Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 12-12-2010, 09:31 AM   #1
rdn2fst
Member#: 257699
2006 Impreza WRX STi
Question Turbo Questions
I perused the sticky on turbos and found some good info there. One thing i cant figure out is the notation of 16g, 20g, and such. What is this measurement?
I've just learned that the used 2006 STi (only 40k miles) has a Blouch Performance Turbo. I'm trying to figure out which model it is but I'm not sure. ...The guy I bought it from was the 2nd owner and claimed no knowledge on the performance mods.
So I'm really looking for two things
1. what is 16g, 20g? What's that measurement and what does it mean?
2. What's the story on Blouch turbos? I am a complete turbo/sti noob. just curious how Blouch compares to stock.
rdn2fst is offline   Reply With Quote
Old 12-13-2010, 01:43 AM   #2
96convt
Member#: 182092
11 titan
Lol... type blouch 20g in the search bar and start reading.....
96convt is offline   Reply With Quote
Old 12-13-2010, 05:59 AM   #3
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
16G, 18G, 20G are all Mitsubishi turbo model numbers, they aren't measurements.
Garret turbos have their own naming system:
http://www.turbobygarrett.com/turbob...gt_basics.html
Borg-Warner and Precision Turbo each have their own naming systems as well.
Old 12-13-2010, 09:31 AM   #4
rdn2fst
Member#: 257699
ah, neat. yeah, this highlights my noobness. thx for the replies.
Old 12-13-2010, 12:19 PM   #5
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
If I remember when I had a Blouch 18G on my 02 WRX, If you look on the turbo compressor housing there should be a small metal plaque that lables exactly what specs the turbo has.
Steve.804 is offline   Reply With Quote
Old 12-13-2010, 01:48 PM   #6
nhat
Member#: 140163
03 STi
hellaflunctional
one would hope! i just bought a blouch turbo and it has no markings/plaques other than what's on the compressor housing and a garret plaque.
Old 12-13-2010, 01:53 PM   #7
anthony_delprete84
Member#: 88254
if the guy claims he has no knowledge of the performance mods....WALK AWAY from the car. You will find another one. You will thank me
anthony_delprete84 is offline   Reply With Quote
Old 12-13-2010, 02:08 PM   #8
al82
Member#: 177913
2011 WRX STi PBP
Turbos have different manufacturers. Every manufacturer have their own naming system. If you check out Garret, Mitsubishi, precision, Turbonetics, they all have their own naming system. Stock location Subaru turbos uses the Mitsubishi style turbos. 16g, 18g and 20g are just naming systems for their turbos.
I think 16g is rated 350hp, 18g is rated 400hp and a 20g is rated 440hp.
The way you can tell what is what is by looking at the compressor side. Go to google images and type in Subaru 16g and then Subaru 20g. The 20gs have a bigger compressor side than a 16g. It would be pretty difficult to tell an 18g from a 20g if it has no markings. If the turbo compressor outlet looks straight like a vf39 turbo then its a 16g. If it looks bent then its either 18g or 20g. Blouch is a pretty good turbo company too, they make awesome stuff.
al82 is offline   Reply With Quote
Old 12-13-2010, 06:00 PM   #9
BrandonDrums
Member#: 118630
2005 Wrx wagon
Red
Do this. If the car was pushing more boost without proper tuning it could already have a massive engine failure in the works. You must have proper tuning and maintenance or things will mess up. Not buying this particular car would be a sound idea unless the guy is willing to take it and pay for a full inspection including compression and leakdown testing, oil analysis and doing some data-logs of the tune.
As for Blouch turbos, they are a great after-market manufacturer of Subaru turbos. They make many models so how they perform compared to stock depends on which turbo you buy but as some guys have said, most of them are Mitsubishi based. I would be less worried about what turbo is on the car than how it was used. Finding out how much boost it's pushing, if it's got stable boost control and if the car is running the right timing and A/F ratios to handle the additional boost is much more important.
Essentially, in a Subaru 2.5L, if it's tuned too aggressively and not properly maintained the Ring-Lands in the pistons could go bad and occasionally, even a EJ257 will spin a ring-bearing. Both essentially mean rebuilding or completely replacing the engine so it's no cheap thing.
Good luck
BrandonDrums is offline   Reply With Quote
Old 12-13-2010, 06:21 PM   #10
rdn2fst
Member#: 257699
Thanks all. I bought the car about a month and a half ago. Since then i've removed the TurboXS EBCS and reinstalled a factory EBCS and have bought a Cobb APV2. Cobb stage 2 OTS has been applied. Boost measures at about 19lbs but sometimes gets up to 20lbs if i really lay into it.
I am definitely getting a protune soon. Your replies are what i was looking for on turbo info. Now i just have to figure out what i want to do... Keep it and be stuck with Street Modified class in autocross or shell out mroe money and revert to stock so i can go to my desired class of STU for autocross. Yeah I know I can sell the Blouch but.... ugh. I'm a real sucker for power!
Old 12-14-2010, 02:30 AM   #11
05subiegtwagon
Member#: 262160
2005 LGT Wagon
I got a 20g for my LGT, what do I need for injectors to get the most out of the turbo?
05subiegtwagon is offline   Reply With Quote
Old 12-14-2010, 07:46 AM   #12
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
You need to:
a. Read the damned sticky threads at the top of this forum BEFORE posting.
b. Stay off the internet as this question is for your tuner NOT anyone else.
c. Learn to start your own thread for your own question and not tag along on someone else's issue.
Old 12-14-2010, 10:39 AM   #13
sti guy 13
Member#: 267072
I have a blouch 20g XT with 10cm housing and 3inch inlet and my DW 850's are perfect
also I bought this turbo direct from Blouch and there are no markings on that plate.
sti guy 13 is offline   Reply With Quote
Old 12-15-2010, 10:08 PM   #14
05subiegtwagon
Member#: 262160
2005 LGT Wagon
Thanks for the reply Unabomber your a nice guy sorry I didn't know where to go a little confused on how all this works on this site.
turbo -> downpipe stud, threads in turbo question 1x2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-06-2010 12:50 PM
turbo, EWG and Turbo question silver_rocket Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 05-15-2007 07:47 PM
2 questions- 1) sti sb question 2) bigger turbo question legacy2003 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-23-2005 06:43 PM
newbie with a question...2.5rs turbo question...which ones???? QCK HNDA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-03-2001 09:10 PM
Turbo Question for all you turbo people out there Jimmy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 05-14-2001 02:30 AM
