Old 12-13-2010, 11:36 AM   #1
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Default Star Spec Z1, bolt puncture!!! Luke, you out there?
Let me start off with a ! I was driving home and some idiot with a box of bolts left his talkgate open....well it fell out of his truck and you know the rest. So I purchased my tires from Luke/tire rack back on 3-09-2010...these are still in very good condition (minus the one with the 5 inch bolt in it!). What should I do? Can I purchase 1 only or do I need 2? This makes me super mad!
wgr73 is offline   Reply With Quote
Old 12-13-2010, 12:18 PM   #2
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
The bolt actually went thru the tire, and hit the inside of the rim...and made a small dent on the bottom inside of the rim!
Old 12-13-2010, 12:26 PM   #3
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
How much tread wear? You might even need to replace all 4 depending on that.
Byzantium is offline   Reply With Quote
Old 12-13-2010, 12:38 PM   #4
nhat
Member#: 140163
03 STi
hellaflunctional
best bet is to purchase a single starspec and ask luke to have it shaved down to the same tread depth as the other 3 tires.
Old 12-13-2010, 12:50 PM   #5
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Thanks for the info guys! I'll have to check the tread wear when I get home. Should I check all 4 tires or just the damaged one?
Old 12-13-2010, 12:55 PM   #6
Byzantium
Member#: 207826
85k 2002 WRX
All of em. They have to be within 2/32" in wear.
Old 12-13-2010, 01:47 PM   #7
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Ok, I will report back my findings. Can I use a simple ruler?
Old 12-13-2010, 02:44 PM   #8
mosc
Member#: 177401
2015 STi White
buy a tread depth gauge. It's worth owning and should be <$10.
mosc is offline   Reply With Quote
Old 12-13-2010, 04:20 PM   #9
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Gotcha, thanks!
Old 12-14-2010, 09:54 AM   #10
Tire Rack Moderator
Member#: 1215
ext. 4362
I agreed with this response
http://www.tirerack.com/accessories/detail.jsp?ID=119
Old 12-14-2010, 01:43 PM   #11
REX8
Member#: 24038
Can't you patch it?
Alternatively, buy 1 and have TR shave it to the correct depth.
Old 12-14-2010, 01:48 PM   #12
mowgli29
Member#: 203438
If the hole isn't MASSIVE in diameter, and its not on the sidewall, I vote for plugging the tire.
Otherwise, new tire + shaved, like they said ^^.
mowgli29 is offline   Reply With Quote
Old 12-14-2010, 02:32 PM   #13
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Ok so I got a depth gauge. Idk if it can be plugged I'll have to ask. The bolt that was in it was about the size of a pencil, is that pluggable?
Luke, your numbers aren't working. Can you Pm or email me back? I sent you an email Saturday or Sunday.
Old 12-14-2010, 02:35 PM   #14
Tire Rack Moderator
Member#: 1215
ext. 4362
phones working fine ... just real busy I'll try to give you a call
Old 12-14-2010, 04:18 PM   #15
REX8
Member#: 24038
Get a patch. No more than $20. Take the tire to you nearest repair shop. They'll do it on the spot.
All this back and forth and you haven't even tried to have it patched or plugged yet?
Old 12-14-2010, 04:21 PM   #16
chickencherryaki
Member#: 240580
Yes. Unless it's within an inch or so of the side wall.
chickencherryaki is offline   Reply With Quote
Old 12-14-2010, 04:48 PM   #17
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
I understand, Thanks for the call Luke!
So it was pluggable after all!!!! He said from the inside it wasn't that bad just looked like it from the outside. It dos still hit the rim which sucks but it's a small
Spot. Thanks for all the help guys!!!
Old 12-14-2010, 05:29 PM   #18
REX8
Member#: 24038
Don't plug, patch. For the 5th time.
Old 12-14-2010, 06:02 PM   #19
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
Thats what i meant!! lol. They used a patch with a plug that goes through too! Oh and it didn't go thru to the rim, crud was just caked on there so it looked like it went through...needless to say this turned out pretty good!
Old 12-14-2010, 06:43 PM   #20
mowgli29
Member#: 203438
Lol... Why is patching so much better? Are plugs more prone to leakage?
To avoid dismounting a tire, I plugged one last year....never had a problem with it afterward.
Old 12-14-2010, 07:19 PM   #21
REX8
Member#: 24038
Patches are worlds better, safer too (much less likely to leak, rip out, etc.). Especially is this guy is competing (track of autox) on those Star Specs.
That being said, I plug most of my tires, for the same reasons as you.
This guy wasn't a DIYer though. So if it's at the tire shop anyway, pay the $10 or so more dollars to patch the sucker.
Old 12-15-2010, 12:20 AM   #22
wgr73
Member#: 232458
2005 & 2008 STi
Cobb 20g & EFR 7670
I plan to auto X next season, hopefully! And they did it for free so it worked out great! I didn't have time to do it myself, otherwise I would've. Thanks for the suggestions too!
Old 12-15-2010, 12:56 AM   #23
nhat
Member#: 140163
03 STi
hellaflunctional
plug and patch would get my vote
Old 12-15-2010, 10:21 AM   #24
Byzantium
Member#: 207826
85k 2002 WRX
And this is why you don't work at a tire shop. Plugs are temporary fixes and always fail. You are also not to exceed certain speed limitations with them.
Patches are good for the life of the tire because it blocks the hole from the inside.
Old 12-15-2010, 12:20 PM   #25
mowgli29
Member#: 203438
You're right, I do not work for a tire shop. If I did, I'd dismount the tire and patch it. I have little free time during the week, so a plug fit the bill in my case. It served me fine for over 10k miles and 100+ mph. (At which point I got new tires, simply because those were worn out.)
I understand that plugs are far from ideal. ...but they're more convenient and cheaper. Why not plug it until one can find time to get it patched?
Can you define "certain speed limitations?"
FS/FT : Black OZ Ultraleggera 18x8 and Dunlop Direzza star spec z1 excipient RMIC Private Classifieds 2 12-30-2010 09:54 AM
FS-Feeler (NorCal): Dunlop Star Specs Z1, 225/40-18, SOLD!!! wwrx Wheels/Tires 5 03-10-2010 05:02 PM
OT collegians....there must be a plethora of you out there..... Naturally_Aspirated Off-Topic 107 02-24-2010 12:58 PM
GT35R ver.8 Spec-C...any good road tuners out there? GT40R Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 05-26-2006 02:14 PM
('93-'01) DMS you out there? kaos200 Impreza Forum 10 06-05-2001 10:47 AM
