Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 12-10-2010, 07:38 PM   #1
02wrbRICH
Member#: 258185
Default 18x9 work emotions with -5 offset has anyone done it?
I have an 02 wrx and am looking for new wheels, a friend of mine has some brand new work emotions that she will sell me for way below cost, the problem is the bolt pattern is 5x114. The wheels are 18x9 +28 offset, the adapter i would need to put these 5x114 on my 5x100 car are an inch thick which is the equivelent to approximately the same as those wheels having a -5 offset. So the question is has anyone run a 9inch wide wheel with an -5 offset on an 02-05 wrx?
I have cusco zero2r coilovers with camber plates on the front ones and have camber bolts for the rear these will be going on before the wheels, i also will be rolling my fenders but i am hesitant to pull them, and i will be rocking stretched tires so let me know if you have heard of anyone with this kind of fittment.
02wrbRICH is offline   Reply With Quote
Old 12-10-2010, 07:59 PM   #2
dantastic
Member#: 66815
2005 WRX Wag -SOLD:(
CGM STX #125
You'll be poking 1.5". Buy the wheels, sell for profit!
dantastic is offline   Reply With Quote
Old 12-10-2010, 08:20 PM   #3
jdmboy
Member#: 240161
2002 wrx wagon R.I.P
87 bmw e30
if your going to get the wheels do a hub swap and then see if you can make it fit, ill put it this way i have 18x9s with a 35 offset an had to roll and pull my fenders a little with a 245/35 tire. -5 offset is not going to work without a lot of retarded fender mods probably involving a wench.
jdmboy is offline   Reply With Quote
Old 12-10-2010, 08:56 PM   #4
sc00by4life
Member#: 97135
that will flat out not fit without a widebody, no matter how much you stretch tire.
Old 12-11-2010, 10:56 AM   #5
littlewhitewagon
Member#: 103068
11 STI sedan
Isn't an inch about 25.4mm? Wouldn't that make your wheel a +3? not that it matters...
littlewhitewagon is offline   Reply With Quote
Old 12-11-2010, 02:42 PM   #6
nhat
Member#: 140163
03 STi
hellaflunctional
i say do it
Old 12-12-2010, 12:25 AM   #7
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
The wheels you want would already look and work stupid on your car. The use of adapters would only make them even worse.
Byzantium is offline   Reply With Quote
STi --> WRX cupholder swap, has anyone done it? TX2TH Interior & Exterior Modification 6 11-26-2010 10:35 AM
235/40/18 on WORK emotion 18x8.5 + 37 offset will it fit? DieselClown Tire & Wheel 1 12-15-2008 03:14 AM
Black Chrome center console, has anyone done it? Jus Blaze Interior & Exterior Modification 7 11-21-2008 02:55 PM
Work Emotions with +43 or +47 offset for my 03 WRX 03twrx Tire & Wheel 4 06-08-2005 07:15 PM
Disabling EGR valve: how to, has anyone done it? tonytiger Normally Aspirated Powertrain 15 05-08-2002 09:13 AM
