Old 12-12-2010, 02:49 PM   #1
Jdesindes
Member#: 266809
2005 Impreza wrx
Arctic white
Default white smoke coming from turbo/downpipe and exhaust smell inside my cockpit?
Hi guys.. I Am new to turbo and to subarus lol. Well first things first, i got a 05 wrx stock ej20 only mods are fujita long arm cai, hks carbon ti cbe, 3" bellmouth dp running no cat, full piping, hks sqv bov, and turboxs manual boost controller, haven't gotten the tune or Cobb ap v2 yet but will very soon.. NOW FOR THE BAD, car runs great checked all hoses and belts checked all possible leaks and checked for some type of liquid that could be burning on the downpipe and found nothing. when the car is on for a bit it starts to smell like exhaust fumes and after I turn it off smoke bellows out from the hood scoop but real thin white smoke. I've popped the hood to see where the smoke is coming from and I believe that I may need a new gasket in between the downpipe and turbo.. Recently installed hks carbon ti turboback and that was the last time I saw the gasket and it was pretty crappy.. Before the turbo back it never smoked so idk. If anyone has any suggestions or ideas that could help it would be very appreciated I'm thinking it's the gasket.
Jdesindes is offline   Reply With Quote
Old 12-12-2010, 04:04 PM   #2
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
This is your problem right here.
You cannot put a full TBE and CAI on an 05 without a tune. Your BOV is also probably causing problems. You cannot put an MBC on any year WRX without a tune.
You're lucky your car runs at all.
XanRules is offline   Reply With Quote
Old 12-12-2010, 05:55 PM   #3
ionno
Member#: 223569
02 WRX wagon
Wayyyy to many parts for not having a tune. An accessport doesn't even have a suitable tune for an aftermarket MBC. You definitely need a tune before you do anymore driving on that car, or put the stock intake and downpipe back on, and take off the boost controller.
ionno is offline   Reply With Quote
Old 12-12-2010, 09:28 PM   #4
kbobomber89
Member#: 231418
2006 WRX
I have the same issue and I am on the acessport stage 2 map. I even have a 05 wrx with turboback and an intake and turbo inlet. And it smokes from the turbo/ downpipe area sometimes.
kbobomber89 is offline   Reply With Quote
Old 12-12-2010, 09:40 PM   #5
tank1987
Member#: 223181
05 WRX, stage mehh
hybrid built SOLD!!! :(
Yeah get tuned ASAP, way dangerous to be running without a tune, and if your running a stock turbo your not going to want to be turning that boost up much at all farthest my tuner said I can go up and be safe is to 16psi. I figure Ill stay at 14 and now ruin the turbo. Also get a set of GrimmSpeed Gasket, for all the exhaust components. I recently did and it made a heck of a difference.
tank1987 is offline   Reply With Quote
Old 12-12-2010, 10:41 PM   #6
Jdesindes
Member#: 266809
2005 Impreza wrx
Arctic white
Default Thanks
Alright thanks for the Info guys definately helped!
I am definately gonna get a tune tomorrow.. And also get those gaskets to be safe. I love the sound of the bov but that's the second time I heard it hurts the engine.. I wonder if I can find someone to recirculate it after the tune.
None the less thanks for the help
Old 12-12-2010, 10:45 PM   #7
Jdesindes
Member#: 266809
2005 Impreza wrx
Arctic white
Lightbulb Thanks
I am definately gonna get a tune tomorrow, I was thinking of boosting 13-14psi And also get those gaskets to be safe. I love the sound of the bov but that's the second time I heard it hurts the engine.. I wonder if I can find someone to recirculate it after the tune.
Old 12-12-2010, 10:52 PM   #8
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Fill out your profile. Where are you?
13-14psi is barely stock boost levels. With your mods, you can go up a bit and be safe.
But don't drive it without a tune unless absolutely necessary.
Old 12-12-2010, 11:02 PM   #9
tank1987
Member#: 223181
05 WRX, stage mehh
Technically stock
boost is right around 11 to 12, atleast on my 05 WRX according to the dyno.
Old 12-12-2010, 11:12 PM   #10
spoolinIT
Member#: 259598
2002 Miata
Not to beat a dead horse. But yea a tune. And I had more or mess the same issue difference was I was getting smoke from my vents. My A/C drain tube was rubbing on my DP. Well melted to it. Tube comes thru the firewall. Half way down the DP. I drive an 07 STi. So that might not be the issue at all.
spoolinIT is offline   Reply With Quote
Old 12-12-2010, 11:39 PM   #11
Jdesindes
Member#: 266809
2005 Impreza wrx
Arctic white
[quote=spoolinIT;32721198]Not to beat a dead horse. But yea a tune. And I had more or mess the same issue difference was I was getting smoke from my vents. My A/C drain tube was rubbing on my DP. Well melted to it. Tube comes thru the firewall. Half way down the DP. I drive an 07 STi. So that might not be the issue at all.[/
Ahhh exact prob I have as well white smoke comes out the vents so I just close them and roll with the windows down lol. The tube was rubbing against the downpipe and melted a nice fat hole so I just plugged it in a bit more and It doesn't touch anymore.
Old 12-12-2010, 11:47 PM   #12
Jdesindes
Member#: 266809
2005 Impreza wrx
Arctic white
I'm in moreno valley ca.. My boost gauge reads 11-12 but it needs to be recalibrated so idk. I'm gonna have to drive it to this shop in temecula tomorrow for the tune and see if they have some gaskets as well. Hopefully after that the problem will be solved then I can buy the Cobb ap.
Old 12-13-2010, 12:57 PM   #13
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
You don't need an AP, and you certainly won't need to buy one after the tune.
Old 12-13-2010, 02:24 PM   #14
Jdesindes
Member#: 266809
2005 Impreza wrx
Arctic white
Ohhh ok I see.. Ima get the tune on Wednesday and probably buy sti injectors instead of the ap now.
Old 01-03-2011, 07:24 PM   #15
Xenotos
Member#: 261782
2004 WRX
any update to this? im having a similar problem.
Xenotos is offline   Reply With Quote
Old 01-03-2011, 08:07 PM   #16
Alwayz_Spoolin
Member#: 266836
2004 WRX
Yea , you can recirculate by putting the stock BOV back on ( if you still have it ) , maybe even borrow one from a friend or just buy the recirculation kit for the HKS SSQV . I think the recirculation kits are around $50 .
Alwayz_Spoolin is offline   Reply With Quote
smoke coming from turbo/downpipe area jebsoner00 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 61 03-29-2016 10:38 PM
smoke coming from turbo/downpipe area jebsoner00 Engine Management & Tuning 1 05-09-2010 02:49 AM
White smoke coming from exhaust at idle.... JonJ Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 71 02-01-2010 08:51 PM
Smoke coming from turbo. I smell upgrade. WTB vf39 or vf34! BugeyePB Rex SWIC Private Classifieds 6 10-03-2009 11:17 AM
thin white smoke coming from exhaust only at idle wrx21 Newbies & FAQs 6 12-06-2006 09:26 PM
