspension 7 11-18-2000 12:13 AM
