Old 12-05-2010, 02:18 AM   #1
slobaru02
Member#: 172781
02 WRX
Default VW Wheels On A WRX
I have a 2003 wrx with stock suspension and was wondering if I put my steelies and snow tires from my 05 vw gli will it fit on the rex? Its a 205/55/16 and I know the bolt pattern is the same 5x100. Will there be an issue with the offset tho? Worse case I can put the snow tires on the stock rims, but I'd rather use the steelies for the winter. If anyone has some experience on what clears and works please let me know. Thanks.
slobaru02 is offline   Reply With Quote
Old 12-05-2010, 11:45 AM   #2
jdmboy
Member#: 240161
2002 wrx wagon R.I.P
87 bmw e30
do you have any idea what the offset of the steelies are? other than that the hub bore is different, the mkiv vws have slightly larger hubs. however i do not know if your steelies are hub centric.
jdmboy is offline   Reply With Quote
Old 12-05-2010, 12:10 PM   #3
2011WRBlue
Member#: 264508
You can always go down to a local wheel/tire shop and buy a set of hub rings to make them hubcentric.
2011WRBlue is offline   Reply With Quote
Old 12-05-2010, 02:31 PM   #4
jdmboy
Member#: 240161
87 bmw e30
only if the wheels have a larger hub bore than the car your trying to put them on which i dont believe is the case.
Old 12-05-2010, 04:36 PM   #5
2011WRBlue
Member#: 264508
I believe VW's are 57.1mm and our cars are 56.1mm.
Old 12-06-2010, 08:27 AM   #6
mr_hann
Member#: 165244
2007 2.5i
i was interested in same setup, but tried some outback 15's (which barely fit my n/a) and went with those instead. i also found that VW used a 1mm larger hub bore, and they have lower offsets. the offset should help brake clearance, as long as the wheel design is caliper friendly. i would be surprised if they didn't fit.
but there's a much easier way to answer your question, and you know what it is.
mr_hann is offline   Reply With Quote
Old 12-06-2010, 09:13 AM   #7
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
My brother used VW steelies on an '02 once.
sniper1rfa is offline   Reply With Quote
Old 12-06-2010, 10:06 AM   #8
pnutbutta
Member#: 192572
2007 Impreza
CGM
yes it will work no problem. vw uses hub bore only 1mm larger than subaru - no needs for rings. offset wont be a problem because of how narrow the wheel is and the tire on the wheel is the correct sizing for your wrx
/thread.
pnutbutta is offline   Reply With Quote
Old 12-09-2010, 07:42 PM   #9
slobaru02
Member#: 172781
02 WRX
thank you everything fit fine
Old 12-09-2010, 11:34 PM   #10
16VDub
Member#: 266609
2002 GTI
Wish it went that easy for subie rims on VW :P
16VDub is offline   Reply With Quote
vw wheels on a wrx Karna Member's Car Gallery 28 11-19-2009 04:06 PM
MK4 VW wheels on a WRX? ever12 Newbies & FAQs 10 04-14-2009 12:25 PM
VW wheels on a Suby blueb3 Legacy Forum 13 03-19-2008 01:36 PM
VW style wheels on a WRX, what do you guys think? rice h8r Off-Topic 73 12-27-2007 12:07 AM
New wheels on Zoebs WRX...Yes AGAIN. (Hyper Black Tarmac 3's on MBP Sedan) suby_dude Member's Car Gallery 40 01-15-2007 10:35 AM
