Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 12-04-2010, 01:03 PM   #1
Member#: 193881
Default O2 sensor problem
Hey all, I recently finished putting a 2003 wrx engine in a 98 RS using the wiring harness from a 2004 wrx, the only snag I am running into is the front O2 sensor. I am getting a P0031 code, I changed the sensor and it didn't fix the problem. I measured the voltage at the connector and got the following:
Small white wire-4.7v
Small black wire- 4.7v
Large white wire- 3.4v
yellow/red wire- 12v
I remember reading somewhere that there are two wires for the O2 sensor pinned out in the ECU differently between the years 2003 and 2004. Because I am running the 2003 ecu with the 2004 harness, this could be my problem, but I can't find it again to know which wires to change.
Any help is greatly appreciated!
lushy is offline   Reply With Quote
O2 sensor problem SubaruLover Warranty Issues & SOA Problems 5 08-22-2002 09:18 PM
O2 sensor problem w/S-AFC and A/F ratio gauge Scoobyslack1 Normally Aspirated with bolt-on Forced Induction Powertrain 6 09-05-2001 03:38 PM
THERE IS A RECALL FOR MY00 RS FOR O2 SENSOR PROBLEM CALL YOUR DEALER CHACHI Normally Aspirated Powertrain 12 04-07-2001 03:07 PM
o2 sensor problems, lean A/F mixture. Help me! Quart2000 Normally Aspirated Powertrain 0 02-07-2001 07:29 PM
O2 sensor problems ac_gohan Bay Area Impreza Club Forum -- BAIC 0 01-23-2001 01:47 AM
