Old 07-03-2002, 11:51 AM   #1
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
Question Hose & Bolt Sizes
Does anyone know the sizes for the Water hose, crank case vent hose, oil return and send lines, turbo coolant lines, and the size(s)of the banjo bolts used for the oil lines.
seven881 is offline   Reply With Quote
Old 07-07-2002, 12:52 PM   #2
TaiChih
Member#: 3467
1998 Dinan3
Bleck
water hose- ID 1 1/4"
crank case vent hose-IIRC1/4"
oil return- should be 10AN
oil feed should be around 4AN
that's all I know.
TaiChih is offline   Reply With Quote
Old 07-07-2002, 01:41 PM   #3
8Complex
Member#: 922
04 FXT
Red
All the crank case and valve cover vent hoses are 1/2" ID.
TaiChih - Are you sure on that 1-1/4" water hose? I could've sworn it was smaller then that.
Old 07-07-2002, 01:57 PM   #4
TaiChih
Member#: 3467
1998 Dinan3
Bleck
I meant the radiator water hose.... I guess that's not what he was talking about I'm such a n00b
bolt size and replacement? tedward88 Newbies & FAQs 7 06-02-2010 02:43 AM
Bolt size for bolt on exh mani heat shields? djoye Factory 2.0L Turbo Powertrain 1 11-08-2007 01:24 PM
Size of hose & t-bolt clamps... help! sizzflair Newbies & FAQs 0 05-03-2007 10:36 PM
Oil Cooler Bolt Bolt Size??? Josey Wales Factory 2.0L Turbo Powertrain 0 09-11-2006 12:23 PM
Bolt size/thread pitch for seat bolts? anti.team Interior & Exterior Modification 1 09-30-2004 10:42 AM
Message Board Statistics All times are GMT -4. The time now is 10:14 AM.
