Old 12-04-2010, 10:32 AM   #1
fastfalcon94
Member#: 126123
Default Just merged my 98rs to 06 wrx harness, having some problems:(
Posted same thing on rs25.com too
http://www.rs25.com/forums/f128/t147...ml#post2313550
Background: 98 2.5rs coupe, 06 wrx 2.5L engine w/ 40k miles, immobilizer, key, ECU,engine wiring harness, dash wiring harness all from the same car.
I couldn't find an exact guide, but used Brydon's 07STI to 99RS guide as I read it's the same as 07WRX. Obviously I have a 98 so I had to convert the pins to B84 connectors.
The car will not start. It will crank, but I am getting no fuel (pump is running but injectors are not pulsing) or spark. Also the main power relay is not providing power to the ECU. It's triggered via the self shutoff control wire from the ECU. On the 98RS this was a 12V trigger. On the 06 WRX, it is a ground trigger. The same is true, but vice versa for the fuel pump relay.
So to fix this, you just swap the opposite trigger wires between the fuel pump relay and the main relay. I've done this. Still my self shutoff wire is not providing ground, it's not providing 12V either. I'm not sure what it's doing, but it won't trigger my main power relay.
If I ground the self shutoff control relay it will power the main relay and ECU. I can try cranking the car, but still no fuel or spark. I've tested every ground at the ECU.
More questions
There were 2 rs sensors here. I'm assuming I need to get the 06 wrx ones for the new harness? I left the old rs plugs on there just incase not wired to anything. Could not having these sensors plugged in cause the engine not to get fuel or spark?
My next thought is the immobilizer. I double checked my wiring here. I don't have pins 5 or 9 hooked up. 5 is some light,and 9 is some keyless entry wire that is T'd to an impact sensor. I don't have an impact sensor. Is there anyway for me to test my immobilizer?
Here is my DBW. Can't really test this yet
I believe these are air controller wires for something I don't need. These don't need to be hooked up anywhere right?
And this is minor to me right now, but.
I'd appreciate any help I can get. If anyone knows what they are doing and local I'd gladly compensate them for some troubleshooting time. I've spent a good 10 hours on this after work, and I can't figure it out.
fastfalcon94 is offline   Reply With Quote
Old 12-04-2010, 11:50 AM   #2
kcpaz
Member#: 194611
1998 Legacy GT
Mexico Blue (not red)
I'd have to look at the wiring diagram again, but I'm almost 100% sure the brown and red wire coming off of the immobilizer has to run through the LED in the cluster, to a fused 12v source. In the diagram it ways it goes to FB-8 M/B Fuse NO. 2 (B). You can try not using the LED and just running that wire directly to a 12V source and see if that works. If not, you may have to source that exact LED bulb and try again.
Also, I'm assuming you have the ignition key that matches the ECU along with the antenna from the column, and the immobilizer matches the ECU... right?
kcpaz is offline   Reply With Quote
Old 12-04-2010, 12:08 PM   #3
RSmatt
Member#: 8039
94 v2 STi RA - RHD
I don't recall ever having to hook up this wire during a merge using an immobilizer. I'm fairly certain that I never even bothered to hook it up.
Let's start with the fuel pump relay and main relays.
Undo what you have currently done. Reattach the GR wire back together. Now merge the LgR wire (directly below the GR) to the ground wire you had the GR hooked to.
Next, take what was the ground coming from the main relay and a merge it with the BR wire in pin 5 of the Main Relay. This is more like a "T" merge, leave no loose ends between the ground and both ends of the BR.
Now let's skip to the brown and gray engine plugs.
The LR and LY wire will not be needed, if you are not going to run the secondary air pumps. The YL wire at pin 1 of the brown plug must be tied in with the YG at pin 3 of the Main Relay (another "T"). The YL wire should have continuity with the YL at pin 1 on the DBW relay, and also with b134 pin7 and b135 pin2.
Hopefully this will help a bit.
RSmatt is offline   Reply With Quote
Old 12-04-2010, 12:51 PM   #4
kcpaz
Member#: 194611
1998 Legacy GT
That must mean the brown and red wire is supplying the ground to the LED circuit. I couldn't tell in the diagram whether that was the case or if the LED was inline from a power source to the Immobilizer. Thanks for the clarification.
Reconditioning some 06 wrx heads, have some ?s Bad Noodle Built Motor Discussion 13 07-08-2010 08:06 PM
Got tuned.....having some problems:( motocooney Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 05-24-2010 01:02 AM
just got my Accessport or 06 wrx MT junkboxer AccessPort 8 09-21-2006 02:58 PM
Just got my brand new 06 WRX Standard STi Juice Bay Area Impreza Club Forum -- BAIC 5 07-08-2006 10:32 PM
