Welcome to the North American Subaru Impreza Owners Club Wednesday July 30, 2014
Old 12-07-2010, 03:02 PM   #1
lustreking
Member#: 5154
1999 Legacy L
Default 1999 Legacy Timing Belt
The timing belt just went on my 1999 Legacy with a 2.2. I believe that this is an interference engine. Is there any hope for the engine at all?
lustreking is offline   Reply With Quote
Old 12-08-2010, 10:07 PM   #2
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
It's non-interference. Just slap a new one on there, and you are golden.
runninstrong is offline   Reply With Quote
Old 12-08-2010, 11:39 PM   #3
Victrix
Member#: 224605
99 would be a phase 2 EJ22, which IS an interference motor. Do a little searching.
Isaac
Victrix is offline   Reply With Quote
Old 12-09-2010, 09:15 AM   #4
lustreking
Member#: 5154
1999 Legacy L
I talked to a local shop that specializes in Subarus, and they said it's usually just the valves that get bent. They quoted me a price of $1200 to pull the heads, do a valve job, and put them back on with a new timing belt. Does that sound fair?
Old 12-09-2010, 11:58 AM   #5
lustreking
Member#: 5154
1999 Legacy L
If possible, I'd prefer not to invest $1200 in an eleven year old car. I also found an engine out of a 1998 Legacy for $250. Any chance I can directly swap 1998 engine into my 1999?
Old 12-09-2010, 12:57 PM   #6
loose Subie
Member#: 262067
Seems likely
loose Subie is offline   Reply With Quote
Old 12-10-2010, 06:21 AM   #7
MDRSK
Member#: 226510
2001 Legacy GT
Dealer charges between $700-$1000 for just the T-belt. Smaller shops can do the t-belt for around $400-$500. If the shop is reliable, $1200 seems like a decent price. How much will the engine swap cost? Is the replacement engine less mileage? Is it an upgrade of some sort? Seems like overkill if the only problem is "possible" bent valves in the head.
MDRSK is offline   Reply With Quote
Old 12-11-2010, 11:32 PM   #8
Victrix
Member#: 224605
up to 98 will be phase 1 engines, it is not a bolt in swap. If you want a bolt in replacement you will need a phase 2 sohc motor. 2.2 and 2.5 are bolt in and both will run off your ecu. 99-02 2.5L sohc motors would be your best bet for availability of a replacement.
Isaac
Old 12-12-2010, 06:49 AM   #9
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Isaac
Wrong !
1999 EJ25 Legacy motors are still the Phase I MAF style.
a 1999 EJ22 from either a Legacy or a 1999-2001 Impreza would work though.
Just because your timing belt went doesn't mean your valves are bent, although it is generally accepted that they are. Was your car idling or were you driving down the road when the belt broke ?
Jonathan is offline   Reply With Quote
Old 12-12-2010, 02:41 PM   #10
Victrix
Member#: 224605
Originally Posted by Jonathan View Post
Wrong !
Thanks for the knowledge jonathan, wouldn't those be DOHC motors in the 99 2.5, not SOHC?
Old 12-12-2010, 07:36 PM   #11
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Thanks for the knowledge Jonathan, wouldn't those be DOHC motors in the 99 2.5, not SOHC?
Yes. For 1999 only the Japanese-built 2.5 Liter motors were SOHC, the US-built Legacys and Outbacks continued to use the DOHC motors.
Old 12-13-2010, 12:05 PM   #12
lustreking
Member#: 5154
1999 Legacy L
Thanks everyone! I've decided to have them do the work. Unfortunately, they can't get me in until the 20th.
1999 forester timing belt? Rock_Strongo Forester Forum 3 02-20-2006 08:47 AM
1990 legacy timing belt tensioner jim747 Legacy Forum 3 10-04-2005 10:35 PM
2001 subaru legacy timing belt dsunshinell82 Service & Maintenance 4 04-11-2005 10:14 PM
Need help 95 legacy timing belt broke chrSTIan Legacy Forum 22 01-03-2005 07:34 PM
96 Legacy Timing Belt Bioguy Private 'For Sale' Classifieds 0 09-07-2003 03:51 PM
