Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Gauges & Electronics
Old 12-08-2010, 01:23 PM   #1
Z1 Performance
Vendor Sales Rating: (43)
Member#: 9327
Default Stack Pro Control Multi Color Gauges - Accurate, Affordable, and Tons of Features!
Stack is one of the oldest, and most respected names in aftermarket instrumentation. Founded in the UK, and distributed worldwide, Stack gauges can be found in all forms of motorsport.
Stack’s Pro-Control range of Professional Stepper Motor Analogue Gauges brings total control and driver awareness of critical engine functions. The gauges are user configurable with Maximum/Minimum alarms which can be set with one of seven different colours to indicate status.
No Control Unit Needed - everything is controlled on each gauge!!
The Pro-Control series has all of the features of the Professional Analogue Gauges plus:
Peak Values recall
Configurable Max and Min full dial alarm warnings
Temperature gauges with built-in “fan controller”
Configurable Pro-Control output for activating accessories eg. fans, pumps, etc (requires relay)
Pressure gauges with built-in “pump controller”
0-5 Volt analogue output for data logger or ECU
Configurable backlight colour
Black dialface when powered off
Available in metric or imperial (US) measurement
Includes all required wiring and sensors (except fuel level gauge and battery voltage gauge)
Accurate and reliable, all gauges (except the digital Air/Fuel gauge) feature LED through-the-dial and needle backlighting and come complete with wiring harness and associated sensor (except for fuel level gauges).
User-configurable minimum and maximum alarms can be set, with one of seven different colours assigned to each.
As soon as an alarm level is exceeded, the full dialface changes colour. If the level exceeds the alarm by more than 10%, the dialface flashes rapidly to further alert the driver.
With a choice of 7 user-selectable LED backlighting colours ( red, green, yellow, blue, purple, turquoise and white) the user can choose the optimum colour for maximum visibility and readability of the gauge, day and night.
All are 52mm, and available for purchase in either metric or imperial (US) measurements!
Available in the following:
Oil Pressure
Oil Temperature
Fuel Pressure
Water Temperature
Boost (35 psi)
EGT
Fuel Level
Battery Voltage
Prices range between $182 per gauge and $230 per gauge. Package deals available when purchasing 3 or more! We also have various gauge pods in stock too too, from single to multigauge mounting.
Stack also has thoughtfully released a 52mm wideband Air Fuel Gauge as well! Includes Bosch wideband sensor, and features an integrated digital display. Available in your choice of white face background or black face background.
Features:
User-selectable Air/Fuel or Lambda real time display
Includes Bosch sensor
Programmable Alarm warns of dangerous lean condition
Peak Recall of leanest value during last run
Suitable for all fuel types with AFR from 6:1 to 20:1
0-4 Volt Data Logger or ECU output
The wideband is priced at $340.00
Package it with any of the above gauges, pod for a total package deal!
To spec out your gauge package and order, just give us a shout!
__________________
Z-1 Performance
(631)863-3820
AIM: z1auto
Garage Sale on Lots of Parts!
- check out the blog!
Z1 Performance is offline   Reply With Quote
Old 12-26-2010, 03:12 PM   #2
Z1 Performance
Member#: 9327
up top!
__________________
Z-1 Performance
(631)863-3820
AIM: z1auto
Old 01-03-2011, 04:57 PM   #3
Z1 Performance
Member#: 9327
ttt!!
__________________
Z-1 Performance
(631)863-3820
AIM: z1auto
Old 01-23-2011, 06:51 AM   #4
Z1 Performance
Member#: 9327
Up top
__________________
Z-1 Performance
(631)863-3820
AIM: z1auto
Old 01-30-2011, 04:47 PM   #5
djosbun
Member Sales Rating: (1)
Member#: 202176
2004 WRX wgn P1RANHA
'07 Tribeca
I will be replacing my VDO gauges (in the clock pod) with these. I just can't believe that some dealers are selling Stack's for list price. I love the full sweeps of Stack gauges, and you can make the illumination green.
djosbun is offline   Reply With Quote
Old 02-01-2011, 04:26 PM   #6
Z1 Performance
Member#: 9327
ttt!!!!
__________________
Z-1 Performance
(631)863-3820
AIM: z1auto
Old 02-24-2011, 12:40 PM   #7
Z1 Performance
Member#: 9327
up top for Thursday!
__________________
Z-1 Performance
(631)863-3820
AIM: z1auto
Old 03-21-2011, 06:01 PM   #8
Z1 Performance
Member#: 9327
ttt!!!
__________________
Z-1 Performance
(631)863-3820
AIM: z1auto
Old 04-13-2011, 02:31 PM   #9
Z1 Performance
Member#: 9327
ttt!!!
__________________
Z-1 Performance
(631)863-3820
AIM: z1auto
Old 06-14-2011, 01:45 PM   #10
Z1 Performance
Member#: 9327
bump!!
__________________
Z-1 Performance
(631)863-3820
AIM: z1auto
Old 06-20-2011, 04:57 PM   #11
Z1 Performance
Member#: 9327
Monday bump
__________________
Z-1 Performance
(631)863-3820
AIM: z1auto
Old 07-11-2011, 03:40 PM   #12
Z1 Performance
Member#: 9327
up top!
we also carry the FULL Stack range, from individual gauges to their all in one dash solutions like the 8100 Series:
__________________
Z-1 Performance
(631)863-3820
AIM: z1auto
Old 07-21-2011, 07:50 PM   #13
Z1 Performance
Member#: 9327
up top!!!!
__________________
Z-1 Performance
(631)863-3820
AIM: z1auto
Old 08-17-2011, 09:48 AM   #14
Z1 Performance
Member#: 9327
up top!!!
__________________
Z-1 Performance
(631)863-3820
AIM: z1auto
Old 09-01-2011, 08:07 AM   #15
Z1 Performance
Member#: 9327
bump!
__________________
Z-1 Performance
(631)863-3820
AIM: z1auto
Old 09-28-2011, 02:06 PM   #16
Z1 Performance
Member#: 9327
ttt!!!
__________________
Z-1 Performance
(631)863-3820
AIM: z1auto
Old 10-08-2011, 08:40 PM   #17
666stars
Member Sales Rating: (7)
Member#: 221364
2002 Wrx EJ207 Ver 8
Wrb Dccd 5 speed now!
Thes are super nice , just picked up a stack oil pressure gauge
666stars is offline   Reply With Quote
tons and tons of awesome stuff runningguy Non-Subaru Stuff 6 06-22-2010 04:54 PM
Gauges picking up a ton of noise Aarondost08 Electrical & Lighting 4 03-17-2010 06:54 AM
fs: SONY BLUETOOTH cdplayer,tons of features vtakk eg Interior/Dressup/Audio & Security 3 12-10-2006 01:52 PM
Tons and Tons of Cusco!! Z1 Performance Suspension/Brakes/Handling 72 12-16-2005 08:53 AM
Huge Part Out- Tons And Tons Of Goodness bottlediger Private 'For Sale' Classifieds 72 03-17-2005 04:16 PM
