Old 12-09-2010, 06:35 PM   #1
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
Lightbulb Fully Adjustable Short Throw Shifter
So I just finished my first semester in Automated Machining Engineering and for a final time filler I decided to make an Adjustable Shifter/Shift Knob. The one in my car was cross threaded by the previous owner and impossible to get off so I decided to make my own for free.
Features
- The bottom section is threaded with a set screw to allow full adjustability to set bushing cylinder at proper height.
- Center bushing cylinder is held with a set screw, allowing ease of locating.
- Top rod can be adjusted with over 1" of height adjustment!!!
Once I figure out all the glitches and make a final blueprint/ build procedure I will try to make a few (I know I can't sell on here, you will have to find me on another forum if I do decide to make a few extra)
*This is a prototype that I am trying out, hence the unfinished look*
subaru_steve is offline   Reply With Quote
Old 12-09-2010, 07:43 PM   #2
wantsti
Member#: 134764
04 sti
java black pearl
looks like it will work.
wantsti is offline   Reply With Quote
Old 12-09-2010, 07:57 PM   #3
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Nylon tipped set screws? EDIT: or brass.
Set screws perpendicular to shafts like that drive me nuts. It's a pretty terrible method for securing things.
sniper1rfa is offline   Reply With Quote
Old 12-09-2010, 09:56 PM   #4
ZeroDrift
Member#: 184324
1999 Impreza 2.5RS
Looks nice! How will the set screws keep everything in place with vibration? Do they have a flat surface to mate against or will it mar the threads/parts?
-Reason I mention this is from bad experiences from set screws backing out or damaging the part it was holding.
ZeroDrift is offline   Reply With Quote
Old 12-10-2010, 01:40 AM   #5
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
Just steel
I will take this into consideration, this prototype was more to see if I had the capability to produce something with easy machining practices and allow it to be withint tolerance. I will gladly look into alternatives to this for my next shifter.
Like I said, it was a quick easy fix for what I was trying to do. I know they mark the thread pretty bad so I was hoping to "Set it and Forget it". I will look into other options and hope they don't back out, maybe I'll keep an Allen wrench in the car with me
Thanks for the input guys!
Old 12-10-2010, 03:59 PM   #6
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Looks like a fun project and usable design. If you aren't adjusting it all the time, I think the set screws should work. I would suggest a non-permanent thread locker (ie. blue loctite) on the set screws though. Have you checked clearance in the car? The main piece looks a bit chunky. Might interfere with some of the trim pieces. If you're just doing it for fun, have you considered using something similar to the COBB/MODE design? It is fully adjustable and the non-threaded rods are clamped in very well, without the need to put a set screw into the side of the a threaded rod.
xluben is offline   Reply With Quote
Old 12-10-2010, 04:53 PM   #7
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
Actually I gave the bottom threaded section with the pivot ball around .500" of clearance to play with any trim down there. I have held it next to my stock short shifter for a match up and it looks like it fill fit just fine. I figured with this being fully adjustable I will be able to play with it to meet most quirks I might run into. For instance I was able to get a rough distance of 2" from the top of the pivot ball to the center of the bushing cylinder, so I have made my adjustability on that bottom threaded rod enough to move .250"+/-. The cylinder itself can be moved from side to side incase I have it off by a few thousands. Once I find the fit and find what i like and don't like I will make a new prototype in the new semester.
I am currently mocking up prototypes in AutoCAD of how to better hold the rods. I still like having a thread for the top section with perhaps a lock nut in place of a set screw. The bottom I am looking into doing a "pinch" design. I have the next month to try out what I made and see how it goes, and then make some final fixes and produce a more appropriate part.
Thanks for all the help guys, I never touched a metal lathe/mill before this semester so I am so excited to be making my own stuff and get so excited to see a drawing I made turn into a part in my hand! I can't wait to get on some CNC, EDM, etc in the coming semesters.
WTB: Cobb adjustable Short Throw Shifter ohforesti Private 'Wanted' Classifieds 1 06-15-2006 01:57 PM
FS: Cobb Tuning Double-Adjustable Short Throw Shifter Killian Maynard Private 'For Sale' Classifieds 33 02-26-2005 11:39 PM
Cobb double-adjustable short-throw shifter review: Get one! Cole Transmission (AT/MT) & Driveline 2 12-29-2004 08:39 PM
WTB: STi Short Throw Shifter or Cobb Double Adjustable Short Throw Shifter rich22 Private 'Wanted' Classifieds 8 05-05-2004 03:27 AM
robo adjustable short throw shifter 2.5racer Transmission (AT/MT) & Driveline 4 07-29-2002 12:08 AM
