Old 12-11-2010, 09:01 PM   #1
CBXJ
Member#: 265789
2006 LGTx2,WRX,OBS
Default Anybody used RiteWire?
I'm swapping the engine in my legacy. Anybody used RiteWire to merge thier wiring harneses ? Or east coast swapers Its the same person.
CBXJ is offline   Reply With Quote
Old 01-09-2011, 02:25 AM   #2
BrianMB
Member#: 176104
2005 STI
a little bit late on the reply, however I would recommend against using Ritewire for getting it done. My brother sent his wiring to them last fall to get done (RS to 2005 STI) and it was over 2 months in getting back to him, after requests from them for more money due to being in Canada for one and then other odds and ends. Also from a work stand point, the completed harness was nothing near what was asked and paid for! Being that the only thing that was remaining stock on the RS was the shell, and some of the interior being that the 2005 STI dash wouldn't fit to my brother's standards; the harness asked and paid for was for a full STI swap -> engine with STI rad and fans, STI a/c, gas tank with the fuel pump and delivery system, transmission and diffs including the DCCD, brakes including the abs, water sprayer kit, STI steering column and guage cluster. Remaining in the interior were the radio, and heater controls those were to be the only things remaining of the RS.
What was delivered was a harness setup for the RS fuel tank, the RS guage cluster and RS rad fans, no water sprayer, no a/c, no DCCD, no STI ABS, the wiring for the airbag was for the RS and not the STI on the column, among other things which I am unable to recall at the moment. When confronted on these items, the only answer was it's not compatible.
Best advice I can give you would be to ask a ton of questions before you even ship your wiring and make sure that you WILL without question get that which you have asked and paid for. If you want more details about the whole situation you can send me a PM here.
BrianMB is offline   Reply With Quote
Old 01-12-2011, 06:56 PM   #3
CBXJ
Member#: 265789
2006 LGTx2,WRX,OBS
yikes, gulp, my harness is there now, so far so good, I'll post how things go..., thanks for the info
Want to lower my final drive: Anybody use 205/45-16? beachbum Normally Aspirated Powertrain 15 05-05-2001 11:00 PM
Want to lower my final drive: Anybody use 205/45-16 beachbum Brakes, Steering & Suspension 0 05-02-2001 10:30 PM
Anybody used Legacy springs in an Impreza? Thug Brakes, Steering & Suspension 0 04-06-2001 09:26 AM
Anybody used the new improved STi Gear Set? david2z4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-01-2001 10:14 AM
Anybody use iMotors? Richpac General Forum Archive 3 02-26-2001 01:51 AM
