#1 |
Vendor Sales Rating: (46)
Member#: 173316
W. Canada
Since I'm in the holiday spirit I will offer a discount on RCE springs. Here is what I have in stock:
Racecomp Engineering GR('08+STI) Yellows ![]() RaceComp’s classic “Yellow” high performance lowering spring is now available for the GR chassis Impreza STI! Following the release of our popular "Regular Guy" springs, RaceComp has produced a more aggressive lowering spring for the 08+ STI. These new springs lower the car approximately 15mm and include new replacement bumpstops to maintain as much travel as possible on the lowering sensitive GR Impreza chassis. Spring rates are an aggressive 330 lbs/in front and 335 lbs/in rear. With a stance to match the performance, these springs utilize the knowledge RaceComp has gained from years of GR chassis set-up experience to maximize handling, retain ride comfort, and improve the look of your Impreza. Racecomp Engineering’s goal was to help cure the crippling understeer that adds to lap times at the track and autocross course. Studying the design of the new GR suspension, a more aggressive performance spring has been produced that retains available bump travel, matches the OEM dampers, and works in conjunction with the new rear motion ratio. The result is a car that handles extremely well from corner entry to corner exit. Racecomp Engineering GD('02+WRX/STI) Regular Guy springs ![]() The RCE “Regular Guy” Black springs are intended for both the daily driven street driver as well as the autocross and track day weekend warrior. Using similar spring rates as the extremely popular and successful RCE Yellow Springs, but having a much more subtle/mild drop in comparison, these are perfect for STi owners not looking for a ride height much lower then stock, and yet are still looking for increased spring rates. Although, these springs may have a subtle look, you will still be outpacing just about everything on the track and auto-x course. When installing these springs, some addtional NVH may be experienced do to increased spring rate. RCE Yellow GD chassis ![]() The highly anticipated Super Sport Street/Track Springs, an OEM replacement spring for 2004-2007 Subaru WRX STi from Racecomp Engineering. Designed for use with standard STi inverted struts or Ohlins Fixed Perch Replacement Struts, these springs are intended for both the daily driven street driver as well as the autocross and track day weekend warrior. Finally, after years of being the authority on Subaru suspension options for everyone from the daily driver to the professional racer, Racecomp Engineering can now provide their own solution to owners looking for the ultimate OEM replacement spring for their Subaru Impreza WRX STi. Using the very popular JDM STi springs that we brought to the U.S. market in mid 2003 as the benchmark, Racecomp focused on improving on track and autocross performance, while maintaining acceptable ride quality. Extensive research, design, and testing was performed to develop a completely new spring unlike anything currently available. With springs rates increased approximately 25% stiffer then the popular JDM Pink Springs, the springs are perfect for those with wider tires worried about rubbing, as well those looking for a little more rear spring rate to promote a more neutral handling characteristic. Much care was taken not to exceed the limits of the stock struts. The mildly progressive design and spring rates properly matched with the dampers ensure that ride quality is not diminished over stock. The car is lowered 20mm in the rear and 23mm in the front for an even look. RCE Wagon springs('02+WRX/Impreza wagon) ![]() Finally, an option exists for Subaru WRX Wagon owners with upgraded struts! Rather then having to choose between spring rates that are too soft, like most wagon specific springs, and a saggy rear end, like most sedan specific springs, Racecomp Engineering is proud to announce an OEM replacement spring for the Subaru WRX Wagon. Designed for use with standard STi inverted struts, Koni Inserts, Tokico D-Spec struts or Ohlins Fixed Perch Replacement struts, these springs are intended for both the daily driven street driver as well as the autocross and track day weekend warrior. Using similar spring rates as the extremely popular and successful RCE Yellow Springs, but having a wagon specific ride height, these are perfect for wagon owners not looking to compromise either ride height or spring rates. ('02-03 GD require '04+ rear tophats) '08+WRX GTWorx Bilstein/RCE Yellows ![]() $1350 a set Email sales@dalesmotorsport.com for more info.
__________________
Service Center: 604 530 9160 Email- To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "Surrey Board of Trade 2012 business of the year. Providing quality service since 1975!!!" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by dalesalignment&brake; 03-29-2011 at 12:05 PM. |
#2 |
Member Sales Rating: (3)
Member#: 167075
VIC
Vehicle:08 STI & 999R White |
These are great prices... hmmmmmmm
Do you know when if they are going to release a bilstein/RCE yellow combo for the GR STIs? How's the bilstein coilover for the GR STI coming along? |
#3 |
Member#: 173316
W. Canada
Limited quantity of springs remaining at these prices.
Bump
__________________
Service Center: 604 530 9160 Email- To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "Surrey Board of Trade 2012 business of the year. Providing quality service since 1975!!!" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Thread Tools | |
| Display Modes | |
| RCE functional springs in stock for '08+STI | dalesalignment&brake | Canada Region Vendor Classifieds | 2 | 08-20-2009 03:49 PM |
| RCE springs in stock-GD and GRB | dalesalignment&brake | VIC Vendor Classifieds | 0 | 06-24-2009 01:35 AM |
| *BOING* - RCE springs in stock - *BOING* | Turn in Concepts | Suspension/Brakes/Handling | 7 | 06-09-2009 06:52 PM |
| RCE Yellow, Black and Wagon springs in stock | dalesalignment&brake | VIC Vendor Classifieds | 0 | 06-16-2008 08:47 PM |
| Swift Lowering Springs - In Stock for all Suby Models | J-Spec Tuning | Suspension/Brakes/Handling | 13 | 11-22-2005 11:52 AM |
