Old 12-07-2010, 08:25 AM   #1
stiferko
Member#: 261366
1997 STiR
Default jdm v7 trans with usdm hubs?
i was wondering if when using the JDM V7 trans and rear diff, if i am able to use any type of USDM hubs, and also which axles i would use?
ive heard i cant use USDM non-STi hubs based on the axles, but im not sure.
thanks!
stiferko is offline   Reply With Quote
Old 12-07-2010, 08:50 AM   #2
25rsti
Member#: 166324
I used v7 spec c trans with v8 sti components but I needed to uninstall the stubs hanging out the front diff because of the male axles on the v8 stuff and get new seals. Search key words, there is tons of stuff to help like it did for me.
found a pic of the stubs I was talking about, if you weren't sure.
Old 12-07-2010, 09:00 AM   #3
stiferko
Member#: 261366
1997 STiR
i couldnt think of any good key words for that...
i figured trying to use JDM diffs, and USDM hubs was kind of a specific subject
Old 12-07-2010, 09:06 AM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
The stub is part number 38415AA110 and the circlip is part number 805329010.
That will help you out a bit.
You need to clarify what hubs you have. USDM 04 are 5x100 and 05-07 are the 5x114.3. IIRC JDM had 5x100 from 01-03 on their STi 6-spds...the others were 5x114.3mm. I always screw up model years with JDM stuff.
Regardless, JDM and USDM doesn't mean crap in reference to hubs as they've both had both
With that said, what hubs do you have?
Old 12-07-2010, 09:15 AM   #5
25rsti
Member#: 166324
Thanks for posting the part #s Homemade, I didnt have those around me now. I wouldnt search this thread but the Transmission section.
Old 12-07-2010, 11:13 PM   #6
stiferko
Member#: 261366
1997 STiR
well im going with a V7 trans and i have 03 wrx hubs
Old 12-08-2010, 12:06 AM   #7
Shainz
Member#: 171778
2002 Snail Wagon
Gray
The WRX front hubs work with STI 6 speed, however the rear differential and axles will not work with WRX rear hubs. You need STI rear hubs to utilize a R180.
Hope this helps.
-Roman
Shainz is offline   Reply With Quote
Old 12-08-2010, 08:20 PM   #8
suberdave
Member#: 101865
88 GL-10 STi
Hope this helps.
-Roman
For the rear i used a custom inner race to mate the R180 STI inner joint to a WRX shaft. check it out here:
http://forums.nasioc.com/forums/show....php?t=2048240
As for front axles your WRX axles will mate to the V7 6 Speed.
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 12-08-2010, 09:37 PM   #9
Homemade WRX
Member#: 33782
96 bastard child
Hope this helps.
-Roman
or http://www.driveshaftshop.com/import...axle-r180-rear
Old 12-09-2010, 04:25 PM   #10
stiferko
Member#: 261366
1997 STiR
would you sell me these custom inner race? if so, how much?
thanks!
dont really want to spend 1200 on rear axles, i can but the full JDM brake/hub assembly front and rear for that much.
WTT JDM v7 shortblock for USDM STi shortblock werkInProgress Private 'Wanted' Classifieds 2 05-23-2005 05:32 PM
Any specialists can confirm the difference of parts for JDM V7 / V8 and USDM STI? V6 Subaru Conversions 3 05-21-2005 11:49 AM
question on JDM V7 / V8 and USDM STi V6 Subaru Conversions 1 05-14-2005 03:06 AM
jdm v7 longblock or usdm 2.5 shortblock? Antonios Kintos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 04-06-2005 01:15 AM
JDM V7 struts w/ USDM GDB springs & top-hats? Call_me_Tom Brakes, Steering & Suspension 4 03-04-2005 10:34 PM
